On Tue, Feb 9, 2016 at 10:48 AM, Volkan Gümüs <hallo@anonymised.com> wrote:
Hi!
I'm using GetFeature with bbox to retrieve features which are inside the
given bbox.
Please see the image in the attachment.
I'm using the bbox of Polygon2 with GetFeature. I would expect to get only
the feature of Polygon2. But GetFeature also gives me the bbox of Polygon1.
Is this because of the Bbox of Polygon1? How can I avoid this?
You have two quick choices:
* Use an explicit intersection filter (making a XML POST request) instead
of a BBOX one
* Go to the store configuration and disable the "loose bbox" checkbox.
Mind, this will also make all WMS requests slower, and full intersection
tests
will be used there too
A not so quick choice is to change the implementations so that WFS uses a
strick bbox implementation for accuracy, but WMS a loose
one for speed. This would require writing code, there is a guide to follow
this path here:
https://github.com/geoserver/geoserver/wiki/Successfully-requesting-and-integrating-new-features-and-improvements-in-GeoServer
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
