Cool, glad to hear things are working. Is this the entire document below. I notice that is are no namespace mappings?
-Justin
Fabio Luiz Leite wrote:
Hi Justin, very thank you !! Everything worked fine !
Now, I have some problems with the follwing filter sample:
<Disjoint>
<PropertyName>Geometry</PropertyName>
<gml:Box srsName=" http://www.opengis.net/gml/srs/epsg.xml#4326">
<gml:coordinates>13.0983,31.589935.5472,42.8143</gml:coordinates>
</gml:Box>
</Disjoint>It's occurring an error during the parsing. The error message is:
org.xml.sax.SAXException: Handler for gml:Box could not be found.
Do you know what is happen ? The java code is the same of the example of the user's guide.
On 1/22/07, *Justin Deoliveira* < jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>> wrote:
Hi Fabio,
I have updated the page which lists the dependencies you will need.
There are quite a few of them :).-Justin
> Justin,
> It's ocurring errors yet. I change the old libraries for new
> libraries (gt2-xml-xsd-2.4-SNAPSHOT.jar ,
> gt2-xml-filter-2.4-SNAPSHOT.jar,
> gt2-xml-gml2-2.4-SNAPSHOT.jar,
> gt2-main-2-2.4-SNAPSHOT )
> and so on.
> The error is the following:
> java.lang.NoClassDefFoundError : org/geotools/resources/Utilities
> Where are this class ? What is the remaining package ?
> On 1/22/07, *Justin Deoliveira* <jdeolive@anonymised.com
wrote:
> Hi Fabio,
> I just added a faq for your question :).
> http://docs.codehaus.org/display/GEOTDOC/XML+Parsing+and+Encoding+FAQ
> Also, if you want you can use svn to check out the source
code directly
> from our geotools repository.
> http://svn.geotools.org/geotools/trunk/gt
> -Justin
> > Hi Justin (and all),
> > How to parse a ogc filter using version 2.3 ? I tryed the
following
> > code, but an error happened on creation of FilterFilter:
> > // instantiante parsers and content handlers
> > MyHandler contentHandler = new MyHandler();
> > FilterFilter filterParser = new
> FilterFilter(contentHandler, null);
> > GMLFilterGeometry geometryFilter = new
> > GMLFilterGeometry(filterParser);
> > GMLFilterDocument documentFilter = new
> > GMLFilterDocument(geometryFilter);
> > // read in XML file and parse to content handler
> > SAXParserFactory factory =
SAXParserFactory.newInstance();
> > SAXParser parser = factory.newSAXParser();
> > ParserAdapter adapter = new ParserAdapter(
> parser.getParser());
> > adapter.setContentHandler(documentFilter);
> > adapter.parse(requestSource);
> > assertEquals(contentHandler.filters.size (),1);
> > LogicFilterImpl f = (LogicFilterImpl)
> contentHandler.filters.get(0);
> > List sub = f.getChildren();
> > assertEquals(2, sub.size());
> > Filter f1 = (Filter) sub.get(0);
> > Filter f2 = (Filter) sub.get(1);
> assertEquals(FilterType.GEOMETRY_INTERSECTS ,f1.getFilterType());
> > assertEquals(FilterType.GEOMETRY_BBOX,
f2.getFilterType());
> > Could you tell me more info about how to get the 2.4
version ? I am
> > interested.
> <mailto: jdeolive@anonymised.com <mailto:jdeolive@anonymised.com>>
<mailto:jdeolive@anonymised.com> <mailto:jdeolive@anonymised.com
<mailto:jdeolive@anonymised.com>>>>
> wrote:
> > Hi Fabio,
> > Actually this a new way to parse a filter and is only
> available in
> > geotools 2.4 which is yet to be released.
> > If you want to use this code, you will need to check
out the
> geotools
> > 2.4 ( trunk ) branch and build it from source.
> > Let me know if you are interested and want more info
on how
> to do so.
> > -Justin
> > > Hi all,
> > > i'm trying to run an example of the user
guide about
> > Filter XML
> > > Support. But, when i run the sample, i'm getting a
lot of
> errors.
> > > The parser in the sample follows:
> > > //create the parser with the filter 1.0 configuration
> > > org.geotools.xml.Configuration = new
> > org.geotools.filter.v1_0.OGCConfiguration ();
> > > org.geotools.xml.Parser
> > > parser = new org.geotools.xml.Parser( configuration );
> > > //the xml instance document above
> > > InputStream xml = ...
> > > //parse
> > > Filter filter = (Filter) parser.parse( xml );
> > > Is this a deprecated way to parse a filter ?
> > > How to run this code using geotools version 2.3 ?
> > > Thanks in advance !
> > > Fábio Luiz Leite Júnior
> > > Take Surveys. Earn Cash. Influence the Future of IT
> > > Join SourceForge.net's Techsay panel and you'll get the
> chance to
> > share your
> > > opinions on IT & business topics through brief
surveys -
> and earn
> > cash
> http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV
<http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV>
<http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV>>
<http://www.techsay.com/default.php?page=join.php&p=sourceforge&CID=DEVDEV>>>
> > > _______________________________________________
> > > Geotools-gt2-users mailing list
> > > Geotools-gt2-users@lists.sourceforge.net
<mailto:Geotools-gt2-users@lists.sourceforge.net>
<mailto:Geotools-gt2-users@lists.sourceforge.net>>
> > <mailto: Geotools-gt2-users@lists.sourceforge.net
<mailto:Geotools-gt2-users@lists.sourceforge.net>>>
> https://lists.sourceforge.net/lists/listinfo/geotools-gt2-users
<https://lists.sourceforge.net/lists/listinfo/geotools-gt2-users>
> > Justin Deoliveira
> > The Open Planning Project
> > http://topp.openplans.org
> > Fábio Luiz Leite Júnior !DSPAM:1004,45b52227100181510810322!
chance to
> share your
> > opinions on IT & business topics through brief surveys -
and earn
> cash
> Justin Deoliveira
> Fábio Luiz Leite Júnior !DSPAM:1004,45b5320e112911410093335!--
Justin Deoliveira
http://topp.openplans.org--
Fábio Luiz Leite Júnior !DSPAM:1004,45b64365265651194215290!
Justin Deoliveira
