[Geoserver-users] GeoWebCache seeding
I have a PostGIS tiled layer that contains north-america OSM data. I tried
to seed it using GeoWebCache. Below are the seeding parameters:
Number of tasks: 4
Type of operation: Reseed
Gridset: EPSG:4326 (Dataset SRS: EPSG:3857)
Format: png8
Zoom start: 0
Zoom stop: 15
Style : polygon
BBox: -180 -91 180 91
MetaTilingFactor: 6x6
WMS Max Redening Time: 12000 (anticipate the seeding will take long)
After I entered submit, I saw this in Tomcat log:
14 Feb 13:18:49 INFO [seed.SeedTask] - GWC Seeder Thread-5 begins seeding
layer : osm:north_america_polygon
14 Feb 13:18:49 INFO [seed.SeedTask] - GWC Seeder Thread-6 begins seeding
14 Feb 13:18:49 INFO [seed.SeedTask] - GWC Seeder Thread-8 begins seeding
14 Feb 13:18:49 INFO [seed.SeedTask] - GWC Seeder Thread-7 begins seeding
Did not see anything showed up on the log until after about 3 hours, the
following messages showed up:
14 Feb 16:34:06 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: This requested used more time than
allowed and has been forcefully stopped. Max rendering time is 12000.0s
        at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:499)
        at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:251)
        at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:123)
        at org.geoserver.wms.GetMap.executeInternal(GetMap.java:521)
        at org.geoserver.wms.GetMap.run(GetMap.java:253)
        at org.geoserver.wms.GetMap.run(GetMap.java:124)
        at
org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:328)
        at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
14 Feb 16:34:06 ERROR [seed.MTSeeder] - Problem communicating with GeoServer
org.geowebcache.GeoWebCacheException: Problem communicating with GeoServer
        at
org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:517)
        at
org.geoserver.gwc.layer.GeoServerTileLayer.seedTile(GeoServerTileLayer.java:706)
        at org.geowebcache.seed.SeedTask.doActionInternal(SeedTask.java:136)
        at org.geowebcache.seed.GWCTask.doAction(GWCTask.java:76)
        at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:36)
        at org.geowebcache.seed.MTSeeder.call(MTSeeder.java:25)
        at java.util.concurrent.FutureTask.run(FutureTask.java:262)
        at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
        at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
        at java.lang.Thread.run(Thread.java:744)
Caused by: java.lang.IllegalStateException: Expected: RenderedImageMap, got
null
        at
org.geoserver.gwc.layer.GeoServerTileLayer.dispatchGetMap(GeoServerTileLayer.java:570)
        at
org.geoserver.gwc.layer.GeoServerTileLayer.getMetatilingReponse(GeoServerTileLayer.java:512)
        ... 9 more
Caused by:
org.geotools.referencing.operation.projection.ProjectionException: Latitude
90°10.5'S is too close to a pole.
        at
org.geotools.referencing.operation.projection.Mercator$Spherical.transformNormalized(Mercator.java:209)
        at
org.geotools.referencing.operation.projection.MapProjection.transform(MapProjection.java:883)
        at
org.geotools.referencing.operation.projection.MapProjection.transform(MapProjection.java:924)
        at
org.geotools.referencing.operation.transform.AbstractMathTransform.transform(AbstractMathTransform.java:237)
        at org.geotools.referencing.CRS.transform(CRS.java:1319)
        at org.geotools.referencing.CRS.transform(CRS.java:1385)
        at
org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:678)
        at
org.geotools.renderer.crs.ProjectionHandler.getQueryEnvelopes(ProjectionHandler.java:133)
        at
org.geotools.renderer.lite.StreamingRenderer.getStyleQuery(StreamingRenderer.java:1048)
        ... 47 more
14 Feb 16:34:06 ERROR [geotools.rendering] - Error transforming bbox
java.lang.Exception: Error transforming bbox
        at
org.geotools.renderer.lite.StreamingRenderer.getStyleQuery(StreamingRenderer.java:1068)
        at
org.geotools.renderer.lite.StreamingRenderer.processStylers(StreamingRenderer.java:2009)
        at
org.geotools.renderer.lite.StreamingRenderer.paint(StreamingRenderer.java:837)
        at
org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:481)
        at
        at
Caused by:
        at
        at
        at
        at
        at
        at
        at
        ... 47 more
14 Feb 16:34:06 WARN [geotools.rendering] - Got a tranform exception while
trying to de-project the current envelope, falling back on full data loading
(no bbox query)
        at
        at
        at
        at
        at
        at
I have no ideas what went wrong and appreciate someone can tell what I did
wrong. I need to be able to seed the layer. Otherwise, the performance
will be unacceptable.
Many thanks in advance.
Tam
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoWebCache-seeding-tp5103935.html
Hi Tam,
I’ve had similar. For whatever reason GeoServer was unable to render one of the tiles within the rendering time (12,000 seconds!!).
From this line:
When this happens, the entire tiling thread that called that request then gets cancelled and thus GeoServer doesn’t even bother trying. That’s what this line means:
So the real question is - why is one of your tiles failing to render in 12,000 seconds (3.3hrs!).
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
I suspect this is the root cause:
Caused by:
90°10.5’S is too close to a pole.
On 15 February 2014 01:59, tt5430 <tt9488@anonymised.com> wrote:
Number of tasks: 4
Format: png8
Zoom start: 0
Zoom stop: 15
Style : polygon
at
at
at
at
at
at
at
at
at
null
at
at
… 9 more
Caused by:
at
at
at
at
at
at
at
… 47 more
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
at
… 47 more
(no bbox query)
at
at
at
at
at
at
Tam
Managing the Performance of Cloud-Based Applications
Take advantage of what the Cloud has to offer - Avoid Common Pitfalls.
Read the Whitepaper.
http://pubads.g.doubleclick.net/gampad/clk?id=121054471&iu=/4140/ostg.clktrk
Geoserver-users mailing list
You’ve got a value slightly larger than 90 for your North/South. Looking at your BBOX, you have:
Try using just 90. In fact, you shouldn’t even need to declare a BBOX if you’re doing the entire planet so just leave it blank.
Jonathan
Hi Jonathan,
Thanks for your response. In fact I had tried previously without entering
anything in the BBOX and got the same "too close to pole" error. That was
why I tried to enter -91 and 91 values in the BBOX in hope that it would fix
the problem. This error only happened when I chose Grid set "EPSG: 4326"
and the OSM data was imported using EPSG: 3857. I did not get the "too
close to pole" error if I chose Girdset EPSG: 900913 which is basically the
same as EPSG: 3857. Was it because GeoServer tried to re-project the data
into EPSG: 4326 and got that error because some of the north-america OSM
data is too close to pole? My question is do I have the use the Grid set
that is compatible with with OSM data SRS?
Tam
View this message in context: http://osgeo-org.1560.x6.nabble.com/GeoWebCache-seeding-tp5103935p5104748.html
You might want to check the bounds that the layer is using as well since one error shows you have a latitude that is 90°10.5’S
“Caused by:
90°10.5’S is too close to a pole.”
Chris Snider
Senior Software Engineer
Intelligent Software Solutions, Inc.
Description: Description: Description: cid:image001.png@anonymised.com
Hi Tam,
From this line:
Caused by:
Jonathan
Number of tasks: 4
Format: png8
Zoom start: 0
Zoom stop: 15
Style : polygon
at
at
at
at
at
at
at
at
at
null
at
at
… 9 more
Caused by:
at
at
at
at
at
at
at
… 47 more
at
at
at
at
at
at
Caused by:
at
at
at
at
at
at
at
… 47 more
(no bbox query)
at
at
at
at
at
at
Tam
