[Geoserver-users] Get "Error rendering coverage on the fast path" when request a browse image from an image mosaic layer
Hi There:
When I try to get an browse image (which is over the north pole), I get errors and no browse image is returned back. Here’s the Geoserver log:
2016-08-31 17:45:35,780 INFO [org.geotools.referencing.factory] - Using “file:/C:/apache-tomcat-8.0.30-geo-2.9.1/webapps/geoserver/WEB-INF/lib/gs-main-2.9.1.jar!/org/vfny/geoserver/crs/override_epsg.properties” as EPSG factory.
2016-08-31 17:45:35,785 INFO [org.geoserver.wms] -
Request: getMap
Time =
Filter = [[[[ short_term_archive_dataset_id = NP1 ] AND [ short_term_archive_facility_id = test ]] AND [ downlink_segment_id = NP_Seg_1 ]]]
Buffer = 0
Format = application/openlayers
Width = 1024
Height = 768
Filters = [[[[ short_term_archive_dataset_id = NP1 ] AND [ short_term_archive_facility_id = test ]] AND [ downlink_segment_id = NP_Seg_1 ]]]
Layers = [org.geoserver.wms.MapLayerInfo@anonymised.com]
MaxFeatures = null
Crs = GEOGCS[“WGS 84”,
DATUM[“World Geodetic System 1984”,
SPHEROID[“WGS 84”, 6378137.0, 298.257223563, AUTHORITY[“EPSG”,“7030”]],
AUTHORITY[“EPSG”,“6326”]],
PRIMEM[“Greenwich”, 0.0, AUTHORITY[“EPSG”,“8901”]],
UNIT[“degree”, 0.017453292519943295],
AXIS[“Geodetic longitude”, EAST],
AXIS[“Geodetic latitude”, NORTH],
AUTHORITY[“EPSG”,“4326”]]
Bbox = SRSEnvelope[-180.0 : 180.0, 88.0 : 90.0]
RemoteOwsType = null
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
CQLFilter = [[[[ short_term_archive_dataset_id = NP1 ] AND [ short_term_archive_facility_id = test ]] AND [ downlink_segment_id = NP_Seg_1 ]]]
Elevation =
FeatureId = null
StartIndex = null
ViewParams = null
ValidateSchema = false
BgColor = java.awt.Color[r=255,g=255,b=255]
Tiled = false
Palette = null
SRS = EPSG:4326
Styles = [StyleImpl[ name=raster]]
Interpolations =
Transparent = false
StyleFormat = sld
SldBody = null
Sld = null
StyleUrl = null
TilesOrigin = null
Exceptions = SE_XML
StyleBody = null
SldVersion = null
StyleVersion = null
ScaleMethod = null
FeatureVersion = null
Version = 1.1.0
Request = GetMap
BaseUrl = http://localhost:8686/geoserver/
Get = true
RawKvp = {REQUEST=GetMap, SRS=EPSG:4326, FORMAT=application/openlayers, BBOX=-180,88,180,90, VERSION=1.1.0, STYLES=, SERVICE=WMS, WIDTH=1024, HEIGHT=768, CQL_FILTER=short_term_archive_dataset_id=‘NP1’ AND short_term_archive_facility_id=‘test’ AND downlink_segment_id=‘NP_Seg_1’, LAYERS=ohs:browse_tile}
RequestCharset = UTF-8
2016-08-31 17:45:35,840 INFO [org.geoserver.wms] -
Request: getServiceInfo
2016-08-31 17:45:35,841 DEBUG [org.geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2016-08-31 17:45:35,841 DEBUG [org.geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2016-08-31 17:45:35,842 DEBUG [org.geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2016-08-31 17:45:35,842 DEBUG [org.geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2016-08-31 17:45:35,850 DEBUG [org.geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2016-08-31 17:45:35,851 DEBUG [org.geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2016-08-31 17:45:35,851 TRACE [org.geotools.factory] - ENTRY (GridCoverageFactory)
2016-08-31 17:45:35,852 TRACE [org.geotools.factory] - RETURN (GridCoverageFactory): found implementation GridCoverageFactory.
2016-08-31 17:45:35,852 DEBUG [org.geotools.renderer.lite.gridcoverage2d] - Rendering using interpolation javax.media.jai.InterpolationNearest@anonymised.com
2016-08-31 17:45:35,852 DEBUG [org.geotools.gce.imagemosaic] - Reading mosaic from file:/C:/csbrowse/datastore.properties
2016-08-31 17:45:35,852 DEBUG [org.geotools.gce.imagemosaic] - Highest res 0.015789652484640204 0.005213341874903499
2016-08-31 17:45:35,853 TRACE [org.geotools.gce.imagemosaic] - Adjusted Requested Envelope = ReferencedEnvelope[-180.0 : 180.0, -46.0546875 : 223.9453125]
Requested raster dimension = java.awt.Rectangle[x=0,y=0,width=1024,height=768]
Corresponding raster source region = java.awt.Rectangle[x=0,y=382,width=1024,height=116]
Corresponding source Envelope = ReferencedEnvelope[-180.0 : 180.0, 48.9793141134912 : 89.63]
2016-08-31 17:45:35,853 DEBUG [org.geotools.gce.imagemosaic] - Loading level 0 with subsampling factors 1 1
2016-08-31 17:45:35,853 DEBUG [org.geotools.gce.imagemosaic] - Prepping to manage SortBy Clause
2016-08-31 17:45:35,853 DEBUG [org.geotools.gce.imagemosaic.catalog] - Index Loaded
2016-08-31 17:45:35,854 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
2016-08-31 17:45:35,855 INFO [org.geotools.jdbc] - Unable to find aggregate function matching visitor: class org.geotools.gce.imagemosaic.catalog.CachingDataStoreGranuleCatalog$1
2016-08-31 17:45:35,855 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
2016-08-31 17:45:35,855 DEBUG [org.geotools.jdbc] - CREATE CONNECTION
2016-08-31 17:45:35,856 DEBUG [org.geotools.filter] - exporting LogicFilter
2016-08-31 17:45:35,856 DEBUG [org.geotools.filter] - exporting PropertyName
2016-08-31 17:45:35,856 DEBUG [org.geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2016-08-31 17:45:35,856 DEBUG [org.geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2016-08-31 17:45:35,856 DEBUG [org.geotools.filter] - exporting SQL ComparisonFilter
2016-08-31 17:45:35,857 DEBUG [org.geotools.filter] - exporting PropertyName
2016-08-31 17:45:35,857 DEBUG [org.geotools.filter] - exporting SQL ComparisonFilter
2016-08-31 17:45:35,857 DEBUG [org.geotools.jdbc] - SELECT “fid”,“scene_id”,“short_term_archive_dataset_id”,“short_term_archive_facility_id”,“downlink_segment_id”,“browse_location”,encode(ST_AsEWKB(“scene_extent”),‘base64’) as “scene_extent” FROM “browsedb”.“browse_tile” WHERE (“scene_extent” && ST_GeomFromWKB(?, 4326) AND “short_term_archive_dataset_id” = ? AND “short_term_archive_facility_id” = ? AND “downlink_segment_id” = ?)
2016-08-31 17:45:35,857 DEBUG [org.geotools.jdbc] - 1 = POLYGON ((-180 48.9793141134912, -180 89.63, 180 89.63, 180 48.9793141134912, -180 48.9793141134912))
2016-08-31 17:45:35,857 DEBUG [org.geotools.jdbc] - 2 = NP1
2016-08-31 17:45:35,858 DEBUG [org.geotools.jdbc] - 3 = test
2016-08-31 17:45:35,858 DEBUG [org.geotools.jdbc] - 4 = NP_Seg_1
2016-08-31 17:45:35,860 DEBUG [org.geotools.gce.imagemosaic] - We added the granule Description of a granuleDescriptor
BBOX: ReferencedEnvelope[-180.0 : 180.0, 88.93 : 89.63]
file: file:/C:/csbrowse/NorthPole/imagery_174435_HH.tif
gridToWorld: PARAM_MT[“Affine”,
PARAMETER[“num_row”, 3],
PARAMETER[“num_col”, 3],
PARAMETER[“elt_0_0”, 0.05870841487279843],
PARAMETER[“elt_0_2”, -179.9706457925636],
PARAMETER[“elt_1_1”, -0.0000999428897772685],
PARAMETER[“elt_1_2”, 89.6299500285551]]
Description of level 2
Description of a granuleDescriptor level
width: 6132
height: 7004
scaleX: 1.0
scaleY: 1.0
baseToLevelTransform: PARAM_MT[“Affine”,
PARAMETER[“num_col”, 3]]
gridToWorldTransform: PARAM_MT[“Affine”,
PARAMETER[“elt_0_2”, -180.0],
PARAMETER[“elt_1_2”, 89.63]]
2016-08-31 17:45:35,860 DEBUG [org.geotools.gce.imagemosaic] - Thread:pool-1-thread-3 Loading raster data for granuleDescriptor Description of a granuleDescriptor
width: 6132
height: 7004
scaleX: 1.0
scaleY: 1.0
2016-08-31 17:45:35,860 DEBUG [org.geotools.jdbc] - CLOSE CONNECTION
2016-08-31 17:45:35,861 DEBUG [org.geotools.gce.imagemosaic] - Producing the final mosaic, step 1, loop through granule collectors
2016-08-31 17:45:35,861 DEBUG [org.geotools.gce.imagemosaic] - Using collector with filter:Filter.INCLUDE
2016-08-31 17:45:35,861 DEBUG [org.geotools.gce.imagemosaic] - Loading level 0 with source region: java.awt.Rectangle[x=0,y=0,width=6132,height=7004] subsampling: 5,3517 for granule:file:/C:/csbrowse/NorthPole/imagery_174435_HH.tif
2016-08-31 17:45:35,862 TRACE [org.geotools.coverage.grid.io.imageio] - reading file: file:/C:/csbrowse/NorthPole/imagery_174435_HH.tif
2016-08-31 17:45:35,865 DEBUG [org.geotools.gce.imagemosaic] - Adding to mosaic granule file:/C:/csbrowse/NorthPole/imagery_174435_HH.tif
2016-08-31 17:45:35,866 DEBUG [org.geotools.gce.imagemosaic] - Support for alpha on input granule file:/C:/csbrowse/NorthPole/imagery_174435_HH.tif
2016-08-31 17:45:35,867 INFO [org.geotools.gce.imagemosaic] - Adding to mosaic failed, original request was RasterLayerRequest description:
SpatialRequestHelper [requestedBBox=ReferencedEnvelope[-180.0 : 180.0, -46.0546875 : 223.9453125], cropBBox=ReferencedEnvelope[-180.0 : 180.0, 48.9793141134912 : 89.63], requestedRasterArea=java.awt.Rectangle[x=0,y=0,width=1024,height=768], destinationRasterArea=java.awt.Rectangle[x=0,y=382,width=1024,height=116], requestCRS=GEOGCS[“WGS 84”,
AUTHORITY[“EPSG”,“4326”]], requestedGridToWorld=PARAM_MT[“Affine”,
PARAMETER[“elt_0_0”, 0.3515625],
PARAMETER[“elt_0_2”, -179.82421875],
PARAMETER[“elt_1_1”, -0.3515625],
PARAMETER[“elt_1_2”, 223.76953125]], requestedResolution=[0.3515625, 0.3515625], coverageProperties=org.geotools.gce.imagemosaic.SpatialRequestHelper$CoverageProperties@anonymised.com…, accurateResolution=false, empty=false, needsReprojection=false, ]
ReadType=DIRECT_READ
2016-08-31 17:45:35,868 ERROR [org.geoserver.ows] -
org.geoserver.platform.ServiceException: Error rendering coverage on the fast path
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:346)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:261)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:131)
at org.geoserver.wms.GetMap.executeInternal(GetMap.java:505)
at org.geoserver.wms.GetMap.run(GetMap.java:249)
at org.geoserver.wms.GetMap.run(GetMap.java:119)
at org.geoserver.wms.DefaultWebMapService.getMap(DefaultWebMapService.java:320)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.lang.reflect.Method.invoke(Method.java:498)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:302)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:190)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:157)
at org.geoserver.kml.WebMapServiceKmlInterceptor.invoke(WebMapServiceKmlInterceptor.java:34)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:179)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:62)
at org.geoserver.gwc.wms.CacheSeedingWebMapService.invoke(CacheSeedingWebMapService.java:36)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:74)
at org.geoserver.gwc.wms.CachingWebMapService.invoke(CachingWebMapService.java:55)
at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:55)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:208)
at com.sun.proxy.$Proxy71.getMap(Unknown Source)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:840)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:268)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:147)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:50)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:959)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:893)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:968)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:859)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:622)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:844)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:729)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:291)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:239)
at org.geoserver.filters.ThreadLocalsCleanupFilter.doFilter(ThreadLocalsCleanupFilter.java:28)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:75)
at org.geoserver.wms.animate.AnimatorFilter.doFilter(AnimatorFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter$Chain.doFilter(SpringDelegatingFilter.java:71)
at org.geoserver.filters.SpringDelegatingFilter.doFilter(SpringDelegatingFilter.java:46)
at org.geoserver.platform.AdvancedDispatchFilter.doFilter(AdvancedDispatchFilter.java:50)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:316)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:69)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:126)
at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:90)
at org.geoserver.security.filter.GeoServerCompositeFilter$NestedFilterChain.doFilter(GeoServerCompositeFilter.java:73)
at org.geoserver.security.filter.GeoServerCompositeFilter.doFilter(GeoServerCompositeFilter.java:92)
at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:330)
at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:114)
at org.geoserver.security.filter.GeoServerAnonymousAuthenticationFilter.doFilter(GeoServerAnonymousAuthenticationFilter.java:54)
at org.springframework.security.web.authentication.www.BasicAuthenticationFilter.doFilterInternal(BasicAuthenticationFilter.java:158)
at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107)
at org.geoserver.security.filter.GeoServerBasicAuthenticationFilter.doFilter(GeoServerBasicAuthenticationFilter.java:84)
at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:91)
at org.geoserver.security.filter.GeoServerSecurityContextPersistenceFilter$1.doFilter(GeoServerSecurityContextPersistenceFilter.java:53)
at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:213)
at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:176)
at org.geoserver.security.GeoServerSecurityFilterChainProxy.doFilter(GeoServerSecurityFilterChainProxy.java:152)
at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346)
at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:87)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:42)
at org.geoserver.filters.SessionDebugFilter.doFilter(SessionDebugFilter.java:48)
at org.geoserver.filters.FlushSafeFilter.doFilter(FlushSafeFilter.java:44)
at org.springframework.web.filter.CharacterEncodingFilter.doFilterInternal(CharacterEncodingFilter.java:121)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:212)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:106)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:502)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:141)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:79)
at org.apache.catalina.valves.AbstractAccessLogValve.invoke(AbstractAccessLogValve.java:616)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:88)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:521)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1096)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:674)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.doRun(AprEndpoint.java:2500)
at org.apache.tomcat.util.net.AprEndpoint$SocketProcessor.run(AprEndpoint.java:2489)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.geoserver.platform.ServiceException: org.geotools.data.DataSourceException: Unable to create this mosaic
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:1083)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.produceMap(RenderedImageMapOutputFormat.java:344)
… 123 more
Caused by: org.geotools.data.DataSourceException: Unable to create this mosaic
at org.geotools.gce.imagemosaic.RasterLayerResponse.prepareResponse(RasterLayerResponse.java:1348)
at org.geotools.gce.imagemosaic.RasterLayerResponse.processRequest(RasterLayerResponse.java:1228)
at org.geotools.gce.imagemosaic.RasterLayerResponse.createResponse(RasterLayerResponse.java:1194)
at org.geotools.gce.imagemosaic.RasterManager.read(RasterManager.java:1157)
at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:894)
at org.geotools.gce.imagemosaic.ImageMosaicReader.read(ImageMosaicReader.java:873)
at org.geoserver.catalog.SingleGridCoverage2DReader.read(SingleGridCoverage2DReader.java:151)
at org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:243)
at org.geoserver.catalog.CoverageDimensionCustomizerReader.read(CoverageDimensionCustomizerReader.java:233)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readSingleCoverage(GridCoverageReaderHelper.java:526)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readCoverageInEnvelope(GridCoverageReaderHelper.java:299)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageReaderHelper.readCoverages(GridCoverageReaderHelper.java:204)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:802)
at org.geotools.renderer.lite.gridcoverage2d.GridCoverageRenderer.renderImage(GridCoverageRenderer.java:770)
at org.geoserver.wms.map.RenderedImageMapOutputFormat.directRasterRender(RenderedImageMapOutputFormat.java:975)
… 124 more
Caused by: java.io.IOException: java.lang.IllegalStateException: Unsupported data type.
at org.geotools.gce.imagemosaic.RasterLayerResponse$GranuleCollector.collectGranules(RasterLayerResponse.java:516)
at org.geotools.gce.imagemosaic.RasterLayerResponse$GranuleCollector.access$2400(RasterLayerResponse.java:332)
at org.geotools.gce.imagemosaic.RasterLayerResponse$MosaicProducer.produce(RasterLayerResponse.java:1072)
at org.geotools.gce.imagemosaic.RasterLayerResponse$MosaicProducer.access$3100(RasterLayerResponse.java:882)
at org.geotools.gce.imagemosaic.RasterLayerResponse.prepareResponse(RasterLayerResponse.java:1296)
… 138 more
Caused by: java.lang.IllegalStateException: Unsupported data type.
at org.geotools.image.ImageWorker.makeColorTransparent(ImageWorker.java:2459)
at org.geotools.gce.imagemosaic.RasterLayerResponse$GranuleCollector.preProcessGranuleRaster(RasterLayerResponse.java:567)
at org.geotools.gce.imagemosaic.RasterLayerResponse$GranuleCollector.collectGranules(RasterLayerResponse.java:508)
… 142 more
The same error when I run GeoServer 2.8.1 in Tomcat 8.0.27. Do you have any idea for what’s going wrong? I can get other images from the mosaic layer.
Thanks
Cathy Hu
Software Engineer
MDA Systems Ltd., 13800 Commerce Parkway, Richmond, BC, Canada V6V 2J3
Tel: +1-604-231-2179 / Facsimile: +1-604-278-2936
www.mdacorporation.com
Oops, meant to send this to the user list.
On Thu, Sep 1, 2016 at 8:40 PM, Cathy Hu <CHU@anonymised.com> wrote:
Hi Devon:
Sorry, I don’t know how to find out the color/band model. I am very appreciated if you could give me some instructions and tell me which tools I could use to check them out.
So far, I can only get some metadata of the browse image from QGIS:
Driver
GDAL provider
VRT
Virtual Raster
Dataset Description
Band 1
STATISTICS_MAXIMUM=42959
STATISTICS_MEAN=9322.3445402102
STATISTICS_MINIMUM=0
STATISTICS_STDDEV=6865.5779769686
Dimensions
X: 9746 Y: 18 Bands: 1
Origin
-221.125,89.6785
Pixel Size
0.0474007,-0.0474007
No Data Value
NoDataValue not set
Data Type
UInt16 - Sixteen bit unsigned integer
Pyramid overviews
Layer Spatial Reference System
+proj=longlat +datum=WGS84 +no_defs
Layer Extent (layer original source projection)
-221.1252541385472625,88.8252824333668229 : 240.8416833346172155,89.6784945075015401
Band
Band 1
Band No
1
No Stats
No stats collected yet
Does this help?
Thanks a lot
Cathy
From: Devon Tucker [mailto:devonrtucker@anonymised.com]
Sent: Thursday, September 01, 2016 7:36 AM
To: Cathy Hu <CHU@anonymised.com>
Subject: Re: [Geoserver-users] Get “Error rendering coverage on the fast path” when request a browse image from an image mosaic layer
Hi Cathy,
Could you tell us a little bit about the data you’re using? Particularly the color/band model? It looks like you’re running into a limitation with the INPUT_TRANSPARENT_COLOR option as seen here:
https://github.com/geotools/geotools/blob/14.5/modules/library/coverage/src/main/java/org/geotools/image/ImageWorker.java#L2442
There is only limited support for input transparency so far. I’m not sure if this limitation exists because other implementations are hard/tricky, or if it’s just that nobody has done it so far. Maybe someone else can chime in.
The most basic workaround is to turn off INPUT_TRANSPARENCY if you don’t need it, although most likely you do. If your mosaic is mostly static and it’s just this one raster that’s causing issues than an alternative is to pre-process that one image to be in a compatible model (byte components).
Another alternative, IIRC, is to use JAI_EXT which supports NoData without having to do input_transparent (I may be wrong on this one?):
http://docs.geoserver.org/stable/en/user/configuration/image_processing/index.html#jai-ext
Devon Tucker
On Wed, Aug 31, 2016 at 6:05 PM, Cathy Hu <CHU@anonymised.com> wrote:
Hi There:
Request: getMap
Time =
Buffer = 0
Width = 1024
Height = 768
MaxFeatures = null
RemoteOwsURL = null
Env = {}
FormatOptions = {}
Angle = 0.0
Elevation =
FeatureId = null
StartIndex = null
ViewParams = null
Tiled = false
Palette = null
SRS = EPSG:4326
Interpolations =
Transparent = false
StyleFormat = sld
SldBody = null
Sld = null
StyleUrl = null
TilesOrigin = null
Exceptions = SE_XML
StyleBody = null
SldVersion = null
StyleVersion = null
ScaleMethod = null
Version = 1.1.0
Request = GetMap
Get = true
width: 6132
height: 7004
scaleX: 1.0
scaleY: 1.0
width: 6132
height: 7004
scaleX: 1.0
scaleY: 1.0
PARAMETER[“elt_1_2”, 223.76953125]], requestedResolution=[0.3515625, 0.3515625], coverageProperties=org.geotools.gce.imagemosaic.SpatialRequestHelper$CoverageProperties@anonymised.comc44323, accurateResolution=false, empty=false, needsReprojection=false, ]
… 123 more
… 124 more
… 138 more
… 142 more
Thanks
Cathy Hu
Software Engineer
Geoserver-users mailing list
Geoserver-users@anonymised.comrge.net
