Hi List,
On my 2.4.0 instance, when I try and GetCapabilities for either WMS 1.1 or 1.3, both return an exception:
javax.xml.transform.TransformerException: java.lang.NullPointerException java.lang.NullPointerException null
The log contains:
2013-10-16 10:42:15,406 ERROR [org.geoserver.ows] -
org.geoserver.platform.ServiceException: javax.xml.transform.TransformerException: java.lang.NullPointerException
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Response.write(Capabilities_1_3_0_Response.java:49)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:919)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:276)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
Caused by: javax.xml.transform.TransformerException: java.lang.NullPointerException
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(Unknown Source)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:300)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:112)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Response.write(Capabilities_1_3_0_Response.java:47)
… 82 more
Caused by: java.lang.NullPointerException
at com.sun.proxy.$Proxy6.hashCode(Unknown Source)
at org.geoserver.catalog.impl.LayerInfoImpl.hashCode(LayerInfoImpl.java:244)
at sun.reflect.GeneratedMethodAccessor106.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:145)
at com.sun.proxy.$Proxy22.hashCode(Unknown Source)
at java.util.HashMap.getEntry(Unknown Source)
at java.util.HashMap.containsKey(Unknown Source)
at java.util.HashSet.contains(Unknown Source)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleLayerTree(Capabilities_1_3_0_Transformer.java:789)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleLayers(Capabilities_1_3_0_Transformer.java:678)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.handleCapability(Capabilities_1_3_0_Transformer.java:429)
at org.geoserver.wms.capabilities.Capabilities_1_3_0_Transformer$Capabilities_1_3_0_Translator.encode(Capabilities_1_3_0_Transformer.java:264)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:1026)
at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transformIdentity(Unknown Source)
… 88 more
All other services GetCaps seem fine.
Any thoughts? Might it be a bug or has something got misconfigured?
Jonathan
This transmission is intended for the named addressee(s) only and may contain sensitive or protectively marked material up to RESTRICTED and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this transmission in error please notify the sender immediately. All email traffic sent to or from us, including without limitation all GCSX traffic, may be subject to recording and/or monitoring in accordance with relevant legislation.
