On Thu, Dec 3, 2015 at 6:05 PM, Smart, Gary Export License Required - US
UTAS <Gary.Smart@anonymised.com> wrote:
OK – yes I see the difference – thanks for the prod!
I had two servers providing the same layer – one using geoserver to proxy
a WMS, the other direct from the WMS.
Ah, so your "proxy" is in fact a WMS store that does WMS cascading
When the GET occurs from the geoserver proxy – the hint is lost.
When the GET occurs direct from the WMS the hint is preserved.
I presume I would need to manually set the minScale maxScale parameters in
the geoserver UI (for each STORE) in order for geoserver to pass them
through
i.e. they are not simply inherited from the WMS source?
Correct, they are not. GeoServer computes its own scale hints from the
default SLD style associated to the layer.
For cascaded WMS layers you don't even have a SLD style, so there is
nothing to go against... I believe some new code
needs to be written to allow scale hints to be set, or just directly
cascaded, for this type of layer.
See this guide if you would have to have this implemented:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
*Geosolutions' Winter Holidays from 24/12 to 6/1*
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
