[Geoserver-users] GeoWebCache
Hello All,
Can I send the styles parameter or filter parameter in the wms url string
when using GeoWebCache? I can't seem to make it work.
Steve
Stephen Crawford
Center for Environmental Informatics
The Pennsylvania State University
Not currently,
because it would create a new set of tiles on disk for every style you specify in the URL. Work has started to support this, and other parameters, in the next version.
For the time being you can
1) create <GEOSERVER_DATA_DIR>/gwc/gwc.xml , see http://geowebcache.org/trac/wiki/configuration
2) manually define layers with the style option, see below
3) restart geoserver to have the new layers show up, check http://localhost:8080/geoserver/gwc/demo
Fill in the gaps and replace layer , styleA , styleB:
<wmsLayer>
<name>layer_styleA<name>
<wmsLayers>layer</wmsLayers>
<wmsStyles>styleA</wmsStyles>
</wmsLayer>
<wmsLayer>
<name>layer_styleB<name>
<wmsStyles>styleB</wmsStyles>
</wmsLayer>
-Arne
Stephen Crawford wrote:
Hello All,
Steve
Stephen Crawford
Check out the new SourceForge.net Marketplace.
It is the best place to buy or sell services for
just about anything Open Source.
http://p.sf.net/sfu/Xq1LFB
Geoserver-users mailing list
Arne Kepp
OpenGeo - http://opengeo.org
Expert service straight from the developers
OK, thanks. Do you think the next version will support a filter on an
attribute, like this:
filter=<Filter><PropertyIsEqualTo><PropertyName>sci_name</PropertyName><Lite
ral>Dryocopus pileatus</Literal></PropertyIsEqualTo></Filter>
Steve
-----Original Message-----
Sent: Wednesday, January 07, 2009 10:47 AM
To: Stephen Crawford
Subject: Re: [Geoserver-users] GeoWebCache
Not currently,
<wmsLayer>
</wmsLayer>
<wmsLayer>
</wmsLayer>
-Arne
Hello All,
Steve
Stephen Crawford
Arne Kepp
That's the goal, to do it on a general level that supports every (reasonable) parameter.
Will obviously require some sort of database to store the various combinations.
-Arne
Steve
From: Arne Kepp [mailto:ak@anonymised.com] Sent: Wednesday, January 07, 2009 10:47 AM
Not currently,
<wmsLayer>
</wmsLayer>
<wmsLayer>
</wmsLayer>
-Arne
Hello All,
Steve
Stephen Crawford
Arne Kepp
