I recently upgraded from 2.3.5 to 2.4.x and GeoWebCache no longer asks me if I want to create a separate cache for each time step when I go to the tiling tab. Has this functionality disappeared, become the default, or just moved somewhere else that I haven’t spotted?
Ian
Ian Turton
moved somewhere else that I haven't spotted?
I believe Kevin (cc'ed) changed the param filters section to be open ended,
so you
should be able to add a time and elevation parameters that way
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
Yes, this has been replaced with the Parameter Filter editor. Create a regular expression parameter filter for the TIME parameter, and set the regexp to “.*” (not including quotes) and you’ll have the same result as you would have by selecting the old check box. Now you can be more specific though by specifying your own regexp, or providing a list of specific values, and you can create filters for any parameters you want, not just TIME, ELEVATION, and STYLE.
On 1 December 2013 06:50, Andrea Aime <andrea.aime@anonymised.com> wrote:
Kevin Smith
Junior Software Engineer | Boundless
ksmith@anonymised.com
+1-778-785-7459
@boundlessgeo
I believe Kevin (cc’ed) changed the param filters section to be open ended, so you
Ing. Andrea Aime
@geowolf
Technical Lead
