What i have so far is a map that has a Google map satellite as a base layer and a custom WMS layer over the top.
When i create a map that only has the WMS layer (in projection EPSG:4326) it works fine and i can do queries on all the feature information as the tutorial shown here:
http://openlayers.org/dev/examples/getfeatureinfo.html
However if i try and put this into a google map (projection EPSG:900913) and overlay the WMS i get the following error:
org.geoserver.platform.ServiceException: org.xml.sax.SAXParseException: Content is not allowed in prolog. org.xml.sax.SAXParseException: Content is not allowed in prolog. Content is not allowed in prolog.
Any help with this would be fantastic
Brad
Bradley Mclain
Systems Administrator Trainee
De Bortoli Wines Pty limited
De Bortoli Rd, BILBUL NSW 2680
e: bradley_mclain@anonymised.com
Bradley McLain ha scritto:
Mumble, I've seen that kind of error in a GetMap request only if you're
adding a SLD_BODY or a FILTER parameter to the request, and their
contents is invalid.
Can you go into the config/server panel and enable "verbose exceptions"
and then grab the full service exception (with the full stack trace that
would tell us where the error originated from)?
Andrea Aime
OpenGeo - http://opengeo.org
