[Geoserver-users] Geoserver WPS python scripting
Hi list:
I’m trying to run python script done through WPS but geoserver does not recognize the existence of geoprocesses I created.
I’m following the instructions:
http://docs.geoserver.org/stable/en/user/community/scripting/py/index.html
http://suite.opengeo.org/docs/latest/processing/scripting/processcreate.html
When I make a GetCapabilities (http://localhost:8080/geoserver/ows?service=wps&version=1.0.0&request=GetCapabilities), get the list of all who are part of geoprocesses geoserver (gs., geo., vec., ras., JTS.,gt.) but none of them is py.*
When I run a DescribeProcess (http://localhost:8080/geoserver/ows?service=WPS&version=1.0.0&request=DescribeProcess&identifier=py:distbear)
get the next response:
<ows:ExceptionReport xmlns:ows=“http://www.opengis.net/ows/1.1” xmlns:xsi=“http://www.w3.org/2001/XMLSchema-instance” version=“1.1.0” xsi:schemaLocation=“http://www.opengis.net/ows/1.1 http://localhost:8080/geoserver/schemas/ows/1.1.0/owsAll.xsd”>
<ows:Exception exceptionCode=“NoApplicableCode”>
ows:ExceptionTextNo such process: py:distbear</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
and the log of the geoserver reports:
2014-05-05 11:50:12,296 WARN [geoserver.ows] - Could not get a ServiceInfo for service wps thus could not check if the service is enabled
2014-05-05 11:50:12,298 ERROR [geoserver.ows] -
org.geoserver.wps.WPSException: No such process: py:distbear
at org.geoserver.wps.DescribeProcess.processDescription(DescribeProcess.java:106)
at org.geoserver.wps.DescribeProcess.run(DescribeProcess.java:96)
at org.geoserver.wps.DefaultWebProcessingService.describeProcess(DefaultWebProcessingService.java:69)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:622)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
If for exmaple i do describeprocess of JTS:buffer:
http://localhost:8080/geoserver/ows?service=WPS&version=1.0.0&request=DescribeProcess&identifier=JTS:buffer
this works fine and works well for any pre-existing geoprocessing in geoserver.
My geoserver was compiled with:
mvn clean install -Pwps
The version I’m using is : (geoserver and tomcat)
Versión:2.4-SNAPSHOT
Revisión de Git: ea0d7c50695f6c2a4564fc5f8fceb1c0b6eb543a
Fecha de compilación :21-Mar-2014 19:03
Versión de GeoTools :10-SNAPSHOT (rev ff340eb96a28b463470cc79a566f8ed12fab934e)
Versión GeoWebCache 1.5.0 (rev 1.5.x/f981cafd349886bb2a1ef45067f26b1aa8e4aff4)
Apache Tomcat/6.0.35 JVM: 1.6.0_30-b30-
Appreciate your help!
Pablo
Hey Pablo,
The python scripting stuff doesn’t come by default with the wps module, so if building from sources you’ll have to enable it separately. Instead build with this command.
mvn clean install -P wps,script,script-py
That should enable the basic scripting functionality plus the python runtime.
-Justin
On Mon, May 5, 2014 at 9:00 AM, pablo zader <pzader@anonymised.com> wrote:
Hi list:
</ows:Exception>
Pablo
Is your legacy SCM system holding you back? Join Perforce May 7 to find out:
� 3 signs your SCM is hindering your productivity
� Requirements for releasing software faster
� Expert tips and advice for migrating your SCM now
http://p.sf.net/sfu/perforce
Geoserver-users mailing list
Justin Deoliveira
Vice President, Engineering | Boundless
jdeolive@anonymised.com
@j_deolive
Hi Justin
When I run the command : mvn clean install -Pwps,script,script-py , this gives me the error
[INFO] Scanning for projects…
[WARNING]
Profile with id: ‘wps’ has not been activated.
[WARNING]
Profile with id: ‘script’ has not been activated.
[WARNING]
Profile with id: ‘script-py’ has not been activated.
I do not understand what the problem is, can you help?
Pablo
2014-05-05 19:45 GMT-03:00 Justin Deoliveira <jdeolive@anonymised.com>:
Hey Pablo,
-Justin
Pablo J. Zader
Lic. en Cs. de la Computación
CONAE
pablo.zader@anonymised.com
"Los Grandes Hombres hablan sobre ideas…
Los Hombres Promedio hablan sobre cosas…
Los Hombres Pequeños hablan… de otros Hombres.
del libro Matemática estas ahi? A. Paenza "
Hi list:
</ows:Exception>
Pablo
Justin Deoliveira
@j_deolive
Hi Pablo,
What directory are you running the command from? It must be run from the root of the source tree.
https://github.com/geoserver/geoserver/tree/master/src
-Justin
On Tue, May 6, 2014 at 9:42 AM, pablo zader <pzader@anonymised.com> wrote:
Hi Justin
[WARNING]
[WARNING]
[WARNING]
Pablo
Justin Deoliveira
@j_deolive
Hey Pablo,
-Justin
Pablo J. Zader
CONAE
Hi list:
</ows:Exception>
Pablo
Justin Deoliveira
@j_deolive
Hi Justin
Sorry, I’m using geoserver SNAPSHOT from https://github.com/boundlessgeo/suite .
Then what I did was:
mvn clean install -Dgs.flags=“-P wps,script,script-py”
and I think it worked.
Thanks.
2014-05-07 8:49 GMT-03:00 Justin Deoliveira <jdeolive@anonymised.com>:
Hi Pablo,
-Justin
Pablo J. Zader
CONAE
Hi Justin
[WARNING]
[WARNING]
[WARNING]
Pablo
Justin Deoliveira
@j_deolive
Hey Pablo,
-Justin
Pablo J. Zader
CONAE
Hi list:
</ows:Exception>
Pablo
Justin Deoliveira
@j_deolive
