On Mon, Jan 19, 2015 at 9:31 AM, matteo.eccher <matteo.eccher@anonymised.com>
wrote:
Dear all,
I am using the WPS request builder demo in GeoServer 2.5.2 and trying to
make an intersection between three layers.
When I execute the "gs:IntersectionFeatureCollection" process on two of the
layers I get some errors.
If the intersection is between the first layer and the second one I get
"extra content at the end of the document";
This one seems to refer to invalid input. Are you feeding GML to the
process? It could be incorrect,
or could be an issue in the parser. Cannot say without seeing the data.
with the second and third the
error is "side location conflict",
JTS intersectin is known to be fragile, there are known problems with
intersections against very
complex polygons (which get much more likely if your polygons are not valid
to start with).
Search the internet for details, but I'm afraid there is no general
solution to the problem
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
