[Geoserver-users] [Geotools-gt2-users] FW: Virtual Earth Transformation Question
Switching this thread to geoserver-users, as it's not a gt question.
And because someone else is likely going to have to help out, as I won't
be online much longer.
But did you change the SRS in the admin console, like in the featureType
page? Or did you just change it in the request string? Because if you
just do the latter than you also need to adjust the bbox. If you do the
former it should work, but there may be something in the pipeline that's
not quite right.
Chris
On Tue, August 21, 2007 12:26 pm, Brad Cooper wrote:
I've played a little more (downloaded 1.5.3 nightly
build). I don't get the error any longer but I don't see an image. I tried
the demo examples from the GeoServer admin console (changing the SRS
parameter).
http://localhost:8080/geoserver/wms?bbox=588215.0934998066,4912904.566716
96,610781.6060742784,4929115.20400145&styles=&Format=application/openlaye
rs&request=GetMap&layers=sf:streams&width=800&height=539&srs=EPSG:900913
But it still doesn't return anything.
--- Chris Holmes <cholmes@anonymised.com> wrote:
1.5.3 should return something, and it should
recognize 900913. It may get the error he got if 900913 isn't defined in
the data directory, like if he's using an older data directory.
On Tue, August 21, 2007 12:10 pm, Randy George
wrote:
Brad's message didn't cop to this list. I assume
this is the bug you
mentioned being fixed in the svn.
-----Original Message-----
Sent: Tuesday, August 21, 2007 9:26 AM
To: Randy George
Subject: RE: [Geotools-gt2-users] Virtual Earth
Unfortunately I get this error message from my
new
1.5.3 Geoserver install.
<ServiceException code="InvalidSRS">No authority
was
defined for code &quot;900913&quot;. Did you
forget
&quot;AUTHORITY:NUMBER&quot;?</ServiceException>
--- Randy George <rkgeorge@anonymised.com> wrote:
When I directly put SRS=EPSG:900913 in a URL to a
valid WMS request, it alway's comes back with a
blank png image. I'll look
at it again later.
Hi Coop,
Hmm... I would have thought the opposite - zoom
in
bad fit, zoom out good fit. I will be curious to
know if EPSG:900913
solves the issue.
I see that now the veapi.js doesn't have to be
modified (the blog was from 2006). Did you work
out how to fool the
tileSourceSpec to point to a Java servlet?
tileSourceSpec.TileSource =
http://someserver:someport/somewebapp/tiles/%4.png";
Randy
Sent: Tuesday, August 21, 2007 8:38 AM
To: Randy George;
Geotools-gt2-users@lists.sourceforge.net
Subject: Re: [Geotools-gt2-users] Virtual Earth
Thanks for the reply Randy,
That's exactly what I'm experiencing "does not
work
well at high zoom values". I've attached two
screenshots from a local VE
.html page. The tiles
are getting dynamically generated from a local
GeoServer instance and
streamed back to the client using a servlet. As
you can see from the
screenshot, the overlay is perfect (we'll looks
perfect to the eye) when
zoomed in, but is off when zoomed out (gets worse
the more I zoom out).
Thanks for the tips, I'll try them out and let
you
know.
Hi Coop,
I'm interested in this as well and am planning
to
get to it sometime. Rob Blackwell's blog
mentioned that he used
EPSG:4326
"Virtual Earth uses a WGS84 Mercator projection,
but
WMS servers need you to
specify the projection. In this case we've
specified
a Coordinate Reference System (CRS) of EPSG:4326
which is a common
geographic projection that is equivalent to
WGS84." I suspect this does
not work well at high zoom values. I gather as
well that the veapi.js
needs to be modified.
Chris Holmes mentions this in his GeoServer
1.5.3
announcement:
http://blog.geoserver.org/2007/08/14/geoserver-embraces-the-geoweb/
"With a bit of coding from Andrea we're also now
shipping with support for the map projection
used by Virtual Earth and
Google
Maps, thanks to SharpGIS
and Chris Schmidt. So now if you use 900913 as
the
EPSG code for your WMS
requests our output will be perfectly overlaid
on those maps."
900913 is a custom EPSG created specific to
Google
and VE. You can download the latest version of
GeoServer1.5.3 and look
at
the
configuration\release\user_projections\epsg.properties
900913=PROJCS["WGS84 / Simple Mercator",
GEOGCS["WGS
84", DATUM["WGS_1984",
SPHEROID["WGS_1984", 6378137.0, 298.257223563]],
PRIMEM["Greenwich", 0.0],
UNIT["degree", 0.017453292519943295],
AXIS["Longitude", EAST],
AXIS["Latitude", NORTH]],
PROJECTION["Mercator_1SP_Google"],
PARAMETER["latitude_of_origin", 0.0],
PARAMETER["central_meridian", 0.0],
PARAMETER["scale_factor", 1.0],
PARAMETER["false_easting", 0.0],
PARAMETER["false_northing", 0.0], UNIT["m",
1.0],
AXIS["x", EAST], AXIS["y",
NORTH], AUTHORITY["EPSG","900913"]]
You can use the GeoTools projection code by
adding
this to the EPSG database. Or you could more
simply add your own
Java
projection code using the parameters above.
http://mathworld.wolfram.com/MercatorProjection.html
Let us know if you succeed in getting the VE WMS
overlay working
Thanks
Randy
geotools-gt2-users-bounces@lists.sourceforge.net
=== message truncated ===
_________________________________________________________________________
___________
Yahoo! oneSearch: Finally, mobile search
that gives answers, not web links.
http://mobile.yahoo.com/mobileweb/onesearch?refer=1ONXIC
Geotools-gt2-users mailing list
https://lists.sourceforge.net/lists/listinfo/geotools-gt2-users
!DSPAM:4005,46cb125e145421439371379!
Chris Holmes
The Open Planning Project
http://topp.openplans.org
Thanks Chris, yes-I only changed the SRS in the URL
and I updated the bbox to be something large enough
that I thought would display the information.
not a gt question.
bbox. If you do the
the pipeline that's
not quite right.
Chris
nightly
(changing the SRS
> parameter).
data directory.
>> this is the bug you
>>> From: Brad Cooper [mailto:coobr01@anonymised.com]
>>> To: Randy George
>> new
>> was
>> forget
a
>>> at it again later.
>>>> Hi Coop,
>> in
to
>> know if EPSG:900913
>>>> solves the issue.
>> out how to fool the
>>>> Randy
>>>> To: Randy George;
>> work
worse
>> you
>>>> know.
>>>>> Hi Coop,
>> to
>>>>> EPSG:4326
projection,
>>>> but
>>>> specified
EPSG:4326
>> which is a common
____________________________________________________________________________________
Looking for a deal? Find great prices on flights and hotels with Yahoo! FareChase.
http://farechase.yahoo.com/
Just tried with the actual 900913 bbox and I get the map all right.
Here is the request:
http://localhost:8080/geoserver/wms?bbox=-11563633,5523243,-11535246,5543493&styles=&Format=application/openlayers&request=GetMap&layers=sf:streams&width=800&height=539&srs=EPSG:900913
Now, to get the bbox in 900913 I had to write a little program
that does the envelope reprojection, and run it among the GeoServer
sources so that it picks up our "extra" Google projection class.
Here it is, just for completeness sake:
import org.geotools.geometry.jts.ReferencedEnvelope;
import org.geotools.referencing.CRS;
import org.opengis.referencing.crs.CoordinateReferenceSystem;
public class GoogleEnvelopeTest {
     public static void main(String args) throws Exception {
         CoordinateReferenceSystem wgs = CRS.decode("EPSG:4326", true);
         System.out.println(wgs);
         CoordinateReferenceSystem google = CRS.decode("EPSG:900913");
         System.out.println(google);
         ReferencedEnvelope lle = new ReferencedEnvelope(-103.87789019829768, -103.62287788915457, 44.372335260095554, 44.502218486214815, wgs);
         ReferencedEnvelope ge = lle.transform(google, true);
         System.out.println(lle);
         System.out.println(ge);
Hope this helps. Hum, in fact it would be nice to have some
geodetic calculator among the GeoServer demos allowing the
end user to perform point and envelop reprojection, compute
geodetic distances and the like... scheduling an issue for
GeoServer 1.7, we need the new interface framework before
we can tackle this one (unless anyone wants to do it now
with Struts, I certainly would not be against it :slight_smile: ).
Thanks Andrea,
It makes since but I do I get GeoTools to recognize
the EPSG:900913 projection? I've never tried to add a
new project to GeoTools (only to Geoserver).
Thanks!
URL
enough
map all right.
little program
among the GeoServer
projection class.
import
Exception {
have some
allowing the
compute
issue for
before
now
Sick sense of humor? Visit Yahoo! TV's
Comedy with an Edge to see what's on, when.
http://tv.yahoo.com/collections/222
Thanks Andrea,
The Google projection is a new class,
with custom code to accomodate for the custom way Google
interprets the Mercator projection.
This class has been created in GeoServer, and still has
to be backported into GeoTools.
Can I ask what are you trying to achieve?
Basically I’d like to create a java based proxy
Servlet that would 1) convert Virtual Earth/Google Map
tile requests to bounding box coordinates, 2)
transform
those coordinates to the appropriate ESPG 900913
reference system, 3) send the appropriate request
based on the
transformed coordinates to a GeoServer WMS, 4) Stream
the WMS results back to the VE map control.
> Thanks Andrea,
recognize
add a
Google
has
Moody friends. Drama queens. Your life? Nope! - their life, your story. Play Sims Stories at Yahoo! Games.
http://sims.yahoo.com/
transform
based on the
Just wondering, we already have a javascript based solution
that does this work on the client side, turning a tile
request into a WMS request, created especially for Google
Maps. You can find it in this file:
https://svn.codehaus.org/geoserver/trunk/geoserver/web/src/main/webapp/gmaps/wms-gs.js
If you can't work in javascript, I guess all you need to
do is to translate this code into java when creating the proxy.
Would that be an acceptable solution?
Thanks Andrea, since I have to support VE I'll need to
do this on the middle tier (convert VE QUAD Tile
Requests to Bounding Boxes and then transform to
900913). I'll take a look at the javascript.
Map
> transform
> based on the
Stream
solution
tile
Google
need to
the proxy.
Shape Yahoo! in your own image. Join our Network Research Panel today! http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7
I was wondering if Brad or anyone else has had success displaying Geoserver WMS on Virtual Earth directly (without using OpenLayers). Did the 900913 projection overlay correctly?
I’ve got a custom proxy servlet that translates between VE quad code and WGS 84 WMS and caches the result, but a) I run into the same overlay problems as Brad and b) I’d rather have one integrated WFS/WMS/VE tile cache solution. Can I do this under Geoserver now or soon-ish?
Thanks, Trevor
Brad Cooper wrote:
Thanks Andrea, since I have to support VE I’ll need to do this on the middle tier (convert VE QUAD Tile Requests to Bounding Boxes and then transform to 900913). I’ll take a look at the javascript.
View this message in context: Re: [Geotools-gt2-users] FW: Virtual Earth Transformation Question
