I’m trying out the new geoserver1.7.0 war on an EC2 Windows instance:
Windows 2003 small instance
Java 1.6.0_07-b06
Apache Tomcat/6.0.18
Postgres8.3/PostGIS1.3.3
Geoserver1.7.0.war + gdal-plugin + image-pyramid-plugin
When I reload geoserver webapp from Tomcat Manager I’m getting this error in geoserver log?
2008-10-27 09:24:16,046 INFO [geoserver.global] - Done disposing datastores.
ERROR [data.jdbc] - There’s code using JDBC based datastore and not disposing them. This may lead to temporary loss of database connections. Please make sure all data access code calls DataStore.dispose() before freeing all references to it
And this in the tomcat stdout_20081027.log log:
27 Oct 10:19:06 INFO [geoserver.global] - Disposing DataStores at GeoServer shutdown…
27 Oct 10:19:06 INFO [geoserver.global] - Done disposing datastores.
log4j:ERROR Error occured while converting date.
java.lang.NullPointerException
at java.lang.System.arraycopy(Native Method)
at java.lang.AbstractStringBuilder.getChars(Unknown Source)
at java.lang.StringBuffer.getChars(Unknown Source)
at org.apache.log4j.helpers.ISO8601DateFormat.format(ISO8601DateFormat.java:128)
at java.text.DateFormat.format(Unknown Source)
at org.apache.log4j.helpers.PatternParser$DatePatternConverter.convert(PatternParser.java:444)
at org.apache.log4j.helpers.PatternConverter.format(PatternConverter.java:64)
at org.apache.log4j.PatternLayout.format(PatternLayout.java:503)
at org.apache.log4j.WriterAppender.subAppend(WriterAppender.java:301)
at org.apache.log4j.RollingFileAppender.subAppend(RollingFileAppender.java:236)
at org.apache.log4j.WriterAppender.append(WriterAppender.java:159)
at org.apache.log4j.AppenderSkeleton.doAppend(AppenderSkeleton.java:230)
at org.apache.log4j.helpers.AppenderAttachableImpl.appendLoopOnAppenders(AppenderAttachableImpl.java:65)
at org.apache.log4j.Category.callAppenders(Category.java:203)
at org.apache.log4j.Category.forcedLog(Category.java:388)
at org.apache.log4j.Category.error(Category.java:302)
at org.geotools.util.logging.Log4JLogger.severe(Log4JLogger.java:129)
at org.geotools.data.jdbc.JDBC2DataStore.finalize(JDBC2DataStore.java:139)
at java.lang.ref.Finalizer.invokeFinalizeMethod(Native Method)
at java.lang.ref.Finalizer.runFinalizer(Unknown Source)
at java.lang.ref.Finalizer.access$100(Unknown Source)
at java.lang.ref.Finalizer$FinalizerThread.run(Unknown Source)
27 Oct 10:19:08 ERROR [data.jdbc] - There’s code using JDBC based datastore and not disposing them. This may lead to temporary loss of database connections. Please make sure all data access code calls DataStore.dispose() before freeing all references to it
27 Oct 10:19:15 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: D:\gdal_data
27 Oct 10:19:17 WARN [referencing.factory] - Axis elements found in a wkt definition, the force longitude first axis order hint might not be respected:
PROJCS[“WGS84 / Simple Mercator”, GEOGCS[“WGS 84”, DATUM[“WGS_1984”, SPHEROID[“WGS_1984”, 6378137.0, 298.257223563]], PRIMEM[“Greenwich”, 0.0], UNIT[“degree”, 0.017453292519943295]], PROJECTION[“Mercator_1SP_Google”], PARAMETER[“latitude_of_origin”, 0.0], PARAMETER[“central_meridian”, 0.0], PARAMETER[“scale_factor”, 1.0], PARAMETER[“false_easting”, 0.0], PARAMETER[“false_northing”, 0.0], UNIT[“m”, 1.0], AXIS[“x”, EAST], AXIS[“y”, NORTH], AUTHORITY[“EPSG”,“54004”]]
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
27 Oct 10:19:20 INFO [geoserver.global] - Loading feature type ‘DS_giant_polygon:::giant_polygon’ (layer 1/17)
27 Oct 10:19:21 INFO [geoserver.global] - Loading feature type ‘DS_poi:::poi’ (layer 2/17)
27 Oct 10:19:21 INFO [geoserver.global] - Loading feature type ‘DS_poly_landmarks:::poly_landmarks’ (layer 3/17)
27 Oct 10:19:21 INFO [geoserver.global] - Loading feature type ‘DS_tiger_roads:::tiger_roads’ (layer 4/17)
27 Oct 10:19:21 INFO [geoserver.global] - Loading feature type ‘sfArchsites:::archsites’ (layer 5/17)
27 Oct 10:19:21 INFO [geoserver.global] - Loading feature type ‘sfBugsites:::bugsites’ (layer 6/17)
27 Oct 10:19:21 INFO [geoserver.global] - Loading feature type ‘sfRestricted:::restricted’ (layer 7/17)
27 Oct 10:19:21 INFO [geoserver.global] - Loading feature type ‘sfRoads:::roads’ (layer 8/17)
27 Oct 10:19:21 INFO [geoserver.global] - Loading feature type ‘sfStreams:::streams’ (layer 9/17)
27 Oct 10:19:21 INFO [geoserver.global] - Loading feature type ‘shpview:::epa3’ (layer 10/17)
27 Oct 10:19:23 INFO [geoserver.global] - Loading feature type ‘shpview:::gnisnonpop_p_tx113’ (layer 11/17)
27 Oct 10:19:23 INFO [geoserver.global] - Loading feature type ‘shpview:::gnispop_p_tx113’ (layer 12/17)
27 Oct 10:19:23 INFO [geoserver.global] - Loading feature type ‘states_shapefile:::states’ (layer 13/17)
27 Oct 10:19:23 INFO [geoserver.global] - Loading feature type ‘tasmania_cities:::tasmania_cities’ (layer 14/17)
27 Oct 10:19:23 INFO [geoserver.global] - Loading feature type ‘tasmania_roads:::tasmania_roads’ (layer 15/17)
27 Oct 10:19:23 INFO [geoserver.global] - Loading feature type ‘tasmania_state_boundaries:::tasmania_state_boundaries’ (layer 16/17)
27 Oct 10:19:23 INFO [geoserver.global] - Loading feature type ‘tasmania_water_bodies:::tasmania_water_bodies’ (layer 17/17)
I have just three featureTypes loaded in GEOSERVER_DATA_DIR beyond the examples and all are using SRS 4326 out of a PostGIS Datastore.
Randy George
Micro Map & CAD
