[Geoserver-users] Geotiff image appears black on map preview
I have a raster tiff image (from ENVI) with .tfw file.
I used the gdal_translate command to translate the tiff image to geotiff, where the results are below:
The gdalinfo of my raster tiff file:
Driver: GTiff/GeoTIFF
Size is 5024, 1719
Coordinate System is:
PROJCS[“unnamed”,
GEOGCS[“unnamed”,
DATUM[“unknown”,
SPHEROID[“unretrievable - using WGS84”,6378137,298.257223563]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“0”]],
PROJECTION[“Transverse_Mercator”],
PARAMETER[“latitude_of_origin”,0],
PARAMETER[“central_meridian”,-51],
PARAMETER[“scale_factor”,0.9996],
PARAMETER[“false_easting”,500000],
PARAMETER[“false_northing”,10000000],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]]]
Origin = (444163.200000000011642,6772635.599999999627471)
Pixel Size = (0.600000000000000,-0.600000000000000)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_XRESOLUTION=100
TIFFTAG_YRESOLUTION=100
Corner Coordinates:
Upper Left ( 444163.200, 6772635.600) ( 51d34’27.23"W, 29d10’25.24"S)
Lower Left ( 444163.200, 6771604.200) ( 51d34’27.42"W, 29d10’58.76"S)
Upper Right ( 447177.600, 6772635.600) ( 51d32’35.63"W, 29d10’25.71"S)
Lower Right ( 447177.600, 6771604.200) ( 51d32’35.81"W, 29d10’59.22"S)
Center ( 445670.400, 6772119.900) ( 51d33’31.52"W, 29d10’42.24"S)
Band 1 Block=5024x1 Type=UInt16, ColorInterp=Red
Band 2 Block=5024x1 Type=UInt16, ColorInterp=Green
Band 3 Block=5024x1 Type=UInt16, ColorInterp=Blue
The gdalinfo of my geotiff file:
Size is 5024, 1719
PROJCS[“SAD69 / UTM zone 22S”,
GEOGCS[“SAD69”,
DATUM[“South_American_Datum_1969”,
SPHEROID[“GRS 1967 (SAD69)”,6378160,298.2500000000049,
AUTHORITY[“EPSG”,“7050”]],
AUTHORITY[“EPSG”,“6618”]],
AUTHORITY[“EPSG”,“4618”]],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]],
AUTHORITY[“EPSG”,“29192”]]
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
COMPRESSION=LZW
Corner Coordinates:
Upper Left ( 444163.200, 6772635.600) ( 51d34’27.22"W, 29d10’24.88"S)
Lower Left ( 444163.200, 6771604.200) ( 51d34’27.41"W, 29d10’58.39"S)
Upper Right ( 447177.600, 6772635.600) ( 51d32’35.63"W, 29d10’25.35"S)
Lower Right ( 447177.600, 6771604.200) ( 51d32’35.80"W, 29d10’58.86"S)
Center ( 445670.400, 6772119.900) ( 51d33’31.51"W, 29d10’41.87"S)
Band 1 Block=256x256 Type=UInt16, ColorInterp=Gray
Band 2 Block=256x256 Type=UInt16, ColorInterp=Undefined
Band 3 Block=256x256 Type=UInt16, ColorInterp=Undefined
I created a new coverage store, with the option “Tagged Image File Format with Geographic Information” and style “raster”. But on map preview the image seems have a some problem, because it appears all black.
Tanks,
Claudiomir G. Zanchetti (Caio)
Sun Certified Programmer for Java SE 5.0 - SUN272515
Ciao Claudio,
the fact that your geotiff is "black" does not represent a problem per-se.
I suspect that your initial image has a dynamic which is very
compressed towards 0 hence, after the conversion the image looks very
dark.
Do you see any error in the errors in the log? Can you make the image
available for testing?
Simone.
Ing. Simone Giannecchini
Owner - Software Engineer
Via Carignoni 51
55041 Camaiore (LU)
phone: +39 0584983027
fax: +39 0584983027
mob: +39 333 8128928
http://simboss.blogspot.com/
http://www.linkedin.com/in/simonegiannecchini
On Mon, Jan 12, 2009 at 3:16 AM, Claudiomir Zanchetti (Caio)
<caio.zanchetti@anonymised.com> wrote:
Size is 5024, 1719
PROJCS["unnamed",
    GEOGCS["unnamed",
        DATUM["unknown",
            SPHEROID["unretrievable - using WGS84",6378137,298.257223563]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","0"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",0],
    PARAMETER["central_meridian",-51],
    PARAMETER["scale_factor",0.9996],
    PARAMETER["false_easting",500000],
    PARAMETER["false_northing",10000000],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]]]
Metadata:
  AREA_OR_POINT=Area
Corner Coordinates:
Upper Left ( 444163.200, 6772635.600) ( 51d34'27.23"W, 29d10'25.24"S)
Lower Left ( 444163.200, 6771604.200) ( 51d34'27.42"W, 29d10'58.76"S)
Upper Right ( 447177.600, 6772635.600) ( 51d32'35.63"W, 29d10'25.71"S)
Lower Right ( 447177.600, 6771604.200) ( 51d32'35.81"W, 29d10'59.22"S)
Center ( 445670.400, 6772119.900) ( 51d33'31.52"W, 29d10'42.24"S)
Size is 5024, 1719
PROJCS["SAD69 / UTM zone 22S",
    GEOGCS["SAD69",
        DATUM["South_American_Datum_1969",
            SPHEROID["GRS 1967 (SAD69)",6378160,298.2500000000049,
                AUTHORITY["EPSG","7050"]],
            AUTHORITY["EPSG","6618"]],
        AUTHORITY["EPSG","4618"]],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","29192"]]
Metadata:
  AREA_OR_POINT=Area
  COMPRESSION=LZW
Corner Coordinates:
Upper Left ( 444163.200, 6772635.600) ( 51d34'27.22"W, 29d10'24.88"S)
Lower Left ( 444163.200, 6771604.200) ( 51d34'27.41"W, 29d10'58.39"S)
Upper Right ( 447177.600, 6772635.600) ( 51d32'35.63"W, 29d10'25.35"S)
Lower Right ( 447177.600, 6771604.200) ( 51d32'35.80"W, 29d10'58.86"S)
Center ( 445670.400, 6772119.900) ( 51d33'31.51"W, 29d10'41.87"S)
I created a new coverage store, with the option "Tagged Image File Format
with Geographic Information" and style "raster". But on map preview the
Tanks,
Check out the new SourceForge.net Marketplace.
It is the best place to buy or sell services for
just about anything Open Source.
http://p.sf.net/sfu/Xq1LFB
Geoserver-users mailing list
