[Geoserver-users] GetFeature BBox
Use Intersects filter instead of BBOX for getting just polygon 2. It will be somewhat slower. BBOX is making search by the bounding boxes of features and all feature with totally or partially overlapping features will be found.
If you want only features which are totally inside the selection box, use the Within filter.
-Jukka Rahkonen-
Volkan Gümüs wrote:
Hi!
I'm using GetFeature with bbox to retrieve features which are inside the given bbox.
Please see the image in the attachment.
I'm using the bbox of Polygon2 with GetFeature. I would expect to get only the feature of Polygon2. But GetFeature also gives me the bbox of Polygon1.
Is this because of the Bbox of Polygon1? How can I avoid this?
Hotlink to image: http://fs5.directupload.net/images/160209/9cfh8ip5.png
Beste Grüße
Volkan Gümüs
F1-Computer.de
Tel: 0231 223 985 60
Fax: 0231 330 295 08
Mail: hallo@...7451...
