[Geoserver-users] GeoTIFFs verus JP2
Hi List,
We’ve recently taken deliver of some aerial photography.
As lossless GeoTIFFs, the RedGreenBlue data is 278GB
As a compressed JP2 file the data is 26GB - the JP2 is almost as good as the GeoTIFFs and comes with pyramids built in.
But for speed purposes with GeoServer I’ve created an imageMosaic of 13 Jpeg compressed GeoTIFFs with overviews/tiles etc. This comes out at a massive 106GB and the quality is worse than the JP2 file despite being four times the size.
Can anyone advise how I can improve these files to make them smaller (ideally with better quality too)? I created each of the GeoTIFFs with the following two commands
Merge, tile, and compress all at once.
gdal_merge -q -o file_name.tif -of GTiff -co TILED=YES -co BIGTIFF=YES -co COMPRESS=JPEG -co JPEG_QUALITY=50 -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 --optfile tiff_list.txt
Pyramids
gdaladdo -r average %THIS_DIR%.tif 2 4 8 16 32 64 128 256
Using JP2 with GDAL is tempting (though supposedly much slower) - but we’re likely to be putting up four band (RGB + Infrared) data, which I think we can use GeoServer to visualise (still to play with). JP2 can’t handle four bands.
Am I doing something wrong with the GeoTIFF creation?
Thoughts welcome.
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
On Tue, Nov 12, 2013 at 9:27 AM, Jonathan Moules <
jonathanmoules@anonymised.com> wrote:
Hi List,
We've recently taken deliver of some aerial photography.
As lossless GeoTIFFs, the RedGreenBlue data is *278GB*
As a compressed JP2 file the data is *26GB* - the JP2 is almost as good
But for speed purposes with GeoServer I've created an imageMosaic of 13
massive *106GB* and the quality is worse than the JP2 file despite being
Try something like this instead:
gdal_translate out.tiff in.tiff -co TILED=YES -co blockxsize=512 -co
blockysize=512 -co COMPRESS=JPEG -co JPEG_QUALITY=85 -co PHOTOMETRIC=YCBCR
gdaladdo out.tiff -r average --config COMPRESS_OVERVIEW JPEG --config
JPEG_QUALITY_OVERVIEW 85 --config INTERLEAVE_OVERVIEW PIXEL --config
PHOTOMETRIC_OVERVIEW YCBCR 2 4 8 16 32
Should give you much better quality, and still, a relatively low size (not
as small as JP2, but faster)
Cheres
Our support, Your Success! Visit http://opensdi.geo-solutions.it for more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Ciao Jonathan,
please read my comments inline below...
Simone Giannecchini
more information.
Ing. Simone Giannecchini
@simogeo
Founder/Director
mob: +39 333 8128928
<jonathanmoules@anonymised.com> wrote:
Hi List,
Unless you have an ECW or Kakadu license JP2 reading won't be as fast
as GeoTiff, I mean, nowhere near to it :slight_smile:
But for speed purposes with GeoServer I've created an imageMosaic of 13 Jpeg
the size.
I believe quality is too low. This makes the files smaller but also
makes the jpeg artifacts quite visibile. I would go with the default
which is 75%.
Moreover, you should use this switch PHOTOMETRIC= YCBCR to improve
JPEG compression.
Pyramids
This is correct but could be done better. Since the base level is
compressed I would compress overviews as well.
gdaladdo -r cubic -config COMPRESS_OVERVIEW JPEG --config
PHOTOMETRIC_OVERVIEW YCBCR %THIS_DIR%.tif 2 4 8 16 32 64 128 256
This should provide more quality but also relatively small size.
Using JP2 with GDAL is tempting (though supposedly much slower) - but we're
can use GeoServer to visualise (still to play with). JP2 can't handle four
bands.
Ehm, I am playing with 4 bands JP2 just these days, hence I am not so
sure this is true (which means I believe it is not :slight_smile: )
I am doing some work to improve performance + quality of 16 bits 4
bands imagery, if you move on along the JP2 lines I could make good
use of a sample.
Thoughts welcome.
Jonathan
November Webinars for C, C++, Fortran Developers
Accelerate application performance with scalable programming models. Explore
techniques for threading, error checking, porting, and tuning. Get the most
from the latest Intel processors and coprocessors. See abstracts and
register
http://pubads.g.doubleclick.net/gampad/clk?id=60136231&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Hi Both,
Thanks for the quick and helpful replies. I’ll do some experimentation with these things. And there I was thinking I’d figured out GDAL. :slight_smile: You might want to put some of this stuff in your “GeoServer on Steroids” presentation.
I’d thought that overviews were compressed - useful to know they’re not; that’ll be a saving of a couple of GB.
I could have sworn someone told me JP2 couldn’t do four bands. Hmmm. For now I’ll stick with GeoTIFFs - I don’t have any 4 band JP2’s and our vendor wasn’t able to create them (nor can FME), so I can’t provide a sample I’m afraid.
Will the PHOTOMETRIC= YCBCR work with a four band RGBI?
The GDALINFO for a source Geotiff is:
Driver: GTiff/GeoTIFF
Files: SP4044.tif
SP4044.tfw
Size is 8000, 8000
Coordinate System is:
PROJCS[“OSGB 1936 / British National Grid”,
GEOGCS[“OSGB 1936”,
DATUM[“OSGB_1936”,
SPHEROID[“Airy 1830”,6377563.396,299.3249753150316,
AUTHORITY[“EPSG”,“7001”]],
AUTHORITY[“EPSG”,“6277”]],
PRIMEM[“Greenwich”,0],
UNIT[“degree”,0.0174532925199433],
AUTHORITY[“EPSG”,“4277”]],
PROJECTION[“Transverse_Mercator”],
PARAMETER[“latitude_of_origin”,49],
PARAMETER[“central_meridian”,-2],
PARAMETER[“scale_factor”,0.9996012717],
PARAMETER[“false_easting”,400000],
PARAMETER[“false_northing”,-100000],
UNIT[“metre”,1,
AUTHORITY[“EPSG”,“9001”]],
AUTHORITY[“EPSG”,“27700”]]
Origin = (440000.000000000000000,245000.000000000000000)
Pixel Size = (0.125000000000000,-0.125000000000000)
Metadata:
TIFFTAG_XRESOLUTION=72
TIFFTAG_YRESOLUTION=72
TIFFTAG_RESOLUTIONUNIT=2 (pixels/inch)
AREA_OR_POINT=Area
Image Structure Metadata:
COMPRESSION=LZW
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 440000.000, 245000.000) ( 1d24’57.45"W, 52d 6’5.31"N)
Lower Left ( 440000.000, 244000.000) ( 1d24’57.87"W, 52d 5’32.94"N)
Upper Right ( 441000.000, 245000.000) ( 1d24’4.89"W, 52d 6’5.04"N)
Lower Right ( 441000.000, 244000.000) ( 1d24’5.32"W, 52d 5’32.68"N)
Center ( 440500.000, 244500.000) ( 1d24’31.39"W, 52d 5’48.99"N)
Band 1 Block=8000x32 Type=Byte, ColorInterp=Red
Band 2 Block=8000x32 Type=Byte, ColorInterp=Green
Band 3 Block=8000x32 Type=Byte, ColorInterp=Blue
Band 4 Block=8000x32 Type=Byte, ColorInterp=Undefined
On 12 November 2013 08:50, Simone Giannecchini <simone.giannecchini@anonymised.com> wrote:
Ciao Jonathan,
please read my comments inline below…
Simone Giannecchini
more information.
@simogeo
Founder/Director
Hi List,
Unless you have an ECW or Kakadu license JP2 reading won’t be as fast
the size.
–optfile tiff_list.txt
which is 75%.
JPEG compression.
Pyramids
bands.
use of a sample.
Thoughts welcome.
Jonathan
register
Thanks again,
Jonathan
Ciao Jonathan,
please, read below...
Simone Giannecchini
more information.
@simogeo
Founder/Director
On Tue, Nov 12, 2013 at 10:20 AM, Jonathan Moules
Hi Both,
Thanks for the quick and helpful replies. I'll do some experimentation with
these things. And there I was thinking I'd figured out GDAL. :slight_smile: You might
want to put some of this stuff in your "GeoServer on Steroids" presentation.
actually that is a good idea, we have some more things coming down the pipe
I'd thought that overviews were compressed - useful to know they're not;
that'll be a saving of a couple of GB.
that's true on very large imagery
I could have sworn someone told me JP2 couldn't do four bands. Hmmm. For now
I'll stick with GeoTIFFs - I don't have any 4 band JP2's and our vendor
wasn't able to create them (nor can FME), so I can't provide a sample I'm
afraid.
It should not.
Files: SP4044.tif
       SP4044.tfw
Size is 8000, 8000
PROJCS["OSGB 1936 / British National Grid",
    GEOGCS["OSGB 1936",
        DATUM["OSGB_1936",
            SPHEROID["Airy 1830",6377563.396,299.3249753150316,
                AUTHORITY["EPSG","7001"]],
            AUTHORITY["EPSG","6277"]],
        PRIMEM["Greenwich",0],
        UNIT["degree",0.0174532925199433],
        AUTHORITY["EPSG","4277"]],
    PROJECTION["Transverse_Mercator"],
    PARAMETER["latitude_of_origin",49],
    PARAMETER["central_meridian",-2],
    PARAMETER["scale_factor",0.9996012717],
    PARAMETER["false_easting",400000],
    PARAMETER["false_northing",-100000],
    UNIT["metre",1,
        AUTHORITY["EPSG","9001"]],
    AUTHORITY["EPSG","27700"]]
Metadata:
  AREA_OR_POINT=Area
  COMPRESSION=LZW
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 440000.000, 245000.000) ( 1d24'57.45"W, 52d 6'5.31"N)
Lower Left ( 440000.000, 244000.000) ( 1d24'57.87"W, 52d 5'32.94"N)
Upper Right ( 441000.000, 245000.000) ( 1d24'4.89"W, 52d 6'5.04"N)
Lower Right ( 441000.000, 244000.000) ( 1d24'5.32"W, 52d 5'32.68"N)
Center ( 440500.000, 244500.000) ( 1d24'31.39"W, 52d 5'48.99"N)
Thanks again,
Jonathan
Ciao Jonathan,
Simone Giannecchini
more information.
@simogeo
Founder/Director
> Hi List,
> the
> Jpeg
> massive
> times
> the size.
> the
>> -co
which is 75%.
JPEG compression.
> Pyramids
> we're
> we
> four
> bands.
use of a sample.
> Thoughts welcome.
> Thanks,
> Jonathan
> or
> error
> us,
> recording
> Explore
> most
> register
> Geoserver-users@lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/geoserver-users
On Tue, Nov 12, 2013 at 12:45 PM, Simone Giannecchini <
It should not.
Actually... JPEG itself is not defined on 4 bands images as far as I know?
Maybe GDAL is dropping the 4th band during the JPEG compression?
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Selon Andrea Aime <andrea.aime@anonymised.com>:
> It should not.
The YCbCR JPEG profile of TIFF is indeed limited to 3 bands. So if you pass a 4
band image, gdal_translate should refuse to process it.
You can JPEG compress a 4 band image, but it will use a JPEG codestream for each
band independantly, so the resulting size will be bigger.
A possible option would be to generate 2 GeoTIFFs for each input file : one
YCbCR JPEG compressed with the RGB components, and one JPEG compressed with the
I component. But that might complicate the overall workflow.
Even
information.
Ing. Andrea Aime
@geowolf
Technical Lead
x.com
HI All,
Many thanks for the all the responses. Interesting discussion; I’ve learnt a lot.
I think my next step is to do some testing; I’ve not tried the four band - RGBI imagery yet. When I do I’ll post back here with whatever seems to work best.
Jonathan
On 12 November 2013 13:45, Even Rouault <even.rouault@anonymised.com4…> wrote:
It should not.
Actually… JPEG itself is not defined on 4 bands images as far as I know?
Even
information.
Ing. Andrea Aime
@geowolf
Technical Lead
from the latest Intel processors and coprocessors. See abstracts and register
Hi List,
One thing I’m noticing with PHOTOMETRIC=YCBCR - I’m losing a lot of sharpness.
In fact, a 50% without YCBCR looks better than a 85% that also has YCBCR enabled.
This is very noticeable at the native resolution, but once you’re about double it or further, it’s effectively invisible.
On the other hand, the YCBCR is about 25% the size of a equivalently compressed JPEG. I guess I’m going to have to choose which way to go.
On 12 November 2013 14:24, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
HI All,
Jonathan
It should not.
Even
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Le mercredi 20 novembre 2013 18:21:06, Jonathan Moules a écrit :
Hi List,
One thing I'm noticing with PHOTOMETRIC=YCBCR - I'm losing a lot of
sharpness.
enabled.
This is very noticeable at the native resolution, but once you're about
double it or further, it's effectively invisible.
YCbCr comes with a oversampling by a factor of 2 of the Cb and Cr channels,
hence the extra compression and quality loss. Although than this oversampling
is done because the human eye is less sensible to chromatic than luminance.
a equivalently compressed JPEG. I guess I'm going to have to choose which
way to go.
I've also been testing a lot of other variables and for some reason DEFLATE
compression seems to make the file *larger* in all circumstances. It
doesn't matter what the Z level is (even 9), or "predictor", in all
instances the resultant file is larger than an uncompressed version. That's
with four band data.
Anyone know why?
It is not completely surprising. If there are no repeateable patterns in the
uncompressed stream, deflate can result in (a bit) larger files. You might want
to try with -co INTERLEAVE=BAND added to see if it improves things. But
generally DEFLATE is not appropriate for aerial imagery.
Jonathan
> HI All,
> Many thanks for the all the responses. Interesting discussion; I've
> learnt a lot.
> I think my next step is to do some testing; I've not tried the four band
> - RGBI imagery yet. When I do I'll post back here with whatever seems to
> work best.
> Cheers,
> Jonathan
>> > > It should not.
>> know?
>> pass a 4
>> for each
>> one
>> with the
>> Even
>> > Cheers
>> > Andrea
>> more
>> > information.
>> > Ing. Andrea Aime
>> > @geowolf
>> > Technical Lead
>> > GeoSolutions S.A.S.
>> > Italy
>> > x.com
>> ------ November Webinars for C, C++, Fortran Developers
>> Explore
>> most
>> register
>> trk _______________________________________________
Geospatial professional services
http://even.rouault.free.fr/services.html
Ciao a tutti,
addign a bit to this, I would not use band interleaving as we have seen bad performance in the past wrt pixel interleaving.
Simone.
Hi List,
sharpness.
enabled.
way to go.
I’ve also been testing a lot of other variables and for some reason DEFLATE
compression seems to make the file larger in all circumstances. It
doesn’t matter what the Z level is (even 9), or “predictor”, in all
instances the resultant file is larger than an uncompressed version. That’s
Anyone know why?
Jonathan
HI All,
learnt a lot.
  • RGBI imagery yet. When I do I’ll post back here with whatever seems to
    work best.
Jonathan
paris.org>wrote:
Selon Andrea Aime <andrea.aime@anonymised.com07…>:
It should not.
know?
pass a 4
for each
one
with the
Even
more
information.
Ing. Andrea Aime
@geowolf
Technical Lead
Explore
most
register
Geoserver-users@anonymised.comurceforge.net
Shape the Mobile Experience: Free Subscription
Software experts and developers: Be at the forefront of tech innovation.
Intel(R) Software Adrenaline delivers strategic insight and game-changing
conversations that shape the rapidly evolving mobile landscape. Sign up now.
http://pubads.g.doubleclick.net/gampad/clk?id=63431311&iu=/4140/ostg.clktrk
Simone Giannecchini
@simogeo
Founder/Director
gdal_merge -q -o rgbi.tif -of GTiff -co TILED=YES -co BIGTIFF=YES -co COMPRESS=JPEG -co JPEG_QUALITY=25 -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 --optfile tiff_list.txt
The “bit” larger files are typically about double the size of the uncompressed one!
I know deflate isn’t as well suited, but I’m experimenting with a whole bunch of different settings to see what sticks.
I’m now trying to get the four band into GeoServer (regular GeoTIFF), but it’s not having it. I’ve created it the same way as the 3 band:
(low compression for testing). No pyramids yet.
The first thing I notice is that the 4 band is smaller (118MB) than the 3 band (164MB).
The gdalinfo for the four band:
Files: rgbi.tif
Size is 8000, 24000
[brevity removed]
Origin = (419000.000000000000000,240000.000000000000000)
Metadata:
AREA_OR_POINT=Area
COMPRESSION=JPEG
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 419000.000, 240000.000) ( 1d43’22.27"W, 52d 3’27.49"N)
Lower Left ( 419000.000, 237000.000) ( 1d43’22.87"W, 52d 1’50.38"N)
Upper Right ( 420000.000, 240000.000) ( 1d42’29.76"W, 52d 3’27.37"N)
Lower Right ( 420000.000, 237000.000) ( 1d42’30.39"W, 52d 1’50.26"N)
Center ( 419500.000, 238500.000) ( 1d42’56.32"W, 52d 2’38.88"N)
Band 1 Block=512x512 Type=Byte, ColorInterp=Red
Mask Flags: PER_DATASET ALPHA
Band 2 Block=512x512 Type=Byte, ColorInterp=Green
Band 3 Block=512x512 Type=Byte, ColorInterp=Blue
Band 4 Block=512x512 Type=Byte, ColorInterp=Alpha
The GeoServer logs contain an error (WMS GetMap request):
2013-11-20 17:56:07,498 ERROR [org.geoserver.ows] -
java.lang.RuntimeException: javax.imageio.IIOException: Unsupported Image Type
at com.sun.media.jai.imageioimpl.ImageReadOpImage.computeTile(ImageReadOpImage.java:706)
at com.sun.media.jai.util.SunTileScheduler.scheduleTile(SunTileScheduler.java:904)
at javax.media.jai.OpImage.getTile(OpImage.java:1129)
Caused by: javax.imageio.IIOException: Unsupported Image Type
at com.sun.imageio.plugins.jpeg.JPEGImageReader.readInternal(Unknown Source)
at com.sun.imageio.plugins.jpeg.JPEGImageReader.read(Unknown Source)
at it.geosolutions.imageioimpl.plugins.tiff.TIFFJPEGDecompressor.decodeRaw(TIFFJPEGDecompressor.java:278)
Ideally I’m looking to have one source file which can be symbolised as not just RGB, but also as any number of false-colour possibilities.
Any suggestions anyone? I’m stumbling into new (for me) territory here.
Jonathan
I would try if it makes difference to save result from gdal_merge first into uncompressed tiff and compress it with deflate in a separate run.
Jukka Rahkonen
Files: rgbi.tif
Size is 8000, 24000
[brevity removed]
Metadata:
AREA_OR_POINT=Area
COMPRESSION=JPEG
INTERLEAVE=PIXEL
Corner Coordinates:
Jonathan
Yep, that worked. Although that’s unfeasible for the full dataset; I don’t have enough diskspace for an uncompressed version.
Also, doing that (deflate, level 9), the tiled version was about 15% smaller than the untiled version.
Thanks!
Jonathan
Jukka Rahkonen
Files: rgbi.tif
Size is 8000, 24000
[brevity removed]
Metadata:
AREA_OR_POINT=Area
COMPRESSION=JPEG
INTERLEAVE=PIXEL
Corner Coordinates:
Jonathan
I think that the reason is that is is hard/impossible to make an optimal deflate compressed tiff when gdal_merge goes through the circle "open file - add data - close file". There are other alternatives to test:
- You can use a non-optimal deflate compressed tiff as a temporary file - is is lossless and the final result will be identical.
- Use gdalbuildvrt for making an interim .VRT file and convert that to final product instead of using gdal_merge.py. Perhaps GDAL can make an optimal deflate compressed image from the VRT file with one run.
A hint: If you play with big datasets and deflate compressed images GDAL sometimes does not guess when it should jump into BigTIFF. Give the -co bigtiff=yes parameter manually if you feel that it could be needed.
If Even is still sneaking here he can say if the behaviour you see with gdal_merge.py is expected or a bug. Otherwise you can ask it from gdal-dev mailing list.
-Jukka-
On 21 November 2013 21:23, Rahkonen Jukka <jukka.rahkonen@anonymised.com<mailto:jukka.rahkonen@anonymised.com>> wrote:
Yep, that worked. Although that's unfeasible for the full dataset; I don't have enough diskspace for an uncompressed version.
Thanks!
Jonathan
Jukka Rahkonen
The "bit" larger files are typically about double the size of the uncompressed one!
I know deflate isn't as well suited, but I'm experimenting with a whole bunch of different settings to see what sticks.
I'm now trying to get the four band into GeoServer (regular GeoTIFF), but it's not having it. I've created it the same way as the 3 band:
The first thing I notice is that the 4 band is *smaller* (118MB) than the 3 band (164MB).
Files: rgbi.tif
Size is 8000, 24000
[brevity removed]
Metadata:
  AREA_OR_POINT=Area
  COMPRESSION=JPEG
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 419000.000, 240000.000) ( 1d43'22.27"W, 52d 3'27.49"N)
Lower Left ( 419000.000, 237000.000) ( 1d43'22.87"W, 52d 1'50.38"N)
Upper Right ( 420000.000, 240000.000) ( 1d42'29.76"W, 52d 3'27.37"N)
Lower Right ( 420000.000, 237000.000) ( 1d42'30.39"W, 52d 1'50.26"N)
Center ( 419500.000, 238500.000) ( 1d42'56.32"W, 52d 2'38.88"N)
Ideally I'm looking to have one source file which can be symbolised as not just RGB, but also as any number of false-colour possibilities.
Any suggestions anyone? I'm stumbling into new (for me) territory here.
Jonathan
Geoserver-users@lists.sourceforge.net<mailto:Geoserver-users@anonymised.comrge.net>
I have been doing a lot of merging recently with GDAL and I have been following this process
1. gdalwarp -multi -of GTiff -s_srs EPSG:32641 -t_srs EPSG:4326 -r cubic --config GDAL_CACHEMAX 600 -wm 600 -et 0 -srcnodata 0 -dstnodata 0 $SOURCE_FILE.sid $DEST_FILE.4326.tif
  Repeat for each source file in the folder
2. ls -1 *.tif >> warpinput.txt
  Create an input file from all the warped images
3. gdalbuildvrt -input_file_list warpinput.txt DEST_FILE.4326.vrt
4. time gdalwarp -of GTiff -multi -r cubic --config GDAL_CACHEMAX 600 -wm 600 -et 0 -srcnodata 0 -dstnodata 0 -co TILED=YES -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 -co BIGTIFF=YES -cutline <path to>library/one_degree_cells/4326/e074n37_onedegree.shp DEST_FILE.4326.vrt DEST_FILE.4326.merged.tif
5. gdaladdo -r gauss --config GDAL_CACHEMAX 4096 --config COMPRESS_OVERVIEW JPEG --config JPEG_QUALITY_OVERVIEW 85 --config INTERLEAVE_OVERVIEW PIXEL DEST_FILE.4326.merged.tif 2 4 8 16 32
This has worked fairly well for me so far, your mileage may vary.
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
-----Original Message-----
From: Rahkonen Jukka [mailto:jukka.rahkonen@anonymised.com]
Sent: Friday, November 22, 2013 11:19 AM
Subject: Re: [Geoserver-users] GeoTIFFs verus JP2
-Jukka-
Thanks!
Jonathan
Jukka Rahkonen
It is not completely surprising. If there are no repeateable patterns in the uncompressed stream, deflate can result in (a bit) larger files. You might want to try with -co INTERLEAVE=BAND added to see if it improves things. But generally DEFLATE is not appropriate for aerial imagery.
gdal_merge -q -o rgbi.tif -of GTiff -co TILED=YES -co BIGTIFF=YES -co COMPRESS=JPEG -co JPEG_QUALITY=25 -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 --optfile tiff_list.txt (low compression for testing). No pyramids yet.
Files: rgbi.tif
Size is 8000, 24000
PROJCS["OSGB 1936 / British National Grid", [brevity removed] Origin = (419000.000000000000000,240000.000000000000000)
Metadata:
  AREA_OR_POINT=Area
  COMPRESSION=JPEG
  INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 419000.000, 240000.000) ( 1d43'22.27"W, 52d 3'27.49"N) Lower Left ( 419000.000, 237000.000) ( 1d43'22.87"W, 52d 1'50.38"N) Upper Right ( 420000.000, 240000.000) ( 1d42'29.76"W, 52d 3'27.37"N) Lower Right ( 420000.000, 237000.000) ( 1d42'30.39"W, 52d 1'50.26"N)
java.lang.RuntimeException: javax.imageio.IIOException: Unsupported Image Type at com.sun.media.jai.imageioimpl.ImageReadOpImage.computeTile(ImageReadOpImage.java:706)
Caused by: javax.imageio.IIOException: Unsupported Image Type at com.sun.imageio.plugins.jpeg.JPEGImageReader.readInternal(Unknown Source) at com.sun.imageio.plugins.jpeg.JPEGImageReader.read(Unknown Source) at it.geosolutions.imageioimpl.plugins.tiff.TIFFJPEGDecompressor.decodeRaw(TIFFJPEGDecompressor.java:278)
Jonathan
Shape the Mobile Experience: Free Subscription Software experts and developers: Be at the forefront of tech innovation.
Intel(R) Software Adrenaline delivers strategic insight and game-changing conversations that shape the rapidly evolving mobile landscape. Sign up now.
Le vendredi 22 novembre 2013 19:18:56, Rahkonen Jukka a écrit :
- add data - close file". There are other alternatives to test: - You can
lossless and the final result will be identical. - Use gdalbuildvrt for
mailing list.
I'm not sure which gdal_merge behaviour Jukka is refering too, but indeed it
might not be the appropriate tool to mosaic stuff into a compressed geotiff due
to the way it operates (it can have to do uncompression / recompression cycles
that will waste space in the geotiff). gdalbuildvrt to do the mosaicing
(without a disk footprint of only a few bytes) followed by gdal_translate to
compress will lead to the optimal file size.
-Jukka-
<jukka.rahkonen@anonymised.com<mailto:jukka.rahkonen@anonymised.com>> wrote: I
Thanks!
Jonathan
Jukka Rahkonen
uncompressed one!
it's not having it. I've created it the same way as the 3 band: gdal_merge
band (164MB).
Files: rgbi.tif
Size is 8000, 24000
[brevity removed]
Metadata:
  AREA_OR_POINT=Area
  COMPRESSION=JPEG
  INTERLEAVE=PIXEL
Corner Coordinates:
Type at
e.java:706) at
:904) at javax.media.jai.OpImage.getTile(OpImage.java:1129)
Source) at
Jonathan
--- Shape the Mobile Experience: Free Subscription
now.
rge.net> https://lists.sourceforge.net/lists/listinfo/geoserver-users
now.
Hi Even,
The gdal_merge.py behaviour I meant was exactly that the resulting directly created compressed tiff can waste space.
-Jukka-
mailing list.
-Jukka-
Thanks!
Jonathan
Jukka Rahkonen
uncompressed one!
band (164MB).
Files: rgbi.tif
Size is 8000, 24000
[brevity removed]
Metadata:
  AREA_OR_POINT=Area
  COMPRESSION=JPEG
  INTERLEAVE=PIXEL
Corner Coordinates:
Type at
e.java:706) at
Source) at
Jonathan
now.
now.
Thanks for the replies. My other problem is that I don’t have a good GDAL install (precompiled for windows). Every one I’ve tried has been buggy/non-functional in some critical way (typically environmental variable issues). I tried creating a nice little batch file to do everything at once in sequence for each raster, but alas that didn’t work out so its “do things manually”.
I’ll have to do some more testing.
Jonathan
  • add data - close file". There are other alternatives to test: - You can
mailing list.
I’m not sure which gdal_merge behaviour Jukka is refering too, but indeed it
-Jukka-
<jukka.rahkonen@anonymised.com…mailto:[jukka.rahkonen@anonymised.com](mailto:jukka.rahkonen@anonymised.com)> wrote: I
Thanks!
Jonathan
Jukka Rahkonen
Jonathan Moulesmailto:[jonathanmoules@anonymised.com](mailto:jonathanmoules@anonymised.com) wrote:
uncompressed one!
it’s not having it. I’ve created it the same way as the 3 band: gdal_merge
band (164MB).
Files: rgbi.tif
Size is 8000, 24000
[brevity removed]
Metadata:
AREA_OR_POINT=Area
COMPRESSION=JPEG
INTERLEAVE=PIXEL
Corner Coordinates:
Type at
e.java:706) at
Source) at
Jonathan
— Shape the Mobile Experience: Free Subscription
now.
now.
What exactly is wrong with the builds from http://gisinternals.com/sdk/? I have been using them for years with good success.
-Jukka Rahkonen-
Jonathan
On 22 November 2013 18:58, Even Rouault <even.rouault@anonymised.com…> wrote:
mailing list.
-Jukka-
Thanks!
Jonathan
Jukka Rahkonen
uncompressed one!
band (164MB).
Files: rgbi.tif
Size is 8000, 24000
[brevity removed]
Metadata:
AREA_OR_POINT=Area
COMPRESSION=JPEG
INTERLEAVE=PIXEL
Corner Coordinates:
Type at
e.java:706) at
Source) at
Jonathan
now.
now.
