[Moving to GeoServer users list]
Nhan,
the matchCase attribute is not permitted on an FES 2.0.0 fes:PropertyIsLike element. If I add matchCase='false' to fes:PropertyIsLike in a working filter, I can reproduce your Geoserver error.
Kind regards,
Ben.
On 16/06/14 20:43, Nhan Vo wrote:
Hi list,
I've just upgraded from Geoserver 2.3.5 to 2.5.1, and the following Get
request does not work any more:
http://localhost:8081/geoserver/wfs?VERSION=2.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=de:entries&FILTER=<fes%3AFilter+xmlns%3Afes%3D'http%3A%2F%2Fwww.opengis.net%2Ffes%2F2.0'+xmlns%3Agml%3D'http%3A%2F%2Fwww.opengis.net%2Fgml%2F3.2'><fes%3APropertyIsLike+matchCase%3D'false'+wildCard%3D'*'+singleChar%3D'%23'+escapeChar%3D'!'><fes%3AValueReference>nokis%3Aname<%2Ffes%3AValueReference><fes%3ALiteral>*<%2Ffes%3ALiteral><%2Ffes%3APropertyIsLike><%2Ffes%3AFilter>
Geoserver gives back the following error:
org.xml.sax.SAXException: Attempted to construct illegal filter - I dont
understand the tag: fes:ValueReference. HINT: tags are case-sensitive!
Attempted to construct illegal filter - I dont understand the tag:
If I however skip the FILTER part in the request, it still works, i.e.
with the following request:
Could someone give me a hint? Thanks!
Best regards,
Nhan
HPCC Systems Open Source Big Data Platform from LexisNexis Risk Solutions
Find What Matters Most in Your Big Data with HPCC Systems
Open Source. Fast. Scalable. Simple. Ideal for Dirty Data.
Leverages Graph Analysis for Fast Processing & Easy Data Exploration
http://p.sf.net/sfu/hpccsystems
GeoTools-GT2-Users mailing list
GeoTools-GT2-Users@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-gt2-users
Ben Caradoc-Davies <Ben.Caradoc-Davies@anonymised.com>
Software Engineer
CSIRO Earth Science and Resource Engineering
Australian Resources Research Centre
Hi Ben,
Thank you for the reply. I switched to version 2.5.1 to check if a bug in WCS was fixed, but it was not. So to avoid the problem asap in our running applications I switched back to version 2.3.5 in which the matchCase was accepted in fes:PropertyIsLike. Perhaps I will try the next Geoserver update.
I've checked with WFS 2.0.0 specification and it seems indeed the matchCase attribute does not exist for fes:PropertyIsLike. I am not sure if this is most desirable
Thanks again for your useful info.
Best regards,
Nhan
Nhan,
Kind regards,
Ben.
Hi list,
Best regards,
Nhan
*Thanh-Trong-Nhan Vo*
smile consult GmbH
Vahrenwalder Straße 4
D-30165 Hannover
Tel:
0511/543617-46
Fax:
0511/543617-66
Mail:
nhanvo@anonymised.com <mailto:nhanvo@anonymised.com>
Internet:
http://www.smileconsult.de/>
Geschäftsführer: Frank Sellerhoff •Peter Milbradt •Christoph Lippert
USt-IdNr.: DE208857046 •Amtsgericht Hannover HRB 58707
PS: Sorry I mean Filter 2.0
On 6/17/2014 8:51 AM, Nhan Vo wrote:
Hi Ben,
Best regards,
Nhan
Nhan,
Kind regards,
Ben.
Hi list,
http://localhost:8081/geoserver/wfs?VERSION=2.0.0&SERVICE=WFS&REQUEST=GetFeature&TYPENAME=de:entries&FILTER=<fes%3AFilter+xmlns%3Afes%3D'http%3A%2F%2Fwww.opengis.net%2Ffes%2F2.0'+xmlns%3Agml%3D'http%3A%2F%2Fwww.opengis.net%2Fgml%2F3.2'><fes%3APropertyIsLike+matchCase%3D'false'+wildCard%3D'*'+singleChar%3D'%23'+escapeChar%3D'!'><fes%3AValueReference>nokis%3Aname<%2 Ffes%3AValueReference%3E%3Cfes%3ALiteral%3E*%3C%2Ffes%3ALiteral%3E%3C%2Ffes%3APropertyIsLike%3E%3C%2Ffes%3AFilter%3E
Best regards,
Nhan
