Hi Alejandro,
so let’s make some order:
- you have updae the the issue occurs only when you create a layers
group? Did I get you well? Have you try to create a group of layers
properly all the parameters in the configuration section? I mean in
particular
Let me know.
Regards
Michele
El 08/07/13 16:41, Michele Beneventi escribió:
Hi Alejandro,
I’m not really sure, of course, but this problem sounds strange because
the geowebcache is embedded in geoserver and these two CRS are the default
ones.
I can confirm this because I also have a such configuration.
Have you made any update or migration activity?
yes i upgrade from geoserver 2.1.4 to 2.3.2 but all ir running normal
Anyway:
- In the “Caching Defaults” as well as in “Gridsets” sections there
should be the two gridsets;
yes they are there
- The layers must be available also in the “Tile Layers” section;
they are there too
- Can you see the specific EPSG preview of the layers at the automatic
demos’s page?
/myServer/geoserver/gwc/demo
yess, the problem comes when using openlayers i made a group that of
layers that do that.
thanks
regards
Michele
Hi michele, i change the log format of my geoserver and i get this that i
think that it have to do with all the trouble, here are the logs:
INFO | jvm 1 | 2013/07/09 15:00:22 | 09 jul 15:00:22 DEBUG
[jdbc.JDBCQuotaStore] - Creating tileset
TileSet[une:ASTGTM2_N23W081_dem#EPSG:4326#image/jpeg]
[referencing.factory] - Error en la fábrica primaria: No se ha encontrado
ningún código “EPSG:900913” de autoridad “European Petroleum Survey Group”
para el objeto de tipo “IdentifiedObject”. La fabrica secundaria será
interrogada.
para el objeto de tipo “CoordinateReferenceSystem”. La fabrica secundaria
será interrogada.
ningún código “EPSG:900913” de autoridad “EPSG” para el objeto de tipo
“EngineeringCRS”. La fabrica secundaria será interrogada.
[grid.BoundingBox] - Created BBOX: Min X: -2.003750834E7 Min Y:
-2.003750834E7 Max X: 2.003750834E7 Max Y: 2.003750834E7
[gwc.layer] - Can’t compute tile layer bouds out of resource native bounds
for CRS EPSG:900913
INFO | jvm 1 | 2013/07/09 15:00:22 | java.lang.NullPointerException:
Unable to transform referenced envelope, crs has not yet been provided.
INFO | jvm 1 | 2013/07/09 15:00:22 | at
org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:658)
org.geoserver.gwc.layer.GeoServerTileLayer.getBounds(GeoServerTileLayer.java:824)
java.lang.Thread.run(Unknown Source)
[gwc.layer] - Can’t compute bounds for tile layer
une:sigfre_cub_Adm_RiosPrinc in CRS EPSG:900913. Assuming full GridSet
bounds. (null)
org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:661)
org.geoserver.gwc.layer.GeoServerTileLayer.getBounds(GeoServerTileLayer.java:844)
org.geoserver.gwc.layer.GeoServerTileLayer.getGrids(GeoServerTileLayer.java:767)
org.geoserver.gwc.layer.GeoServerTileLayer.checkGridSubsets(GeoServerTileLayer.java:712)
org.geoserver.gwc.layer.GeoServerTileLayer.getGridSubsets(GeoServerTileLayer.java:698)
org.geowebcache.diskquota.storage.TilePageCalculator.getTileSetsFor(TilePageCalculator.java:111)
org.geowebcache.diskquota.jdbc.JDBCQuotaStore$2.doInTransactionWithoutResult(JDBCQuotaStore.java:230)
[grid.BoundingBox] - Created BBOX: Min X: 0.0 Min Y: 0.0 Max X: -1.0 Max Y:
-1.0
ningún código “EPSG:3857” de autoridad “European Petroleum Survey Group”
interrogada.
[geotools.parameter] - Axis length mismatch.
ningún código “EPSG:3785” de autoridad “European Petroleum Survey Group”
interrogada.
for CRS EPSG:4326
org.tanukisoftware.wrapper.WrapperSimpleApp.run(WrapperSimpleApp.java:238)
une:sigfre_cub_Adm_RiosPrinc in CRS EPSG:4326. Assuming full GridSet
bounds. (null)
[grid.BoundingBox] - Created BBOX: Min X: -180.0 Min Y: -90.0 Max X: 180.0
Max Y: 90.0
Max Y: 90.0
-1.0
Max Y: 90.0
TileSet[une:sigfre_cub_Adm_RiosPrinc#EPSG:4326#image/png]
TileSet[une:sigfre_cub_Adm_RiosPrinc#EPSG:900913#image/png]
TileSet[une:sigfre_cub_Adm_RiosPrinc#EPSG:4326#image/jpeg]
TileSet[une:sigfre_cub_Adm_RiosPrinc#EPSG:900913#image/jpeg]
[gwc.layer] - Depersisting GeoServerTileLayerInfo from C:\Archivos de
programa\GeoServer
2.3.2\data_dir\gwc-layers\LayerInfoImpl–570ae188_124761b8d78_-7fb0.xml
[referencing.factory] - Failed to create an object for code “8647”.
org.opengis.referencing.NoSuchIdentifierException: Could not locate NTv2
Grid File NTv2_0.gsb
org.geotools.referencing.operation.transform.NTv2Transform.(NTv2Transform.java:117)
INFO | jvm 1 | 2013/07/09 15:00:22 | 09 jul 15:00:22 TRACE
[referencing.factory] - Error en la creación de una transformación de
coordenadas según la autoridad “European Petroleum Survey Group”.
INFO | jvm 1 | 2013/07/09 15:00:23 | 09 jul 15:00:22 DEBUG
[grid.BoundingBox] - Created BBOX: Min X: -1.1562867513204884E7 Min Y:
5522913.211891563 Max X: -1.1535963887183946E7 Max Y: 5543400.923533295
-1.0
INFO | jvm 1 | 2013/07/09 15:00:23 | at
INFO | jvm 1 | 2013/07/09 15:00:23 | 09 jul 15:00:23 DEBUG
[referencing.factory] - Failed to create an object for code “8585”.
INFO | jvm 1 | 2013/07/09 15:00:23 | 09 jul 15:00:23 TRACE
[grid.BoundingBox] - Created BBOX: Min X: -103.87100615361031 Min Y:
44.37021187004215 Max X: -103.62932676908186 Max Y: 44.50162561960653
Max Y: 90.0
TileSet[une:sigfre_cub_Conv_lineas220#EPSG:4326#image/jpeg]
programa\GeoServer
2.3.2\data_dir\gwc-layers\LayerInfoImpl–7cdc5a5c_13d358d423c_-7fbb.xml
[grid.BoundingBox] - Created BBOX: Min X: -9350852.687675366 Min Y:
2511508.559584662 Max X: -9239502.274801318 Max Y: 2632035.433856736
INFO | jvm 1 | 2013/07/09 15:00:24 | 09 jul 15:00:24 DEBUG
TileSet[nurc:Pk50095#EPSG:4326#image/jpeg]
for CRS EPSG:900913
INFO | jvm 1 | 2013/07/09 15:00:24 | java.lang.NullPointerException:
INFO | jvm 1 | 2013/07/09 15:00:24 | at
[gwc.layer] - Can’t compute bounds for tile layer une:sigfre_cub_Adm_munic
in CRS EPSG:900913. Assuming full GridSet bounds. (null)
-1.0
for CRS EPSG:4326
in CRS EPSG:4326. Assuming full GridSet bounds. (null)
org.springframework.transaction.support.TransactionCallbackWithoutResult.doInTransaction(TransactionCallbackWithoutResult.java:33)
INFO | jvm 1 | 2013/07/09 15:00:25 | 09 jul 15:00:25 DEBUG
TileSet[sf:restricted#EPSG:4326#image/png]
TileSet[sf:restricted#EPSG:4326#image/jpeg]
programa\GeoServer
2.3.2\data_dir\gwc-layers\LayerInfoImpl-1de7ab45_139ca8c819c_-7fec.xml
for CRS EPSG:900913
INFO | jvm 1 | 2013/07/09 15:00:25 | java.lang.NullPointerException:
INFO | jvm 1 | 2013/07/09 15:00:25 | at
une:sigfre_cub_Adm_Altura_mas_30m_Grado in CRS EPSG:900913. Assuming full
-1.0
for CRS EPSG:4326
une:sigfre_cub_Adm_Altura_mas_30m_Grado in CRS EPSG:4326. Assuming full
Hi Alejandro,
ones.
Anyway:
yes they are there
they are there too
demos’s page?
thanks
regards
Michele
interrogada.
será interrogada.
for CRS EPSG:900913
bounds. (null)
-1.0
interrogada.
interrogada.
for CRS EPSG:4326
bounds. (null)
Max Y: 90.0
Max Y: 90.0
-1.0
Max Y: 90.0
programa\GeoServer
-1.0
Max Y: 90.0
programa\GeoServer
for CRS EPSG:900913
-1.0
for CRS EPSG:4326
programa\GeoServer
for CRS EPSG:900913
-1.0
for CRS EPSG:4326
Il giorno 10/Lug/2013 12:57, “J.Alejandro Martinez Linares” <
Hi Alejandro,
ones.
Anyway:
yes they are there
they are there too
demos’s page?
thanks
regards
Michele
that i think that it have to do with all the trouble, here are the logs:
interrogada.
será interrogada.
for CRS EPSG:900913
bounds. (null)
-1.0
interrogada.
interrogada.
for CRS EPSG:4326
bounds. (null)
Max Y: 90.0
Max Y: 90.0
-1.0
Max Y: 90.0
programa\GeoServer
-1.0
Max Y: 90.0
programa\GeoServer
for CRS EPSG:900913
-1.0
for CRS EPSG:4326
programa\GeoServer
for CRS EPSG:900913
-1.0
for CRS EPSG:4326
