[Geoserver-users] Geowebcache Time Interval
Dear Users,
How to assign time interval to take regular cache using geowebche. For instance every afternoon at 13:00 hrs geowebcache should be started automatically and it should start creating tiles. ?
S. Thiruvikraman M.Sc.,
Ph: +919746149212 , +919003419957
Set up a batch/bash script and use task schedular/cron depending on your system.
GWC has a REST interface, so the script can call curl for the URLs.
Here is the batch file I use to rebuild various tiles - it’s actually fairly complicated as I found I was acquiring lots of different scripts for different datasets; this amalgamates them - you’ll need CURL in the same directory to run it.
http://pastebin.com/q4LKbyJ9
Feel free to tweak it to your needs.
The RESTful interface has some documentation on the Geoserver docs.
Jonathan
On 26 February 2014 05:15, Vikram Santhanam <vikraman.gis@anonymised.com> wrote:
Dear Users,
Flow-based real-time traffic analytics software. Cisco certified tool.
Monitor traffic, SLAs, QoS, Medianet, WAAS etc. with NetFlow Analyzer
Customize your own dashboards, set traffic alerts and generate reports.
Network behavioral analysis & security monitoring. All-in-one tool.
http://pubads.g.doubleclick.net/gampad/clk?id=126839071&iu=/4140/ostg.clktrk
Geoserver-users mailing list
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
