[Geoserver-users] GeoTIFFs verus JP2
If you are on Windows 64-bit and don’t need Python nor Oracle, use this:
http://gisinternals.com/sdk/Download.aspx?file=release-1600-x64-gdal-mapserver.zip
Installation is like with FWTools: unzip. Go to installation directory, run “sdkshell” or perhaps “sdkshell hideoci”.
This is for sure problem free and good to have always on all your computers.
For Python v. 2.7 and Oracle I have installed
http://gisinternals.com/sdk/Download.aspx?file=release-1600-x64-gdal-mapserver\gdal-110-1600-x64-core.msi
http://gisinternals.com/sdk/Download.aspx?file=release-1600-x64-gdal-mapserver\GDAL-1.10.0.win-amd64-py2.7.msi
http://gisinternals.com/sdk/Download.aspx?file=release-1600-x64-gdal-mapserver\gdal-110-1600-x64-oracle.msi
I have not yet studied the environment settings, I just open the GDAL command window that appears into Start menu after msi installation and used python tools with absolute paths like
c:\python27\python C:\GDAL_dev\bin\gdal\python\scripts\gdal_edit.py [parameters]
-Jukka-
Jonathan Moules wrote:
Hi Jukka,
I’ve tried that one before. First there’s the fact there are far too many options and I can never be sure I’m getting the right thing (the page assumes a significant level of knowledge about what package is what). Second the python scripts (i…e. gdal_merge.py) don’t work “out of the box” and it’s non-obvious how to fix that (I just noticed there are also “GDA: python bindings” extension things, but just done that and it still doesn’t work so… :-S ).
For ease of use I prefer http://fwtools.maptools.org/ - except that it seems to be an outdated version of GDAL (so I’m hitting some GDAL bugs there) and has an issue with batch files too.
And the QGIS version comes with all manner of environmental variable issues that stop it from working stand-alone for me.
I think I may have tried the version that comes with FME too, but similar issues.
GDAL is a powerful tool, but as I’ve learnt to expect from command-line software, it’s not easy to install/use. :frowning:
Jonathan
On 26 November 2013 11:27, Rahkonen Jukka <jukka.rahkonen@anonymised.com86…> wrote:
What exactly is wrong with the builds from http://gisinternals.com/sdk/? I have been using them for years with good success.
-Jukka Rahkonen-
Jonathan wrote:
Thanks for the replies. My other problem is that I don’t have a good GDAL install (precompiled for windows). Every one I’ve tried has been buggy/non-functional in some critical way (typically environmental variable issues). I tried creating a nice little batch file to do everything at once in sequence for each raster, but alas that didn’t work out so its “do things manually”.
I’ll have to do some more testing.
Jonathan
On 22 November 2013 18:58, Even Rouault <even.rouault@anonymised.com> wrote:
Le vendredi 22 novembre 2013 19:18:56, Rahkonen Jukka a écrit :
I think that the reason is that is is hard/impossible to make an optimal
deflate compressed tiff when gdal_merge goes through the circle "open file
  • add data - close file". There are other alternatives to test: - You can
    use a non-optimal deflate compressed tiff as a temporary file - is is
    lossless and the final result will be identical. - Use gdalbuildvrt for
    making an interim .VRT file and convert that to final product instead of
    using gdal_merge.py. Perhaps GDAL can make an optimal deflate compressed
    image from the VRT file with one run.
A hint: If you play with big datasets and deflate compressed images GDAL
sometimes does not guess when it should jump into BigTIFF. Give the -co
bigtiff=yes parameter manually if you feel that it could be needed.
If Even is still sneaking here he can say if the behaviour you see with
gdal_merge.py is expected or a bug. Otherwise you can ask it from gdal-dev
mailing list.
I’m not sure which gdal_merge behaviour Jukka is refering too, but indeed it
might not be the appropriate tool to mosaic stuff into a compressed geotiff due
to the way it operates (it can have to do uncompression / recompression cycles
that will waste space in the geotiff). gdalbuildvrt to do the mosaicing
(without a disk footprint of only a few bytes) followed by gdal_translate to
compress will lead to the optimal file size.
-Jukka-
On 21 November 2013 21:23, Rahkonen Jukka
<jukka.rahkonen@anonymised.commailto:[jukka.rahkonen@anonymised.com](mailto:jukka.rahkonen@anonymised.com..)> wrote: I
would try if it makes difference to save result from gdal_merge first into
uncompressed tiff and compress it with deflate in a separate run.
Yep, that worked. Although that’s unfeasible for the full dataset; I don’t
have enough diskspace for an uncompressed version.
Also, doing that (deflate, level 9), the tiled version was about 15%
smaller than the untiled version.
Thanks!
Jonathan
Jukka Rahkonen
Jonathan Moulesmailto:[jonathanmoules@anonymised.com](mailto:jonathanmoules@anonymised.com) wrote:
It is not completely surprising. If there are no repeateable patterns in
the uncompressed stream, deflate can result in (a bit) larger files. You
might want to try with -co INTERLEAVE=BAND added to see if it improves
things. But generally DEFLATE is not appropriate for aerial imagery.
The “bit” larger files are typically about double the size of the
uncompressed one!
I know deflate isn’t as well suited, but I’m experimenting with a whole
bunch of different settings to see what sticks.
I’m now trying to get the four band into GeoServer (regular GeoTIFF), but
it’s not having it. I’ve created it the same way as the 3 band: gdal_merge
-q -o rgbi.tif -of GTiff -co TILED=YES -co BIGTIFF=YES -co COMPRESS=JPEG
-co JPEG_QUALITY=25 -co BLOCKXSIZE=512 -co BLOCKYSIZE=512 --optfile
tiff_list.txt (low compression for testing). No pyramids yet.
The first thing I notice is that the 4 band is smaller (118MB) than the 3
band (164MB).
The gdalinfo for the four band:
Driver: GTiff/GeoTIFF
Files: rgbi.tif
Size is 8000, 24000
Coordinate System is:
PROJCS[“OSGB 1936 / British National Grid”,
[brevity removed]
Origin = (419000.000000000000000,240000.000000000000000)
Pixel Size = (0.125000000000000,-0.125000000000000)
Metadata:
AREA_OR_POINT=Area
Image Structure Metadata:
COMPRESSION=JPEG
INTERLEAVE=PIXEL
Corner Coordinates:
Upper Left ( 419000.000, 240000.000) ( 1d43’22.27"W, 52d 3’27.49"N)
Lower Left ( 419000.000, 237000.000) ( 1d43’22.87"W, 52d 1’50.38"N)
Upper Right ( 420000.000, 240000.000) ( 1d42’29.76"W, 52d 3’27.37"N)
Lower Right ( 420000.000, 237000.000) ( 1d42’30.39"W, 52d 1’50.26"N)
Center ( 419500.000, 238500.000) ( 1d42’56.32"W, 52d 2’38.88"N)
Band 1 Block=512x512 Type=Byte, ColorInterp=Red
Mask Flags: PER_DATASET ALPHA
Band 2 Block=512x512 Type=Byte, ColorInterp=Green
Band 3 Block=512x512 Type=Byte, ColorInterp=Blue
Band 4 Block=512x512 Type=Byte, ColorInterp=Alpha
The GeoServer logs contain an error (WMS GetMap request):
2013-11-20 17:56:07,498 ERROR [org.geoserver.ows] -
java.lang.RuntimeException: javax.imageio.IIOException: Unsupported Image
Type at
com.sun.media.jai.imageioimpl.ImageReadOpImage.computeTile(ImageReadOpImag
e.java:706) at
com.sun.media.jai.util.SunTileScheduler.scheduleTile(SunTileScheduler.java
:904) at javax.media.jai.OpImage.getTile(OpImage.java:1129)
Caused by: javax.imageio.IIOException: Unsupported Image Type
at com.sun.imageio.plugins.jpeg.JPEGImageReader.readInternal(Unknown
Source) at com.sun.imageio.plugins.jpeg.JPEGImageReader.read(Unknown
Source) at
it.geosolutions.imageioimpl.plugins.tiff.TIFFJPEGDecompressor.decodeRaw(TI
FFJPEGDecompressor.java:278)
Ideally I’m looking to have one source file which can be symbolised as not
just RGB, but also as any number of false-colour possibilities.
Any suggestions anyone? I’m stumbling into new (for me) territory here.
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in
error please notify the sender immediately. All email traffic sent to or
from us, including without limitation all GCSX traffic, may be subject to
recording and/or monitoring in accordance with relevant legislation.
— Shape the Mobile Experience: Free Subscription
Software experts and developers: Be at the forefront of tech innovation.
Intel(R) Software Adrenaline delivers strategic insight and game-changing
conversations that shape the rapidly evolving mobile landscape. Sign up
now.
http://pubads.g.doubleclick.net/gampad/clk?id=63431311&iu=/4140/ostg.clktr
k _______________________________________________
Geoserver-users mailing list
Geoserver-users@lists.sourceforge.net<mailto:Geoserver-users@anonymised.com
rge.net> https://lists.sourceforge.net/lists/listinfo/geoserver-users
now.
Geospatial professional services
http://even.rouault.free.fr/services.html
conversations that shape the rapidly evolving mobile landscape. Sign up now.
http://pubads.g.doubleclick.net/gampad/clk?id=63431311&iu=/4140/ostg.clktrk
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Hi Jukka,
Just like with the one that Simone linked to, when I try and run gdal_merge.py I get a python error:
C:\Users\jmou1\Desktop\release-1600-x64-gdal-mapserver\bin\gdal\python\scripts>g
dal_merge.py
File “C:\Users\jmou1\Desktop\release-1600-x64-gdal-mapserver\bin\gdal\python\s
cripts\gdal_merge.py”, line 36, in
import gdal
File “C:\Users\jmou1\Desktop\release-1600-x64-gdal-mapserver\bin\gdal\python\g
dal.py”, line 2, in
from osgeo.gdal import deprecation_warn
File “C:\Users\jmou1\Desktop\release-1600-x64-gdal-mapserver\bin\gdal\python\o
sgeo_init_.py”, line 21, in
gdal = swig_import_helper()
File "C:\Users\jmou1\Desktop\release-1600-x64-gdal-mapserver\bin\gdal\python\o
sgeo_init
.py", line 17, in swig_import_helper
_mod = imp.load_module(‘_gdal’, fp, pathname, description)
ImportError: DLL load failed: %1 is not a valid Win32 application.
gdal_edit.py gives me the same.
gdalinfo etc works, it’s just the python stuff that doesn’t.
Kind Regards,
Jonathan
On 26 November 2013 12:32, Rahkonen Jukka <jukka.rahkonen@anonymised.com> wrote:
-Jukka-
Hi Jukka,
Jonathan
-Jukka Rahkonen-
Jonathan
On 22 November 2013 18:58, Even Rouault <even.rouault@anonymised.com…> wrote:
mailing list.
-Jukka-
Thanks!
Jonathan
Jukka Rahkonen
uncompressed one!
band (164MB).
Files: rgbi.tif
Size is 8000, 24000
[brevity removed]
Metadata:
AREA_OR_POINT=Area
COMPRESSION=JPEG
INTERLEAVE=PIXEL
Corner Coordinates:
Type at
e.java:706) at
Source) at
Jonathan
now.
now.
In case anyone else is hitting this issue, the version of GDAL that comes in the OSGeo4W package http://trac.osgeo.org/osgeo4w/ - works just fine, including the python stuff and it’s easy to install.
On 26 November 2013 12:56, Jonathan Moules <jonathanmoules@anonymised.com> wrote:
Hi Jukka,
dal_merge.py
import gdal
dal.py”, line 2, in
sgeo_init
Kind Regards,
Jonathan
-Jukka-
Hi Jukka,
Jonathan
-Jukka Rahkonen-
Jonathan
mailing list.
-Jukka-
Thanks!
Jonathan
Jukka Rahkonen
uncompressed one!
band (164MB).
Files: rgbi.tif
Size is 8000, 24000
[brevity removed]
Metadata:
AREA_OR_POINT=Area
COMPRESSION=JPEG
INTERLEAVE=PIXEL
Corner Coordinates:
Type at
e.java:706) at
Source) at
Jonathan
now.
now.
