After importing a geotiff in a data store (no errors), then going to
preview layer using open layers, I see nothing but a large gray
polygon. Is there anything I can do to help troubleshoot this? I can
view the tiff in graphics editing/viewing problems. It's a 2GB file,
not sure if that's relevant or not.
On Thu, Sep 17, 2015 at 12:28 AM, Alex O'Ree <spyhunter99@anonymised.com> wrote:
Polygon as in .... vector polygon? Did you associate the polygon
style instead of the raster one by any chance?
If not, can you run gdalinfo against that file, and provide the geoserver
version you're using?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Thanks for the quick response and sorry for not getting back sooner.
Polygon as in a large gray square. I can zoom in and out, just no map.
It's all gray.
It was imported as the raster layer.
Below is the output from gdalinfo
C:\Program Files\GDAL>gdalinfo c:\maps\geoserver-2.7.2\data_dir\alaska.tiff
ERROR 1: Can't load requested DLL: C:\Program
Files\GDAL\gdalplugins\gdal_MrSID.dll
126: The specified module could not be found.
Driver: GTiff/GeoTIFF
Files: c:\maps\geoserver-2.7.2\data_dir\alaska.tiff
Size is 29184, 18432
Coordinate System is `'
GCP Projection =
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433],
AUTHORITY["EPSG","4326"]]
GCP[ 0]: Id=1, Info=
(0,0) -> (-116.680203045685,34.7986191024166,0)
GCP[ 1]: Id=2, Info=
(29184,0) -> (-111.472081218274,34.7986191024166,0)
GCP[ 2]: Id=3, Info=
(0,18432) -> (-116.680203045685,32.313003452244,0)
GCP[ 3]: Id=4, Info=
(29184,18432) -> (-111.472081218274,32.313003452244,0)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_DATETIME=2015:09:16 17:47:52
TIFFTAG_IMAGEDESCRIPTION=com.partech.geoio.rpf.BoundaryRectangle@anonymised.com0...
TIFFTAG_RESOLUTIONUNIT=3 (pixels/cm)
TIFFTAG_SOFTWARE=GV
TIFFTAG_XRESOLUTION=1
TIFFTAG_YRESOLUTION=1
Image Structure Metadata:
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0,18432.0)
Upper Right (29184.0, 0.0)
Lower Right (29184.0,18432.0)
Center (14592.0, 9216.0)
Band 1 Block=128x128 Type=Byte, ColorInterp=Red
Mask Flags: PER_DATASET ALPHA
Band 2 Block=128x128 Type=Byte, ColorInterp=Green
Band 3 Block=128x128 Type=Byte, ColorInterp=Blue
Band 4 Block=128x128 Type=Byte, ColorInterp=Alpha
On Wed, Sep 16, 2015 at 6:46 PM, Andrea Aime
not sure if that's relevant or not.Polygon as in .... vector polygon? Did you associate the polygon
version you're using?Cheers
Andrea--
http://goo.gl/it488V for more information.Ing. Andrea Aime
@geowolf
Technical LeadGeoSolutions S.A.S.
mob: +39 339 8844549http://www.geo-solutions.it
http://twitter.com/geosolutions_itAVVERTENZE AI SENSI DEL D.Lgs. 196/2003
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i
file/s allegato/i sono da considerarsi strettamente riservate. Il loro
utilizzo è consentito esclusivamente al destinatario del messaggio, per le
finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio
senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia
via e-mail e di procedere alla distruzione del messaggio stesso,
cancellandolo dal Vostro sistema. Conservare il messaggio stesso, divulgarlo
anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per
finalità diverse, costituisce comportamento contrario ai principi dettati
dal D.Lgs. 196/2003.The information in this message and/or attachments, is intended solely for
information in this message that has been received in error. The sender does
e-mail transmission, viruses, etc.-------------------------------------------------------
On Fri, Sep 18, 2015 at 1:29 AM, Alex O'Ree <spyhunter99@anonymised.com> wrote:
It's all gray.It was imported as the raster layer.
Switch to the publishing tab in the layer editor, and check the default
style: is it raster,
or polygon?
Ing. Andrea Aime
@geowolf
Technical Lead
Try changing the style classes to better cover the actual data range.
Often with rasters if you don't stretch min/mix you end up with just
gray as the few outlying values get assigned white and black (NoData as
something like -9999 can cause this.
-Alex
On 09/17/2015 04:29 PM, Alex O'Ree wrote:
126: The specified module could not be found.ERROR 1: Can't load requested DLL: C:\Program
126: The specified module could not be found.Driver: GTiff/GeoTIFF
GCP Projection =
GEOGCS["WGS 84",
DATUM["WGS_1984",
Metadata:
AREA_OR_POINT=Area
TIFFTAG_SOFTWARE=GV
INTERLEAVE=PIXEL
Corner Coordinates:
Band 4 Block=128x128 Type=Byte, ColorInterp=AlphaOn Wed, Sep 16, 2015 at 6:46 PM, Andrea Aime
<andrea.aime@anonymised.com> wrote:On Thu, Sep 17, 2015 at 12:28 AM, Alex O'Ree <spyhunter99@anonymised.com> wrote:
Andrea--
@geowolf
Monitor Your Dynamic Infrastructure at Any Scale With Datadog!
Get real-time metrics from all of your servers, apps and tools
in one place.
SourceForge users - Click here to start your Free Trial of Datadog now!
http://pubads.g.doubleclick.net/gampad/clk?id=241902991&iu=/4140
Geoserver-users mailing list
ill give it a shot, first thing tomorrow
something like -9999 can cause this.-Alex
GCP Projection =
GEOGCS["WGS 84",
DATUM["WGS_1984",
Metadata:
AREA_OR_POINT=Area
TIFFTAG_IMAGEDESCRIPTION=com.partech.geoio.rpf.BoundaryRectangle@anonymised.com7250...
TIFFTAG_SOFTWARE=GV
INTERLEAVE=PIXEL
Corner Coordinates:
Andrea--
@geowolf
in one place.
It is set to raster style.
Often with rasters if you don’t stretch min/mix you end up with just
On 09/17/2015 04:29 PM, Alex O’Ree wrote:
It’s all gray.It was imported as the raster layer.
ERROR 1: Can’t load requested DLL: C:\Program
126: The specified module could not be found.ERROR 1: Can’t load requested DLL: C:\Program
Coordinate System is `’
GCP Projection =
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
SPHEROID[“WGS 84”,6378137,298.257223563,
AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4326”]]
(0,0) → (-116.680203045685,34.7986191024166,0)
(29184,0) → (-111.472081218274,34.7986191024166,0)
(0,18432) → (-116.680203045685,32.313003452244,0)
(29184,18432) → (-111.472081218274,32.313003452244,0)
Metadata:
AREA_OR_POINT=Area
TIFFTAG_SOFTWARE=GV
INTERLEAVE=PIXEL
Corner Coordinates:
<andrea.aime@anonymised.com…> wrote:On Thu, Sep 17, 2015 at 12:28 AM, Alex O’Ree <spyhunter99@anonymised.com> wrote:
view the tiff in graphics editing/viewing problems. It’s a 2GB file,
not sure if that’s relevant or not.Polygon as in … vector polygon? Did you associate the polygon
version you’re using?Cheers
Andrea–
@geowolf
(Legislative Decree June, 30 2003, no.196 - Italy’s New Data Protection
in one place.
If I go to layer preview, then tiff from the drop down, I do get a image of the map back. It only appears that open layers has an issue
GCP Projection =
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
Metadata:
AREA_OR_POINT=Area
TIFFTAG_SOFTWARE=GV
INTERLEAVE=PIXEL
Corner Coordinates:
<andrea.aime@anonymised.com> wrote:On Thu, Sep 17, 2015 at 12:28 AM, Alex O’Ree <spyhunter99@anonymised.com> wrote:
Andrea–
@geowolf
in one place.
can geoserver import nitf file formats?
GCP Projection =
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
Metadata:
AREA_OR_POINT=Area
TIFFTAG_SOFTWARE=GV
INTERLEAVE=PIXEL
Corner Coordinates:
Andrea–
@geowolf
in one place.
On Fri, Sep 18, 2015 at 3:21 PM, Alex O'Ree <spyhunter99@anonymised.com> wrote:
Waaait a second, I think I see it now, that geotiff has per overview inner
raster masks. Those are supported only in GeoServer > 2.8.0, which are
are about to release, you should give 2.8-RC1 a try
Ing. Andrea Aime
@geowolf
Technical Lead
One more update. I was able to get some data to import by cropping the geo tiff. Now the problem is that it’s rendering mirrored and inverted (open layers). Any idea?
GCP Projection =
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
Metadata:
AREA_OR_POINT=Area
TIFFTAG_SOFTWARE=GV
INTERLEAVE=PIXEL
Corner Coordinates:
Andrea–
@geowolf
in one place.
On Fri, Sep 18, 2015 at 4:53 PM, Alex O'Ree <spyhunter99@anonymised.com> wrote:
tiff. Now the problem is that it's rendering mirrored and inverted (open
layers). Any idea?
Adding to the weirdness of that geotiff, it's not ortorectified apparently,
but uses ground control points instead.
Use gdalwarp/gdaltranslate to fix it
Ing. Andrea Aime
@geowolf
Technical Lead
Progress! Looks like the release version did work, but the scale is way off, inverted and upside down. Same behavior with both versions
GCP Projection =
GEOGCS[“WGS 84”,
DATUM[“WGS_1984”,
Metadata:
AREA_OR_POINT=Area
TIFFTAG_SOFTWARE=GV
INTERLEAVE=PIXEL
Corner Coordinates:
Andrea–
@geowolf
in one place.
Any idea what options I need for gdal?
On Fri, Sep 18, 2015 at 4:53 PM, Alex O’Ree <spyhunter99@anonymised.com> wrote:
Adding to the weirdness of that geotiff, it’s not ortorectified apparently, but uses ground control points instead.
Ing. Andrea Aime
@geowolf
Technical Lead
Success! I just ran gdalwarp input.tiff output.tiff then imported the output file. woohoo! Thanks for your help!
On Fri, Sep 18, 2015 at 4:53 PM, Alex O’Ree <spyhunter99@anonymised.com…> wrote:
Ing. Andrea Aime
@geowolf
Technical Lead
