Hi List,
I’m looking at my GetCapabilities xml from GWC: http://myserver/geoserver/gwc/service/wms?request=GetCapabilities and I see the bounding boxes of my layers are as expected:
I also have two grouped layers, those bounding boxes are not OK. The SRS is set properly but the coordinates are in WGS84:
Why is that and how can I fix it?
I couldn’t find something in the webadmin for this.
Paul
Hi Paul,
You should be able to set layergroup SRS.
http://docs.geoserver.org/stable/en/user/webadmin/data/layergroups.html?highlight=layer%20group#edit-layer-group
Jonathan
On 3 July 2013 14:26, Paul Meems <bontepaarden@anonymised.com> wrote:
Hi List,
Paul
This SF.net email is sponsored by Windows:
Build for Windows Store.
http://p.sf.net/sfu/windows-dev2dev
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Thanks Jonathan,
I’ve checked and my grouped layers bbox are OK.
So I checked the GetCapabilities again and I can no longer reproduce.
I don’t what happened but my issue is solved!
Great way to start the weekend
Paul
Paul Meems
Release manager, configuration manager
and forum moderator of MapWindow GIS.
www.mapwindow.org
Owner of MapWindow.nl - Support for
Dutch speaking users.
www.mapwindow.nl
2013/7/5 Jonathan Moules <jonathanmoules@anonymised.com>
Hi Paul,
Jonathan
Hi List,
Paul
