[Geoserver-users] geowebcache security
I’d like to prevent anonymous users from seeing the list of layers in the geowebcache.
I’ve tried:
· Creating service access rule for gwc.* that allows only admin to access it
· Setting catalog mode to “Hide”
· Setting data rules so that no workspaces can be accessed by anonymous
But in all these cases, GWC will still list the layers and only challenge when you try and seed htem. Is there a way to prevent GWC from listing all the layers in geoserver?
On Thu, Mar 19, 2015 at 8:58 PM, Justin Pierre <jpierre@anonymised.com>
the geowebcache.
I’ve tried:
to access it
anonymous
I believe only modifying GWC code so that also the capabilities part is
aware of the security restrictions is the only way to go
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
I agree, this requires an up-stream change in GWC’s API. It is a good idea, and could probably be combined with adding support for virtual services as both require providing filtered views of the catalogue.
On 24 March 2015 at 10:21, Andrea Aime <andrea.aime@anonymised.com> wrote:
Dive into the World of Parallel Programming The Go Parallel Website, sponsored
by Intel and developed in partnership with Slashdot Media, is your hub for all
things parallel software development, from weekly thought leadership blogs to
news, videos, case studies, tutorials and more. Take a look and join the
conversation now. http://goparallel.sourceforge.net/
Geoserver-users mailing list
On Thu, Mar 19, 2015 at 8:58 PM, Justin Pierre <jpierre@anonymised.com> wrote:
I’ve tried:
I believe only modifying GWC code so that also the capabilities part is aware of the security restrictions is the only way to go
Ing. Andrea Aime
@geowolf
Technical Lead
Kevin Smith
Software Engineer | Boundless
ksmith@anonymised.com
+1-778-785-7459
@boundlessgeo
http://boundlessgeo.com/
