It seems that user is making a request to an area of about 225x225 km. This is based on the polygon which I took from your log snippet
POLYGON ((-456108.5008002104 1053235.9528774032<tel:9528774032>, -456108.5008002104 1245178.5366634205, -263904.20541160624 1245178.5366634205, -263904.20541160624 1053235.9528774032, -456108.5008002104 1053235.9528774032))
Funny side observation, something in the copy-paste-htmt-mail program-web formatting etc. chain or wherever has changed one coordinate into telephone number
2014-08-20 15:37:03,232 DEBUG [org.geotools.jdbc] - 1 = POLYGON ((-
If your source data has lots of small features like land parcels or buildings then there can be huge number of features inside that BBOX. However, rendering for example 100000 parcels into 800x800 pixel sized output does not make sense because no one can see them as distinct objects. What you can do immediately:
- Set scale limit for the layer and render nothing at this scale
- If you need to draw something at this scale, prepare a simplified dataset from most important features and less vertices for small scales.
-Jukka Rahkonen-
Samyajit Talukdar
I understand that GeoServer 2.1.0 is quite outdated but there is no upgrade plan
at the minute by the customer. Any suggestion would help us immensely.Thanks & Regards,
Samyajit Talukdar
________________________________________
Sent: 20 August 2014 21:41
To: Samyajit Talukdar
Subject: Re: [Geoserver-users] GeoServer2.1.0 with Oracle Spatial performance
issueGeoServer 2.1.0 was released in 2011 and is no longer in development. Can you
update to a newer version of GeoServer and run your benchmark again?Jody Garnett
On Wed, Aug 20, 2014 at 11:11 AM, Samyajit Talukdar
<Samyajit.Talukdar@anonymised.com<mailto:Samyajit.Talukdar@anonymised.com
ter.co.uk>> wrote:
We have a GeoServer2.1.0 with Oracle plug-in deployed on Weblogic as an
application. We have created layers for the Oracle Spatial data for projection on
BIng maps. We are facing performance issues with a single overlay taking
around 35 seconds to render on screen. On analysis of the GeoServer log(snippet
below), it is noticed that there is a gap between 2014-08-20 15:37:03,232 and
2014-08-20 15:37:07,662. Is it the database queries running for 4 seconds? We
are using JDBC connection pools to connect to the Oracle database. The spatial
indexes have been analysed recently. Any suggestions to tune the database or
tips to improving the performance will be highly appreciated.2014-08-20 15:37:03,216 DEBUG [org.geotools.jdbc] - 1 = POLYGON ((-
608830.7182036353 354213.0151268281, -608830.7182036353
578637.1600929049, -383996.34103620437 578637.1600929049, -
383996.34103620437 354213.0151268281, -608830.7182036353
354213.0151268281))
2014-08-20 15:37:03,216 DEBUG [org.geotools.rendering] - Expanding
rendering area by 2 pixels to consider stroke width
2014-08-20 15:37:03,232 DEBUG [org.geotools.rendering] - Querying layer
http://sw.opengeo.org/iccsa:ICC_SA_LAYER_WOA_COVERAGE with bbox:
ReferencedEnvelope[-16.89697265625 : -14.04052734375, 58.80260054809615
: 60.25095233761055]
2014-08-20 15:37:03,232 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
2014-08-20 15:37:03,232 TRACE [org.geotools.core] - ENTRY 4
2014-08-20 15:37:03,232 DEBUG [org.geotools.filter] - exporting PropertyName
2014-08-20 15:37:03,232 DEBUG [org.geotools.jdbc] - SELECT
ID,NAME,LOCATION as LOCATION FROM DW_GIS_STAGING.WOA_COVERAGE
WHERE SDO_FILTER(LOCATION, ?, 'mask=anyinteract querytype=WINDOW') =
'TRUE'
2014-08-20 15:37:03,232 DEBUG [org.geotools.data.oracle.sdo] - Using layer
SRID: 27700
2014-08-20 15:37:03,232 DEBUG [org.geotools.jdbc] - Setting parameter 1 as
MDSYS.SDO_GEOMETRY(2003,27700,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,
1003,3),MDSYS.SDO_ORDINATE_ARRAY(-
456108.5008002104,1053235.9528774032,-
263904.20541160624,1245178.5366634205))
2014-08-20 15:37:07,662 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
2014-08-20 15:37:07,662 DEBUG [org.geotools.rendering] - Style cache hit
ratio: NaN , hits 0, requests 0Thanks & Regards,
Samyajit Talukdar
Privileged/Confidential information may be contained in this Email and any files
transmitted with it. If you are not the intended recipient you should not retain,
copy or use this Email for any purpose or disclose all or part of its contents to
any person. If you have received this Email in error please notify the postmaster
and sender immediately and delete this Email from your system.Opinions, conclusions and other information in this message that do not relate
to the official business of Scottish Water ("SW"), Scottish Water Solutions Ltd
("SWS") or Scottish Water Solutions 2 Ltd ("SWS2") shall be understood as
neither given nor endorsed by them. The contents of Emails sent and received by
SW, SWS and SWS2 are monitored.WARNING: Although SW, SWS and SWS2 have taken reasonable precautions to
ensure no viruses or other malicious software are present, SW, SWS and SWS2
cannot accept responsibility for any loss or damage arising from the use of this
Email or attachments however caused. The recipient should therefore check this
Email and any attachments for the presence of viruses or other malicious
software.Scottish Water
www.scottishwater.co.uk<http://www.scottishwater.co.uk>
www.scottishwatersolutions.co.uk<http://www.scottishwatersolutions.co.uk>
postmaster@anonymised.com<mailto:postmaster@anonymised.com>------------------------------------------------------------------------------
Slashdot TV.
Video for Nerds. Stuff that matters.
http://tv.slashdot.org/
Geoserver-users mailing list
Geoserver-users@lists.sourceforge.net<mailto:Geoserver-
users@lists.sourceforge.net>
https://lists.sourceforge.net/lists/listinfo/geoserver-users------------------------------------------------------------------------------
Slashdot TV.
