I have created a map with geoserver and postgresSQL. I have managed in
geoserver to seed the layers into tiles but for some reason as you view
across the map, it does not create those tiles. For instance, if I seeded
the layer till zoom 11 and wanted to view at zoom level 20, I could but it
does not seem to create the tiles for a later stage nor make it more
effective or faster. Also when I set a bounding area in the seeding form
section, it gives me http 500 error and I'm not sure why.
I have set up geoserver and placed the folder for the tiles for the
geowebcache.
I am using the intergrated geowebcache that comes with geoserver. The logs
don't seem to show if there is something wrong.
I am using OpenLayers and programmed in to allow to see the full map with
several layers.
It uses this to access the map: 192.168.1.56/geoserver/test/gwc/service/wms
just to make sure: Do the resolutions for your OpenLayers map match the resolutions set for the gridset of your cached layer? You can get the list of resolutions for example by opening the preview of the cached layer you're interested in (Tile Caching section in the Web Interface > Locate the Layer > Select the Gridset you are interested in (will open the Layer Preview of this layer in this gridset) > Open the source and check if the resolutions array in the source matches the one configured in your OpenLayers application, if configured).
Max
________________________________________
Von: Ravyn <smrcoutts24@anonymised.com>
Gesendet: Dienstag, 9. September 2014 15:07
An: geoserver-users@lists.sourceforge.net
Betreff: [Geoserver-users] Geowebcache tiles showing only when seeding and not when viewing the map
geowebcache.
several layers.
Meet PCI DSS 3.0 Compliance Requirements with EventLog Analyzer
Achieve PCI DSS 3.0 Compliant Status with Out-of-the-box PCI DSS Reports
Are you Audit-Ready for PCI DSS 3.0 Compliance? Download White paper
Comply to PCI DSS 3.0 Requirement 10 and 11.5 with EventLog Analyzer http://pubads.g.doubleclick.net/gampad/clk?id=154622311&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
