[Geoserver-users] [Geotools-gt2-users] WFSDemo does not work with some of the data
When i make getFeature request to shp layer, the response from server is fine. But, when I make request postgres layer created from this shp file the response is like this:
<ows:ExceptionReport version=“1.0.0” xsi:schemaLocation=“http://www.opengis.net/ows http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd”>
<ows:Exception exceptionCode=“NoApplicableCode”>
ows:ExceptionTextjava.lang.NullPointerException
null</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
This happens also when I make request to some other shp layers.
do you have any idea, where the problem might be?
Kuba
On Thu, Jul 29, 2010 at 3:47 PM, Jody Garnett <jody.garnett@anonymised.com> wrote:
GeoServer also has a “demo request” page where you can issue the requests yourself and look at the result.
Jody
On 29/07/2010, at 7:31 PM, Roy Braam wrote:
Jakub,
Can you check the network activity between geotools and the wfs server? Most of the times it helps to understand the problem.
Roy
From: Jakub Rojek [mailto:kuba.rojek@anonymised.com]
To: GeoTools [mailto:geotools-gt2-users@anonymised.com.net]
Sent: Thu, 29 Jul 2010 11:01:42 +0200
Subject: [Geotools-gt2-users] WFSDemo does not work with some of the data
Hi!
I was trying out WFS demo available on GeoTools User Guide Wiki web site http://docs.codehaus.org/display/GEOTDOC/WFS+Plugin.
The problem is that it works only with some of the data. Mostly with those that come along with Geoserver instalation. The problem appears when I use the demo on the data that are stored in POSTGIS data bank.
I realy do not know where is the problem. NetBeaans indicate that there is NullPoIntException in this code line:
FeatureReader ft = wfs.getFeatureReader(query, Transaction.AUTO_COMMIT);
this the whole error message that I get when I run the WFSDemo:
29.07.2010 10:56:31 org.geotools.xml.XMLSAXHandler processException
SCHWERWIEGEND: java.lang.NullPointerException
null org.geotools.xml.filter.FilterComplexTypes$ServiceExceptionType.getValue(FilterComplexTypes.java:1669)
org.geotools.xml.handlers.ComplexElementHandler.endElement(ComplexElementHandler.java:157)
org.geotools.xml.XMLSAXHandler.endElement(XMLSAXHandler.java:266)
org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanEndElement(Unknown Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
javax.xml.parsers.SAXParser.parse(SAXParser.java:198)
org.geotools.xml.DocumentFactory.getInstance(DocumentFactory.java:140)
org.geotools.data.wfs.v1_0_0.WFSFeatureReader.run(WFSFeatureReader.java:125)
29.07.2010 10:56:31 org.geotools.xml.XMLSAXHandler endElement
WARNUNG: java.lang.NullPointerException
null
WARNUNG: Line 10 Col 20
29.07.2010 10:56:31 org.geotools.data.wfs.v1_0_0.NonStrictWFSStrategy createFeatureReaderPOST
WARNUNG: java.io.IOException: org.geotools.ows.ServiceException: java.lang.NullPointerException
null
null
29.07.2010 10:56:31 org.geotools.data.wfs.v1_0_0.NonStrictWFSStrategy createFeatureReaderGET
null
Exception in thread “main” java.io.IOException: org.geotools.ows.ServiceException: java.lang.NullPointerException
null
at org.geotools.xml.gml.FCBuffer.hasNext(FCBuffer.java:326)
at org.geotools.data.wfs.v1_0_0.WFSFeatureReader.loadElement(WFSFeatureReader.java:189)
at org.geotools.data.wfs.v1_0_0.WFSFeatureReader.hasNext(WFSFeatureReader.java:178)
at org.geotools.data.wfs.v1_0_0.NonStrictWFSStrategy.createFeatureReaderGET(NonStrictWFSStrategy.java:134)
at org.geotools.data.wfs.v1_0_0.NonStrictWFSStrategy.createFeatureReader(NonStrictWFSStrategy.java:101)
at org.geotools.data.wfs.v1_0_0.NonStrictWFSStrategy.getFeatureReader(NonStrictWFSStrategy.java:72)
at org.geotools.data.wfs.v1_0_0.WFS_1_0_0_DataStore.getFeatureReader(WFS_1_0_0_DataStore.java:747)
at iosb.fraunhofer.de.geotools.WFSDemo.main(WFSDemo.java:51)
Caused by: org.geotools.ows.ServiceException: java.lang.NullPointerException
null
at org.geotools.xml.XMLSAXHandler.endElement(XMLSAXHandler.java:274)
at org.apache.xerces.parsers.AbstractSAXParser.endElement(Unknown Source)
at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanEndElement(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
at org.apache.xerces.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:198)
at org.geotools.xml.DocumentFactory.getInstance(DocumentFactory.java:140)
at org.geotools.data.wfs.v1_0_0.WFSFeatureReader.run(WFSFeatureReader.java:125)
null
at org.geotools.xml.filter.FilterComplexTypes$ServiceExceptionType.getValue(FilterComplexTypes.java:1669)
at org.geotools.xml.handlers.ComplexElementHandler.endElement(ComplexElementHandler.java:157)
at org.geotools.xml.XMLSAXHandler.endElement(XMLSAXHandler.java:266)
… 13 more
Java Result: 1
The Palm PDK Hot Apps Program offers developers who use the
Plug-In Development Kit to bring their C/C++ apps to Palm for a share
of $1 Million in cash or HP Products. Visit us here for more details:
http://p.sf.net/sfu/dev2dev-palm_______________________________________________
Geotools-gt2-users mailing list
Geotools-gt2-users@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geotools-gt2-users
It looks like a java error in your server, the server is returning a ServiceExceptionReport maybe you can look at the logs of the server? It could be some unexpected corrupt data?
Roy
To: Jody Garnett [mailto:jody.garnett@anonymised.com], GeoServer [mailto:geoserver-users@lists.sourceforge.net]
Sent: Thu, 29 Jul 2010 16:36:10 +0200
Subject: Re: [Geoserver-users] [Geotools-gt2-users] WFSDemo does not work with some of the data
</ows:Exception>
Kuba
Jody
Jakub,
Roy
To: GeoTools [mailto:geotools-gt2-users@lists.sourceforge.net]
Hi!
null
null
null
null
null
null
null
… 13 more
Java Result: 1
Sounds like a configuration problem; you can set up geoserver to have
more information in the response; or check the geoserver logs.
On Fri, Jul 30, 2010 at 12:36 AM, Jakub Rojek <kuba.rojek@anonymised.com> wrote:
<ows:ExceptionReport version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/ows
http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd&quot;&gt;
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>java.lang.NullPointerException
</ows:Exception>
Kuba
wrote:
GeoServer also has a "demo request" page where you can issue the requests
Jody
Jakub,
Roy
Hi!
null
Source)
Source)
Source)
Source)
null
null
null
Source)
Source)
Source)
Source)
null
null
Exception in thread "main" java.io.IOException:
null
        at
        at
        at
        at
        at
        at
null
        at
Source)
        at
Source)
        at
Source)
        at
Source)
Source)
Source)
Source)
        at
        at
        at
null
        at
        at
        at
        ... 13 more
Java Result: 1
Best Open Source Mac Front-Ends 2024
geotools-gt2-users List Signup and Options
