On Mon, Jan 25, 2016 at 8:46 AM, Derek Watling <derek@anonymised.com> wrote:
Problem solved: On the GeoServer web administration interface "Tile
Caching"
> "Caching Defaults", "Enable Data Security" was ticked. Simply un-ticking
this option makes the grouped layer work.
Oh, that's interesting? Do you have any data access restrictions setup in
your server?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
