We have a GeoServer2.1.0 with Oracle plug-in deployed on Weblogic as an application. We have created layers for the Oracle Spatial data for projection on BIng maps. We are facing performance issues with a single overlay taking around 35 seconds to render on screen. On analysis of the GeoServer log(snippet below), it is noticed that there is a gap between 2014-08-20 15:37:03,232 and 2014-08-20 15:37:07,662. Is it the database queries running for 4 seconds? We are using JDBC connection pools to connect to the Oracle database. The spatial indexes have been analysed recently. Any suggestions to tune the database or tips to improving the performance will be highly appreciated.
2014-08-20 15:37:03,216 DEBUG [org.geotools.jdbc] - 1 = POLYGON ((-608830.7182036353 354213.0151268281, -608830.7182036353 578637.1600929049, -383996.34103620437 578637.1600929049, -383996.34103620437 354213.0151268281, -608830.7182036353 354213.0151268281))
2014-08-20 15:37:03,216 DEBUG [org.geotools.rendering] - Expanding rendering area by 2 pixels to consider stroke width
2014-08-20 15:37:03,232 DEBUG [org.geotools.rendering] - Querying layer http://sw.opengeo.org/iccsa:ICC_SA_LAYER_WOA_COVERAGE with bbox: ReferencedEnvelope[-16.89697265625 : -14.04052734375, 58.80260054809615 : 60.25095233761055]
2014-08-20 15:37:03,232 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
2014-08-20 15:37:03,232 TRACE [org.geotools.core] - ENTRY 4
2014-08-20 15:37:03,232 DEBUG [org.geotools.filter] - exporting PropertyName
2014-08-20 15:37:03,232 DEBUG [org.geotools.jdbc] - SELECT ID,NAME,LOCATION as LOCATION FROM DW_GIS_STAGING.WOA_COVERAGE WHERE SDO_FILTER(LOCATION, ?, ‘mask=anyinteract querytype=WINDOW’) = ‘TRUE’
2014-08-20 15:37:03,232 DEBUG [org.geotools.data.oracle.sdo] - Using layer SRID: 27700
2014-08-20 15:37:03,232 DEBUG [org.geotools.jdbc] - Setting parameter 1 as MDSYS.SDO_GEOMETRY(2003,27700,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3),MDSYS.SDO_ORDINATE_ARRAY(-456108.5008002104,1053235.9528774032,-263904.20541160624,1245178.5366634205))
2014-08-20 15:37:03,232 DEBUG [org.geotools.jdbc] - 1 = POLYGON ((-456108.5008002104 1053235.9528774032, -456108.5008002104 1245178.5366634205, -263904.20541160624 1245178.5366634205, -263904.20541160624 1053235.9528774032, -456108.5008002104 1053235.9528774032))
2014-08-20 15:37:07,662 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
2014-08-20 15:37:07,662 DEBUG [org.geotools.rendering] - Style cache hit ratio: NaN , hits 0, requests 0
Thanks & Regards,
Samyajit Talukdar
Privileged/Confidential information may be contained in this Email and any files transmitted with it. If you are not the intended recipient you should not retain, copy or use this Email for any purpose or disclose all or part of its contents to any person. If you have received this Email in error please notify the postmaster and sender immediately and delete this Email from your system.
Opinions, conclusions and other information in this message that do not relate to the official business of Scottish Water (“SW”), Scottish Water Solutions Ltd (“SWS”) or Scottish Water Solutions 2 Ltd (“SWS2”) shall be understood as neither given nor endorsed by them. The contents of Emails sent and received by SW, SWS and SWS2 are monitored.
WARNING: Although SW, SWS and SWS2 have taken reasonable precautions to ensure no viruses or other malicious software are present, SW, SWS and SWS2 cannot accept responsibility for any loss or damage arising from the use of this Email or attachments however caused. The recipient should therefore check this Email and any attachments for the presence of viruses or other malicious software.
Scottish Water
www.scottishwater.co.uk
www.scottishwatersolutions.co.uk
postmaster@anonymised.com
