[Geoserver-users] GeoServer's spatial filter preventing SQL view layer from working
I've created a function within Oracle for on-the-fly clustering that I hoped
to query via GeoServer using an SQL view layer.
The function takes as its arguments the bounding box and the number of grid
cells to use in a basic gridded clustering process (i.e. find the centre of
mass for points within each grid cell). Please note I've tried the Point
Stacker extension and it isn't adequate for my needs. Executing the
following query within Oracle gives the list of sdo_geometry objects that I
expect:
select * from table(package_name.function_name(-180, -90, 180, 90, 3);
My intention is to make WMS requests to GeoServer with the viewparams
parameter included that provides all required arguments. Because of the way
the function works the returned sdo_geometry objects will only ever be
within the provided bounding box.
I can successfully create an SQL view layer within GeoServer using this
syntax and everything seems OK while publishing. However when I access the
layer everything falls apart. GeoServer takes my query and wraps it as
follows:
SELECT GEOMETRY as GEOMETRY FROM (select * from
table(package_name.function_name(-180, -90, 180, 90, 3))) VTABLE WHERE
SDO_FILTER(GEOMETRY, ?, 'mask=anyinteract querytype=WINDOW') = 'TRUE'
Oracle then errors because the function's table return type doesn't have a
spatial index to use with SDO_FILTER. Although I did find a somewhat
similar problem on GIS.SE
<http://gis.stackexchange.com/questions/92554/can-i-create-an-oracle-spatial-view-from-a-non-spatial-table&gt;
the same solution does not apply as my function returns a table, not a
single object, and Oracle doesn't permit indexes on named table types.
As things currently stand I don't think I can make this work, and the only
thing that could potentially help is to prevent GeoServer from appending its
SDO_FILTER mask. However I'm guessing this just isn't possible without
digging into the source and creating a custom build (totally not an option).
Can anyone tell me if there's something I've missed here, or suggest a
different approach for solving the same problem? Any thoughts would be very
much appreciated.
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoServer-s-spatial-filter-preventing-SQL-view-layer-from-working-tp5237269.html
I think this is the same issue discussed in this (lengthy) thread:
http://osgeo-org.1560.x6.nabble.com/Reducing-query-data-size-in-Oracle-td5192620.html
TLDR: not possible right now, apparently requires clever development to make it work.
If there has been improvement on this front it would be great to know about it. Or would be great to have someone implement a workaround!
On Wed, Nov 18, 2015 at 12:08 PM, cheesybiscuits <thomaschristian@anonymised.com> wrote:
I’ve created a function within Oracle for on-the-fly clustering that I hoped
mass for points within each grid cell). Please note I’ve tried the Point
Stacker extension and it isn’t adequate for my needs. Executing the
expect:
follows:
SDO_FILTER(GEOMETRY, ?, ‘mask=anyinteract querytype=WINDOW’) = ‘TRUE’
Oracle then errors because the function’s table return type doesn’t have a
<http://gis.stackexchange.com/questions/92554/can-i-create-an-oracle-spatial-view-from-a-non-spatial-table>
single object, and Oracle doesn’t permit indexes on named table types.
As things currently stand I don’t think I can make this work, and the only
SDO_FILTER mask. However I’m guessing this just isn’t possible without
Can anyone tell me if there’s something I’ve missed here, or suggest a
much appreciated.
Geoserver-users mailing list
Hi Martin,
it certainly looks similar, most likely same.
No new development, still not possible, people still welcome to chip in with resources/funds:https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
On Thu, Nov 19, 2015 at 6:32 AM, Martin Davis <mtnclimb@anonymised.com> wrote:
On Wed, Nov 18, 2015 at 12:08 PM, cheesybiscuits <thomaschristian@anonymised.com.84…> wrote:
expect:
follows:
much appreciated.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Actually after some more thought I think this situation is slightly different (although the technical solution might end up being the same). Here’s the two cases as I understand them:
  1. In my original case the need was to run a query against an Oracle spatial table and return a geometry value computed from the base geometry. So the SDO_FILTER clause for the query bounding box was still required, it just needed to be run against the base geometry, not the geometry returned by the query.
  2. In the cluster case (if I understand it) no SDO_FILTER clause is required, but instead the bounding box values need to be passed to a custom Oracle function.
It seems like #1 might be simpler to implement than #2. For instance, in #1 GeoServer can still run an “empty query” to determine the geometry column(s), whereas that doesn’t seem feasible in #2.
On Wed, Nov 18, 2015 at 11:22 PM, Andrea Aime <andrea.aime@anonymised.com> wrote:
Hi Martin,
On Thu, Nov 19, 2015 at 6:32 AM, Martin Davis <mtnclimb@anonymised.com…84…> wrote:
expect:
follows:
much appreciated.
Wow, that is a long thread!
I read / skimmed through the full conversation and what I take from it is
there are numerous ways this could be done that would increase complexity,
deviate from GeoServer's UI philosophy, and consume lots of developer time,
but that Andrea's original suggestion - to not append an SDO_FILTER clause
if a spatial index doesn't exist for the geometry column - is the most
suitable. It can simply be the Oracle function / procedure writer's
responsibility to ensure their code filters output features to the queried
bbox.
Ideally GeoServer would make minx, miny, maxx, and maxy of the query
available by default (e.g. accessible in your SQL View via %%minx%%) so that
these would not have to be provided by viewparams.
There is a lot of documentation on starting GeoServer development but I have
previously been confused about how to get involved in extension development.
Any pointers for the best way to get started in this?
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoServer-s-spatial-filter-preventing-SQL-view-layer-from-working-tp5237269p5237488.html
+1 - agreed that this seems like the “simplest” way forward.
On Thu, Nov 19, 2015 at 10:08 AM, cheesybiscuits <thomaschristian@anonymised.com> wrote:
deviate from GeoServer’s UI philosophy, and consume lots of developer time,
but that Andrea’s original suggestion - to not append an SDO_FILTER clause
if a spatial index doesn’t exist for the geometry column - is the most
suitable. It can simply be the Oracle function / procedure writer’s
bbox.
