[Geoserver-users] Geoserver's Service Footprint
I’m just wondering that is there any way to learn if a WMS is serving from GeoServer if the service is behind the proxy? Is there any footprint in the service to detect it is serving fro GeoServer?
Best.
A.
On Tue, May 12, 2015 at 8:28 AM, Alper Dinçer <alperd.web@anonymised.com> wrote:
I'm just wondering that is there any way to learn if a WMS is serving from
Hum... I don't think we do anything to explicitly state that the server is
a GeoServer (well, unless people forgot to customize
the contact and owner information), but you can get some clues by looking
at which output formats are supported.
If you find the crazy long list of SRS there is a good chance that's a
GeoServer too, but it can be customized.
The clues are stronger if there is a parallel WFS, since the list of filter
function GeoServer provides is rather unique
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
