[Geoserver-users] GeoWebCache configuration in GeoNode
I have a GeoNode 2.4.x running with a GeoServer 2.7-snapshot.
Since there is no gwc folder inside the GeoServer data folder I wonder where
GWC stores the cached tiles. In addition I can't find the geowebcache.xml
file.
Thanks in advanced for your help.
Best,
Paolo
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoWebCache-configuration-in-GeoNode-tp5284549.html
I am not familiar with geonode so this may or may not be helpful. A quick web search indicates to me the when setting up geoserver for geonode geoserver runs under tomcat. If your geoserver is running under tomcat gwc is set up in /webapps/geoserver/WEB_INF/web.xml and will look something like this
<context-param>
   <param-name>GEOSERVER_DATA_DIR</param-name>
   <param-value>C:\geoserver\data_dir</param-value>
</context-param>
-----Original Message-----
From: Paolo Pasquali [mailto:paolo.pasquali@anonymised.com]
Sent: Wednesday, September 07, 2016 11:23 AM
Subject: [Geoserver-users] GeoWebCache configuration in GeoNode
Since there is no gwc folder inside the GeoServer data folder I wonder where GWC stores the cached tiles. In addition I can't find the geowebcache.xml file.
Best,
Paolo
Geoserver-users mailing list
Ralph,
the GWC documentation says so. I guess that if I want to set a different folder for the cached tiles I have to add this to the web.xml:
GEOWEBCACHE_CACHE_DIR /my/new/gwc/folder/
By default it is not set in web.xml. And if it is not set, according to the documentation, the gwc tiles folder should be in the geoserver/data folder. But it is not.
I have a lot of cached tiles somewhere and I want to move them but I cannot find them.
GEOSERVER_DATA_DIR C:\geoserver\data_dir
From: Paolo Pasquali [mailto:paolo.pasquali@anonymised.comcom]
To: geoserver-users@anonymised.comsourceforge.net
Since there is no gwc folder inside the GeoServer data folder I wonder where GWC stores the cached tiles. In addition I can’t find the geowebcache.xml file.
Best,
Paolo
Geoserver-users@anonymised.com.382…sourceforge.net
You can just use JVM properties like
-DGEOWEBCACHE_CACHE_DIR=<path_to_tile_cache>
and
-DGEOSERVER_DATA_DIR=<path_to_geoserver_config_dir>
in order to move your folders somewhere else in the system.
On Wed, Sep 7, 2016 at 6:05 PM, Paolo Pasquali <paolo.pasquali@anonymised.com> wrote:
Ralph,
Best Regards,
Alessio Fabiani.
Visit http://goo.gl/it488V for more information.
Ing. Alessio Fabiani
@alfa7691
Founder/Technical Lead
Via di Montramito 3/A
mob: +39 331 6233686
From: Paolo Pasquali [mailto:paolo.pasquali@anonymised.comom]
To: geoserver-users@anonymised.comrge.net
Best,
Paolo
Geoserver-users@anonymised.comrge.net
