[Geoserver-users] Geoserver's zipped shapefile corrupted
For some reason I cannot download data from our Geoserver as a zipped shapefile. The file I get, is always only 397 bytes, and it cannot be opened. Any idea what has been gone wrong. Downloading worked well at least 5-6 months ago, and Geoserver version is still the same, old 2.3.1. We don’t update it, until we get a new server. Booting Geoserver does not help. Java version is Oracle 1.7.0_01 64-bit.
Any ideas? Which file is responsible for producing a zipped shape?
Oiva
On Wed, Oct 15, 2014 at 8:35 AM, Hakala Oiva (MTT) <oiva.hakala@anonymised.com>
don't update it, until we get a new server. Booting Geoserver does not
Here:
https://github.com/geoserver/geoserver/blob/master/src/wfs/src/main/java/org/geoserver/wfs/response/ShapeZipOutputFormat.java
About ideas, don't you get anything interesting in the GeoServer logs?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
probably the file is an error from geoserver in xml format. Have you tried opening the file with a text editor and see if it contains the description of the error?
Mauro
2014-10-15 8:35 GMT+02:00 Hakala Oiva (MTT) <oiva.hakala@anonymised.com383…>:
Oiva
Comprehensive Server Monitoring with Site24x7.
Monitor 10 servers for $9/Month.
Get alerted through email, SMS, voice calls or mobile push notifications.
Take corrective actions from your mobile device.
http://p.sf.net/sfu/Zoho
Geoserver-users mailing list
Mauro
Her is the content of the zip-file. Don’t understand where the “Permission denied” comes from. I was logged as an admin to Geoserver, and tried to get data from Layer preview > WFS > shapefile
Oiva
<?xml version="1.0" ?>
java.io.IOException: Permission denied
Permission denied
On Wed, Oct 15, 2014 at 10:09 AM, Hakala Oiva (MTT) <oiva.hakala@anonymised.com>
wrote:
Her is the content of the zip-file. Don't understand where the
"Permission denied" comes from. I was logged as an admin to Geoserver, and
GeoServer needs to write the shapefile on disk before it can turn it into a
zip file, the permission issue is about that file system write, which is
evidently
not allowed.
I guess either the user running GeoServer changed, and has less privileges
than before, or the file system changed somehow.
GeoServer does these writes in the java temp directory, which is different
depending on the container
used to run GeoServer, for example in the case of Tomcat it would be
$TOMCAT_HOME/temp
Ing. Andrea Aime
@geowolf
Technical Lead
Thank you Andrea and Mauro!
Maybe our system admin has changed privileges somewhere. Our Geoserver is still running under Jetty, and what would be the right folder, where Geoserver writes the shape first? I have also geoserver installed on my own computer, but I cannot find, what would be the right folder.
Oiva
GeoServer needs to write the shapefile on disk before it can turn it into a zip file, the permission issue is about that file system write, which is evidently
not allowed.
I guess either the user running GeoServer changed, and has less privileges than before, or the file system changed somehow.
GeoServer does these writes in the java temp directory, which is different depending on the container
used to run GeoServer, for example in the case of Tomcat it would be $TOMCAT_HOME/temp
Hi Oiva,
A thought – was the error message actually a file with a “.zip” extension?
If so I’d posit this seems like a bug – the error should be in a .xml for various reasons including so users don’t wonder why their .zip is “corrupt”.
Jonathan
From: Hakala Oiva (MTT) [mailto:oiva.hakala@anonymised.com]
Sent: Wednesday, October 15, 2014 11:56 AM
To: GeoServer Mailing List List
Subject: Re: [Geoserver-users] Geoserver’s zipped shapefile corrupted
Oiva
not allowed.
This message has been scanned for viruses by MailControl, a service from BlackSpider Technology
Click here to report this email as spam.
Hi Oiva,
Jonathan
Oiva
not allowed.
