All,
I am trying without success to seed a layer in geowebcache.
Here is the url I am using to do the seeding:
http://127.0.0.1:8080/geowebcache/seed?layers=map&start=12&stop=14
When I enter this url into firefox, I see this...
Seeding map from level 12 to level 14 for format image/png and bounds Min X:
-2.003750834E7 Min Y: -2.003750834E7 Max X: 2.003750834E7 Max Y:
2.003750834E7
Level 12, ~672400 metatile(s) [16777216 tile(s)]
0,
and then it stops.
When use curl I see this:
[pmccullough@anonymised.com ~]$ curl
"http://10.1.15.73:8080/geowebcache/seed?layers=map&start=12&stop=14"
<html><body><table><tr><td>Seeding map from level 12 to level 14 for format
image/png and bounds Min X: -2.003750834E7 Min Y: -2.003750834E7 Max X:
2.003750834E7 Max Y: 2.003750834E7</td></tr><tr><td>Level 12, ~672400
metatile(s) [16777216 tile(s)]</td></tr><tr><td>0, [pmccullough@anonymised.com ~]$
and I am suddenly back at the command prompt.
Here is the stack trace in the tomcat logfile:
INFO: Initializing Spring FrameworkServlet 'geowebcache'
Aug 13, 2008 8:57:05 AM org.apache.catalina.core.StandardWrapperValve
invoke
SEVERE: Servlet.service() for servlet geowebcache threw exception
java.lang.IllegalStateException: getWriter() has already been called for
this response
at
org.apache.catalina.connector.Response.getOutputStream(Response.java:579)
at
org.apache.catalina.connector.ResponseFacade.getOutputStream(ResponseFacade.java:183)
at
org.geowebcache.GeoWebCacheDispatcher.writeError(GeoWebCacheDispatcher.java:381)
at
org.geowebcache.GeoWebCacheDispatcher.handleRequestInternal(GeoWebCacheDispatcher.java:156)
at
org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:153)
at
org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:48)
at
org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:874)
at
org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:808)
at
org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:523)
at
org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:453)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:690)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at
org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at
org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at
org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at
org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
at
org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at
org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at
org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at
org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at
org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
at
org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at
org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Unknown Source)
I see no output to the geoserver log file.
Here is the layer definition in geowebcache:
#Type, determines configuration parser
layername=map
type=wms
# Backend
wmsurl=http://localhost:8080/geoserver/wms
wmslayers=layer-group_map
# Tile profile
mimetypes=image/png
palette=sfmaps
srs=EPSG:900913
grid=-20037508.34,-20037508.34,20037508.34,20037508.34
bbox=-20037508.34,-20037508.34,20037508.34,20037508.34
width=256
height=256
version=1.1.0
errormime=application/vnd.ogc.se_inimage
tiled=false
transparent=true
metatiling=5x5
debugheaders=true
# Cache backend settings
cacheprefix=c:\\geowebcache\\map
This config works properly using openlayers; images get cached, etc.
I am careful to delete c:\\geowebcache\\ ech time through.
I am careful to restart tomcat.
My environment is
- geowebcache 0.8.4
- geoserver 1.6.3
- java 1.6.0_05
- tomcat 6.0.16
- windows xp sp2
Paul
View this message in context: http://www.nabble.com/geowebcache---seeding---java.lang.IllegalStateException%3A-getWriter()-has-already-been-called-for-this-response-tp18969233p18969233.html
