Thank you Andrea, I will investigate this.
Hi Chris,
openlayers and the desktop clients are making pretty much the same OGC requests, so I don’t believe
you can tell them apart using the built-in authorization mechanism.
But the mechanism is pluggable, so you could write your own that checks the incoming requests for
hints… hard to find a solid solution, but some ideas off the top of my head (warning, only thought about it a split minute):
- Desktop clients may setup the “user agent” HTTP header in a way that can be recognized, or you
could just whitelist the user agents of most browsers (mind, you might end up blocking uncommon browsers in the process, and possibly the ones in incognito mode too)
- If the openlayers based client is written by you, you could add an extra vendor parameter to the GetMap requests, it’s normally
hard/impossible to make common desktop clients to do the same.
Both approaches are weak against someone resourceful writing his own client and spoofing the right
params/user agent values by examining your web client of course.
On Fri, Jul 29, 2016 at 5:06 PM, Chris Buckmaster <chris.buckmaster@…7473…> wrote:
Hi
I am running Geoserver version 2.5 and have an Openlayers 3 web map application which accesses some WMS and WFS services from the Geoserver instance.
At the moment I haven’t configured any authentication so it is running the default settings.
What I would like is to allow this to continue so my Openlayers application has full access to all of the layers on Geoserver, but for anyone accessing my WMS / WFS (i.e through QGIS), I would like to include a username / password or restrict the layers visible through these services.
I have had a quick look the manual trying to understand how this works but cannot seem to grasp it – I know there are authentication settings within the web interface, but would these not be for the whole of Geoserver? How am I able to allow access to my Openlayers application, but also restrict access to the WFS / WMS services for desktop users wanting to view my services?
Thanks, Chris
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
