[Geoserver-users] Geotiif Image not displayed in large Zoom Levels
Hello,
I have imported in Geoserver a large Geotiff Image (3GB) in ETRS89. Everything works ok but I have noticed to things that I would like to discuss:
  1. Why in Layer preview the image does not look as clear when I use the WMS version 1.3.0. in compare with the WMS 1.1.1?
  2. Why there is no tile generation for the image after the scale 1:4261.
If it helps you can find attached the geoserver.log and the gdalinfo of the Geotiff:
Thanks in advaned,
Stephanos
On Mon, Nov 9, 2015 at 9:59 AM, Stephanos Charalambous <
stephanos_ch@anonymised.com> wrote:
Hello,
discuss:
That's weird, but I cannot comment further without a image sample
Could it be that at zoom level in question you are selecting less than a
pixel of the source data?
Still a bug for sure, I just know that stuff does not always work as
expected when the oversampling
compared to the native resolution level becomes less than reasonable (e.g.
1000 times)
By the way, there is no attachment in your mail (not the one that got to
the mailing list, at least)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
