On 08 Jun 2015, at 16:20, Daniele Romagnoli <daniele.romagnoli@anonymised.com> wrote:
Hi Tore,
do you have any chance to open a JIRA with a sample file reporting the issue?
I think it should preserve the NoData value so we need to investigate on this.
When configuring the layer, do you see any value in the Null Values column of the coverage band details of your dataset?
Please, let us know.
Daniele
On Mon, Jun 8, 2015 at 3:25 PM, Tore Halset <halset@anonymised.com> wrote:
Hello.
I have some of GeoTIFFs with NODATA values. I add the directory as a ImageMosaic store to GeoServer. It works very well except that the GeoTIFFs I download from WCS does not have a NODATA value set. At least not visible from gdalinfo. I have tried with 2.7.1 and the nightly build from master as of today.
gdalinfo on one of the original GeoTIFF. They all share the same NODATA value.
Band 1 Block=7911x1 Type=Float32, ColorInterp=Gray
NoData Value=1000000
Band 2 Block=7911x1 Type=Float32, ColorInterp=Undefined
gdalinfo on a GeoTIFF fetched with GetCoverage on the ImageMosaic store.
Band 1 Block=16x16 Type=Float32, ColorInterp=Gray
Band 2 Block=16x16 Type=Float32, ColorInterp=Alpha
Any tips on how to fix this?
Tore Halset.
Geoserver-users mailing list
Ing. Daniele Romagnoli
Senior Software Engineer
Via Poggio alle Viti 1187
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
