[Geoserver-users] Get legend from SLD with multiple user styles
Hi list,
I have a layer.sld with 2 user styles (layer and layerLegend). I want to create a legend of the layerLegend user style. But when using the following request, I get a runtime exception: java.lang.NullPointerException: request.getStyle()
wms?request=GetLegendGraphic&version=1.0.0&format=image/png&strict=false&style=layerLegend&width=20&height=20
When I copy the layer.sld to the www/styles directory in the data directory and I add the SLD-parameter to the previous request, the expected legend graphic is created successfully.
wms?request=GetLegendGraphic&version=1.0.0&format=image/png&strict=false&style=layerLegend&width=20&height=20&SLD=http://localhost:8080/geoserver/www/styles/layer.sld
Is it possible to generate the legend of a 2nd (or 3rd) user style in an SLD without having to copy the sld into the www/styles directory?
Kind regards,
Roel De Nijs
Senior Java Developer
Hi Roel,
I believe you’re misunderstanding the meaning of the “style” parameter: it is not supposed to be a UserStyle name, but the name of a Style Layer Descriptor (basically, what you write in the “Name” field when you create a new style through GeoServer’s web UI).
To my knowledge, there is no way to specify which UserStyle inside the SLD document will be used (I guess the first one is picked if multiple are present, didn’t try though). From chapter “Introduction to SLD” in GeoServer’s documentation: “A style document specifies a single named layer and a user style for it”. If I understand correctly, this sentence implies that one should not put multiple user styles in the same SLD document, but rather create multiple SLD documents containing one User Style each.
That’s because you’re specifying which SLD document should be used via the “SLD” parameter.
Hope this helps.
<br>-- <br><br>Best regards,<br>Stefano Costa<br><br>==<br>GeoServer Professional Services from the experts! Visit<br>http://goo.gl/it488V for more information.<br>==<br>Dott. Stefano Costa<br>Senior Software Engineer<br><br>GeoSolutions S.A.S.<br>Via Poggio alle Viti 1187<br>55054 Massarosa (LU)<br>Italy<br>phone: +39 0584 962313<br>fax: +39 0584 1660272<br><br>http://www.geo-solutions.it<br>http://twitter.com/geosolutions_it<br><br>-------------------------------------------------------<br>AVVERTENZE AI SENSI DEL D.Lgs. 196/2003<br>Le informazioni contenute in questo messaggio di posta elettronica e/o<br>nel/i file/s allegato/i sono da considerarsi strettamente riservate.<br>Il loro utilizzo è consentito esclusivamente al destinatario del<br>messaggio, per le finalità indicate nel messaggio stesso. Qualora<br>riceviate questo messaggio senza esserne il destinatario, Vi preghiamo<br>cortesemente di darcene notizia via e-mail e di procedere alla<br>distruzione del messaggio stesso, cancellandolo dal Vostro sistema.<br>Conservare il messaggio stesso, divulgarlo anche in parte,<br>distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità<br>diverse, costituisce comportamento contrario ai principi dettati dal<br>D.Lgs. 196/2003.<br><br>The information in this message and/or attachments, is intended solely<br>for the attention and use of the named addressee(s) and may be<br>confidential or proprietary in nature or covered by the provisions of<br>privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New<br>Data Protection Code).Any use not in accord with its purpose, any<br>disclosure, reproduction, copying, distribution, or either<br>dissemination, either whole or partial, is strictly forbidden except<br>previous formal approval of the named addressee(s). If you are not the<br>intended recipient, please contact immediately the sender by<br>telephone, fax or e-mail and delete the information in this message<br>that has been received in error. The sender does not give any warranty<br>or accept liability as the content, accuracy or completeness of sent<br>messages and accepts no responsibility for changes made after they<br>were sent or for other risks which arise as a result of e-mail<br>transmission, viruses, etc.<br><br><br><br>
Hi Stefano,
That’s exactly what I’m experiencing. And I tried it, so I can confirm your guess: if the Style Layer Descriptor contains more than 1 UserStyle, the legend is generated based on the first one in the SLD.
So you can’t specify which UserStyle to generate a legend from, unless if you specify the SLD document. I don’t want to duplicate the styles in the www/styles directory, so I’m wondering if it’s possible to refer to a local style using the SLD-parameter.
I already tried the following request but without the desired result :frowning:
wms?request=GetLegendGraphic&version=1.0.0&format=image/png&strict=false&style=layerLegend&width=20&height=20&SLD=layer.sld
wms?request=GetLegendGraphic&version=1.0.0&format=image/png&strict=false&style=layerLegend&width=20&height=20&SLD=file:/layer.sld
wms?request=GetLegendGraphic&version=1.0.0&format=image/png&strict=false&style=layerLegend&width=20&height=20&SLD=file:/styles/layer.sld
Kind regards,
Roel De Nijs
Van: Stefano Costa [mailto:stefano.costa@…1107…]
Verzonden: donderdag 4 juni 2015 15:24
Aan: Roel De Nijs
CC: geoserver-users@lists.sourceforge.net
Onderwerp: Re: [Geoserver-users] Get legend from SLD with multiple user styles
Hi Roel,
Hope this helps.
<br><br>
<br>-- <br>
<br><br>
<br><br>
<br>==<br>
<br>[http://goo.gl/it488V](http://goo.gl/it488V) for more information.<br>
<br>==<br>
<br><br>
<br>Italy<br>
<br><br>
<br>[http://www.geo-solutions.it](http://www.geo-solutions.it)<br>
<br>[http://twitter.com/geosolutions_it](http://twitter.com/geosolutions_it)<br>
<br><br>
<br><br>
<br><br>
<br><br>
Hi Roel,
I had a quick look though the code and I see at least the intention of parsing multiple styles out of a referenced
sld file, and then a lookup by name using whatever was provided in the style parameter.
So, in theory, this should work, at least in the current version of GeoServer (I’m referring to 2.7.x and 2.6.x)
You did not say which version you’re using, if it’s a currently supported version (2.7.x, 2.6.x) can you please
open a ticket at https://osgeo-org.atlassian.net/projects/GEOS with the sld in question and the details of your
requests, if it’s older, could you try 2.6.x/2.7.x?
On Thu, Jun 11, 2015 at 7:04 PM, Roel De Nijs <roel.denijs@anonymised.com3…> wrote:
Hi Stefano,
Kind regards,
Roel De Nijs
Van: Stefano Costa [mailto:stefano.costa@anonymised.com]
Aan: Roel De Nijs
Hi Roel,
Hope this helps.
<br> <br>
<br>-- <br>
<br> <br>
<br> <br>
<br>==<br>
<br>==<br>
<br> <br>
<br>Italy<br>
<br> <br>
<br> <br>
<br> <br>
<br> <br>
<br> <br>
Volg Aquafin op Facebook | Twitter | YouTube | LinkedIN
Disclaimer: zie www.aquafin.be P Denk aan het milieu. Druk deze mail niet onnodig af.
Geoserver-users mailing list
Ing. Andrea Aime
@geowolf
Technical Lead
mob: +39 339 8844549
Hi Andrea,
We are using Geoserver 2.6.2.
I was probably not completely clear about what I’m trying to achieve: when you provide an SLD file in the directory www/styles of geoserver’s data directory and you use a reference tot his SLD file, it works like a charm.
But I don’t want to duplicate our SLDs in the www/styles directory, so I was wondering if it was possible to refer to the local SLD file (e.g. the SLD file in the styles directory of the workspace). And if it is, what’s the correct syntax to do so. I already tried a few (layer.sld, file:/layer.sld, file:/styles/layer.sld), but without any success.
Kind regards,
Roel
Verzonden: vrijdag 12 juni 2015 4:59
Hi Roel,
On Thu, Jun 11, 2015 at 7:04 PM, Roel De Nijs <roel.denijs@…5173…> wrote:
Hi Stefano,
Kind regards,
Roel De Nijs
Aan: Roel De Nijs
Hi Roel,
Hope this helps.
<br> <br>
<br>-- <br>
<br> <br>
<br> <br>
<br>==<br>
<br>==<br>
<br> <br>
<br>Italy<br>
<br> <br>
<br> <br>
<br> <br>
<br> <br>
<br> <br>
Ing. Andrea Aime
@geowolf
Technical Lead
Hi Roel,
you could try and access the SLD files in your workspace via the REST
interface (remember to tune the REST security configuration in
$GEOSERVER_DATA_DIR/security/rest.properties, only admin has access to
REST services by default), like this:
wms?request=GetLegendGraphic...&SLD=http://localhost:8080/geoserver/rest/workspaces/&lt;ws&gt;/styles/&lt;style&gt;\.sld
However, have you taken into consideration my previous suggestion, i.e.
splitting your layer.sld file in two separate SLD files, containing just
one UserStyle each?
You'd end up with layer.sld containing the "layer" UserStyle, to be
used, I presume, in GetMap requests, and layerLegend.sld, containing the
"layerLegend" UserStyle, to be used in GetLegendGraphic requests.
Is there any particular reason this approach would not work for your use
case?
Il giorno lun, 15/06/2015 alle 12.29 +0000, Roel De Nijs ha scritto:
Hi Andrea,
success.
Kind regards,
Roel
Best regards,
Stefano Costa
Dott. Stefano Costa
D.Lgs. 196/2003.
Hi Stefano,
Sorry for not being clear about your previous suggestion. That is exactly what we are currently using :slight_smile:
The reason why I'm investigating this possibility of combining multiple styles in 1 SLD, is merely from a maintenance point of view rather than a functional point of view. I assume if all styles for a certain layer are in 1 SLD and one style needs some changes, it's easier not to forget to change the other styles accordingly if all styles are combned in 1 SLD (instead of 2 or more different SLDs). And because it works flawlessly if you provide a link to an (external) sld using the SLD parameter, it might probably be pretty easy to use an SLD file from my workspace.
I didn't think about the REST interface. I will definitely be investigating that one as it seems there's no other possibility to refer to a workspace-specific style. If this request would work, it would be the ideal solution:
<ws>/wms?request=GetLegendGraphic...&SLD=layer.sld
And then geoserver would retrieve the layer.sld from the workspaces/<ws>/styles directory.
Kind regards,
Roel
-----Oorspronkelijk bericht-----
Verzonden: maandag 15 juni 2015 15:00
Aan: Roel De Nijs
CC: Andrea Aime; geoserver-users@lists.sourceforge.net
Hi Roel,
you could try and access the SLD files in your workspace via the REST interface (remember to tune the REST security configuration in $GEOSERVER_DATA_DIR/security/rest.properties, only admin has access to REST services by default), like this:
splitting your layer.sld file in two separate SLD files, containing just one UserStyle each?
You'd end up with layer.sld containing the "layer" UserStyle, to be used, I presume, in GetMap requests, and layerLegend.sld, containing the "layerLegend" UserStyle, to be used in GetLegendGraphic requests.
Is there any particular reason this approach would not work for your use case?
Hi Andrea,
success.
Kind regards,
Roel
Best regards,
Stefano Costa
GeoServer Professional Services from the experts! Visit http://goo.gl/it488V for more information.
Dott. Stefano Costa
Le informazioni contenute in questo messaggio di posta elettronica e/o nel/i file/s allegato/i sono da considerarsi strettamente riservate.
Il loro utilizzo è consentito esclusivamente al destinatario del messaggio, per le finalità indicate nel messaggio stesso. Qualora riceviate questo messaggio senza esserne il destinatario, Vi preghiamo cortesemente di darcene notizia via e-mail e di procedere alla distruzione del messaggio stesso, cancellandolo dal Vostro sistema.
Conservare il messaggio stesso, divulgarlo anche in parte, distribuirlo ad altri soggetti, copiarlo, od utilizzarlo per finalità diverse, costituisce comportamento contrario ai principi dettati dal D.Lgs. 196/2003.
The information in this message and/or attachments, is intended solely for the attention and use of the named addressee(s) and may be confidential or proprietary in nature or covered by the provisions of privacy act (Legislative Decree June, 30 2003, no.196 - Italy's New Data Protection Code).Any use not in accord with its purpose, any disclosure, reproduction, copying, distribution, or either dissemination, either whole or partial, is strictly forbidden except previous formal approval of the named addressee(s). If you are not the intended recipient, please contact immediately the sender by telephone, fax or e-mail and delete the information in this message that has been received in error. The sender does not give any warranty or accept liability as the content, accuracy or completeness of sent messages and accepts no responsibility for changes made after they were sent or for other risks which arise as a result of e-mail transmission, viruses, etc.
Volg Aquafin op Facebook<https://www.facebook.com/AquafinNV&gt; | Twitter<https://twitter.com/aquafinnv&gt; | YouTube<http://www.youtube.com/channel/UCk_4P5BJ-MtEEDCkCsR_KqQ?feature=mhee&gt; | LinkedIN<http://www.linkedin.com/company/aquafin/products&gt;
Disclaimer: zie www.aquafin.be<http://www.aquafin.be> P Denk aan het milieu. Druk deze mail niet onnodig af.
[http://www.aquafin.be/ISOlogo.png\] <http://pers.aquafin.be/aquafin-behaalt-eerste-belgische-iso55001-certificaat#&gt;
On Mon, Jun 15, 2015 at 6:12 PM, Roel De Nijs <roel.denijs@anonymised.com>
wrote:
Hi Stefano,
GeoServer configuration is designed to have one style per SLD file, if you
go out that pattern, you're pretty much on your own, it might work in some
cases, not at all in others.
We only support properly multiple styles per sld file when they come as
dynamic parameters in the request, but that has its own downside, including
that we fetch
and parse the sld file for every single request
Ing. Andrea Aime
@geowolf
Technical Lead
