[Geoserver-users] GeoWebCache WMTS issue (bug?
Hi List,
If I try and go to the GetCapabilities document for the WMTS service, I get a GeoWebcache error. The page that comes up is HTML, contains the GWC logo and the text:
400: 9
The console has:
29 Jan 12:17:13 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Matching patterns for request [/gwc/service/wmts] are [/gwc/service/**]
29 Jan 12:17:13 DEBUG [org.geoserver.ows.OWSHandlerMapping] - URI Template variables for request [/gwc/service/wmts] are {}
29 Jan 12:17:13 DEBUG [org.geoserver.ows.OWSHandlerMapping] - Mapping [/gwc/service/wmts] to HandlerExecutionChain with handler [org.geoserver.ows.Dispatcher@anonymised.com] and 1 interceptor
29 Jan 12:17:13 DEBUG [org.geoserver.gwc.layer] - Depersisting GeoServerTileLayerInfo from D:\Geoserver_data\gwc-layers\LayerInfoImpl-1edff41_13bfc89cfdb_-7f88.xml
29 Jan 12:17:13 ERROR [org.geowebcache.GeoWebCacheDispatcher] - 9 http://wppgeog3:8082/geoserver/gwc/service/wmts
java.lang.ArrayIndexOutOfBoundsException: 9
at org.geowebcache.grid.GridSubset.getWMTSCoverages(GridSubset.java:382)
at org.geowebcache.service.wmts.WMTSGetCapabilities.layerGridSubSets(WMTSGetCapabilities.java:386)
at org.geowebcache.service.wmts.WMTSGetCapabilities.layer(WMTSGetCapabilities.java:268)
at org.geowebcache.service.wmts.WMTSGetCapabilities.contents(WMTSGetCapabilities.java:231)
at org.geowebcache.service.wmts.WMTSGetCapabilities.generateGetCapabilities(WMTSGetCapabilities.java:109)
at org.geowebcache.service.wmts.WMTSGetCapabilities.writeResponse(WMTSGetCapabilities.java:74)
at org.geowebcache.service.wmts.WMTSService.handleRequest(WMTSService.java:247)
at org.geowebcache.service.wmts.WMTSService$$FastClassByCGLIB$$e221a779.invoke()
at net.sf.cglib.proxy.MethodProxy.invoke(MethodProxy.java:149)
at org.springframework.aop.framework.Cglib2AopProxy$CglibMethodInvocation.invokeJoinpoint(Cglib2AopProxy.java:689)
I know it worked previously because I reported issue GEOS-5503 against it.
I have one custom gridset. Using GeoServer 2.2.3
Any ideas?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
Dear all,
a simple question
Does Geoserver support the hierarchical layer group definition?
Thank’s
Nunzio
On Tue, Jan 29, 2013 at 3:46 PM, Nunzio Testa <nunzio.testa@anonymised.com…> wrote:
Dear all,
a simple question
GeoServer 2.2.x does not, but GeoServer 2.3.0 will.
We are releasing the beta version today, you can download it already here:
http://geoserver.org/display/GEOS/GeoServer+2.3-beta
(official announcement should follow later today)
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
