[Geoserver-users] getCapabilities problem
Nunzio,
which version are you using?
Try running getCapabilities after setting SKIP_MISCONFIGURED_LAYERS in global settings of geoserver (http://docs.geoserver.org/latest/en/user/webadmin/server/globalsettings.html#resource-error-handling)
If it works in that case you have to check disappearing style or layer configuration.
Carlo
2013/2/14 Nunzio Testa <nunzio.testa@anonymised.com>
Dear all,
i tried to use geoserver getCapabilities functionality.
I make the following request http://geoserver/ows?service=wms&version=1.1.1&request=GetCapabilities. The processing starts but the resulting XML terminate with the following error
Carlo,
the version the geoserver versioni s 2.2.
I already setting the Resource error handling to “SKIP_MISCONFIGURED_LAYERS”, but it seem to be not have the expected result.
In this configuration I receive the error.
Nunzio
Da: geo.ccancellieri@anonymised.com [mailto:geo.ccancellieri@anonymised.com84…] Per conto di carlo cancellieri
Inviato: giovedì 14 febbraio 2013 11:54
A: Nunzio Testa
Oggetto: Re: [Geoserver-users] getCapabilities problem
Nunzio,
Carlo
Dear all,
