Yingqi Tang wrote:
Justin,
when I am trying to generate the binding for owaAll.xsd schema, I got
a fatal error saying thatNullPointerException from org.geotools.xml.Schemas.getIncludes(Schemas.java 862)
Which seems to be caused by the <import> tag in the owaAll schema.
Do you how to solve that?
Hmm... that would mean the schema passed in is null... can you give me the entire stack trace?
YingqiOn 7/25/07, Yingqi Tang <anakintang@anonymised.com> wrote:
Justin,
Justin
Thanks a lot for the information and I already checkout the geoserver
code. I am also a little curious about the process of generating those
model and binding using EMF and gt2-xmlcodegen, so could you give me
some information on how to generate them independent from the
geoserver project?I hope I didn't trouble you too much on this.
YingqiOn 7/25/07, Justin Deoliveira <jdeolive@anonymised.com> wrote:
> Sure thing.
> They live in the geoserver subversion repository.
> http://svn.codehaus.org/geoserver/trunk/
> In particular:
> http://svn.codehaus.org/geoserver/trunk/geoserver/net.opengis.ows/
> http://svn.codehaus.org/geoserver/trunk/geoserver/net.opengis.wfs/
> The above two are just the models themselves generated from the schema
> http://svn.codehaus.org/geoserver/trunk/geoserver/ows
> http://svn.codehaus.org/geoserver/trunk/geoserver/wfs
> These two modules contain the xml bindings to parse + encode instances
> of the model.
> Check them out and feel free to let me know if you have any more questions.
> -Justin
> Yingqi Tang wrote:
> > That will be great if you could provide more infomation on those
> > modules that you've done, thanks a lot, I really appreciate.
> > Thanks,
> > Yingqi
> > On 7/24/07, Justin Deoliveira <jdeolive@anonymised.com> wrote:
> >> Hmmm. cant say that I do... However it sounds like you are trying to
> >> generate classes from the wfs 1.1 schema? I should let you know that I
> >> have done so successfully in GeoServer... and the result is available
> >> via two GeoServer modules. The classes were generated with emf. If you
> >> want more info about how to get yours hands on them just let me know.
> >> -Justin
> >> Yingqi Tang wrote:
> >> > Justin,
> >> > Do you know how to solve the same problem for "mvn jaxb2:xjc"?
> >> > Thanks
> >> > On 7/24/07, Yingqi Tang <anakintang@anonymised.com> wrote:
> >> >> Thanks a lot!
> >> >> I actually tried and that successfully works around the problem
> >> >>> Hi
> >> >>> Nope you didnt' miss anything... This is a problem with xml schema in
> >> >>> general... usually parsers arent able to resolve schema location
> >> >>> references directly because they don't exist. Luckily there are some
> >> >>> plugin configuration parameters which can help.
> >> >>> What you need to do is download the ows schema somewhere to your hard
> >> >>> disk. It is available from schemas.opengis.net in case you dont
> >> already
> >> >>> know.
> >> >>> Then specify the following in the plugin configuration:
> >> >>> <configuration>
> >> >>> <schemaLookupDirectories>
> >> >>> <schemaLookupDirectory>[directory with
> >> ows.xsd]</schemaLookupDirectory>
> >> >>> </schemaLookupDirectories>
> >> >>> </configuration>
> >> >>> The full reference of plugin configuration parameters is located
> >> here:
> >> http://docs.codehaus.org/display/GEOTDOC/1+Configuration+Parameter+Reference> >>
> >> >>> There are some other parameters which can probably help. Give that
> >> a try
> >> >>> and let me know how it goes.
> >> >>> Also... if we could keep these discussion on the public mailing list
> >> >>> (gt-devel) that would be good. Thanks.
> >> >>> -Justin
> >> >>> Yingqi Tang wrote:
> >> >>>> Justin,
> >> >>>> I was trying to follow the XML development guide to create
> >> binding for
> >> >>>> a schema. The first schema I throw in is wfs.xsd for WFS 1.1.0.
> >> >>>> It seems the path of wfs.xsd can be resolved, but there is relative
> >> >>>> path in wfs.xsd itself like "../../ows/1.0.0/owsAll.xsd", which
> >> causes
> >> >>>> the problem and exception popup saying "Can not resolve schema
> >> >>>> location..."
> >> >>>> Did I miss something?
> >> >>>> Here is the plugin configuration:
> >> >>>> <plugin>
> >> >>>> <groupId>org.geotools.maven</groupId>
> >> >>>> <artifactId>gt2-xmlcodegen</artifactId>
> >> >>>> <version>2.4-SNAPSHOT</version>
> >> >>>> <configuration>
> >> >>>> <schemaLocation>\src\main\xsd\wfs\1.1.0\wfs.xsd</schemaLocation>
> >> <destinationPackage>org.geotools.experiment.wfs2</destinationPackage>
> >> >>>> <constructorArguments>
> >> >>>> <constructorArgument>
> >> >>>> <name>factory</name>
> >> <type>org.geotools.po.ObjectFactory</type>
> >> >>>> </constructorArgument>
> >> >>>> </constructorArguments>
> >> >>>> </configuration>
> >> >>>> </plugin>
> >> >>>> Thanks
> >> >>> Justin Deoliveira
> >> >>> The Open Planning Project
> >> >>> http://topp.openplans.org
> >> > This SF.net email is sponsored by: Splunk Inc.
> >> > Still grepping through log files to find problems? Stop.
> >> > Now Search log events and configuration files using AJAX and a browser.
> >> > Download your FREE copy of Splunk now >> http://get.splunk.com/
> >> > _______________________________________________
> >> > Geotools-gt2-users mailing list
> >> > Geotools-gt2-users@lists.sourceforge.net
> >> > https://lists.sourceforge.net/lists/listinfo/geotools-gt2-users
> >> Justin Deoliveira
> Justin Deoliveira
>!DSPAM:4007,46a8be3910526491211187!
Justin Deoliveira
