I am moving this one to the geoserver-users list, please make sure you're subscribed if you want follow ups.
I have a fresh install of 1.7.1, and my seed buttons are working fine. Is anyone else observing either case ?
All the links are defined as "./{layer name}" , so I don't see how it could be refering to /geowebcache or anything like that. Please check the source of the HTML.
Regarding S3, there is a patch in Trac that lets you do that. Will probably go into 1.1.
Sidebug:
The first seed sometimes bombs out with "Invalid request, unknown location". I have not been able to debug this because Eclipse somehow gets all the line numbers wrong (steps through whitespace). It goes away if you repeat the request.
-Arne
Landmine Mapper wrote:
Greetings,
Regarding the GeoWebCache Seeding Mechanism ¶
Option 1: Use the web interface ¶GeoWebCache now has a built-in seeding mechanisms than utilizes simple forms. You can access this through the "Dynamic list of demos" screen by clicking the "Seed this Layer" link, or directly:
http://localhost:8080/geowebcache/rest/layername/seed/
However if you use the GeoWebCache plugin for Geoserver 1.7.1
the link (and seed buttons) are not correct....They should be:
http://localhost:8080/geoserver/gwc/rest/seed/topp:states*P.S. It would be really awesome if the seeded tiles produced where formatted correctly so that they could be also be redistributed/copied to Amazon S3 or other cloud server...
Landmine
------------------------------------------------------------------------_______________________________________________
Geowebcache-devel mailing list
Geowebcache-devel@lists.sourceforge.net
https://lists.sourceforge.net/lists/listinfo/geowebcache-devel
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
