[Geoserver-users] GetFeature Java Problem
Hi All!
I've found the answer!
  try {
    HttpClient client = new HttpClient();
    GetMethod method = new GetMethod( url );
    method.setFollowRedirects( true );
    // Execute the GET method
    int statusCode = client.executeMethod( method );
    if( statusCode != -1 ) {
      String contents = method.getResponseBodyAsString();
      method.releaseConnection();
      System.out.println( contents );
   catch( Exception e ) {
    e.printStackTrace();
Ths website was helpfull: http://www.informit.com/guides/printerfriendly.asp?g=java&seqNum=43&rl=1
Best regards,
Virginie
-----Message d'origine-----
De : Justin Deoliveira [mailto:jdeolive@anonymised.com]
Envoyé : vendredi 19 janvier 2007 18:11
À : Virginie BERRE
Cc : geoserver-users@lists.sourceforge.net
Objet : Re: [Geoserver-users] GetFeature Java Problem
By default, the body of post requests are considered to be xml. In this
case you want the mime-type to be "application/x-www-form-urlencoded". I
beleive you can do this with the line:
connection.setRequestProperty("Content-Type",
"application/x-www-form-urlencoded");
Virginie BERRE wrote:
Hi All !
I've some troubles with Java code and hope you could help me.
I try to receive the GML response to a GetFeature request.
Let see my Java code:
String service_request_version = URLEncoder.encode("service") + "=" +
URLEncoder.encode("WFS") +
                        "&" + URLEncoder.encode("version") + "=" +
URLEncoder.encode("1.0.0") +
                        "&" + URLEncoder.encode("request") + "=" +
URLEncoder.encode("GetFeature");
                        String typename = URLEncoder.encode("typename")
+ "=" + URLEncoder.encode("adresses:commune");
                        String maxfeatures =
URLEncoder.encode("maxfeatures") + "=" + URLEncoder.encode("100");
                        String filter = "<ogc:Filter><ogc:BBOX>" +
"<ogc:PropertyName>GEOMETRY</ogc:PropertyName>" +
                                               "<gml:Box
xmlns:gml=\"http://www.opengis.net/gml\\&quot; srsName=\""+srs+"\">" +
"<gml:coordinates>"+xMin+","+yMin+","+xMax+","+yMax+"</gml:coordinates>"+
                                               "</gml:Box>" +
                                   "</ogc:BBOX></ogc:Filter>";
                        String filterEncoded =
"filter="+URLEncoder.encode(filter);
                        String parameters =
service_request_version+"&"+typename+"&"+maxfeatures+"&"+filterEncoded;
                        OutputStreamWriter osw = null;
                        try {
                                   URL url = new
URL("http://localhost:8080/AdressesServices-1.0/wfs&quot;\);
                                   HttpURLConnection connection =
(HttpURLConnection) url.openConnection();
                                   connection.setDoOutput(true);
                                   osw = new
OutputStreamWriter(connection.getOutputStream());
                                   osw.write(parameters);
                                   osw.flush();
                                   BufferedReader br = new
BufferedReader(new InputStreamReader(connection.getInputStream()));
                                   String response = new String();;
                                   String line;
                                   while((line = br.readLine()) != null)
                                               response += line;
                                   br.close();
                                   osw.close();
                                   System.out.println(url+"?"+parameters);
                                   System.out.println(response);
                        } catch (MalformedURLException e) {
                        } catch (IOException e) {
The URL is well-formed and when I copy it on my browser, it works fine
but the response returned is :
<ServiceExceptionReport version="1.2.0"
xsi:schemaLocation="http://www.opengis.net/ogc
http://localhost:8080/AdressesServices-1.0/schemas//wfs/1.0.0/OGC-exception.xsd&quot;&gt;
<ServiceException
locator="org.vfny.geoserver.util.requests.readers.DispatcherXmlReader">
      org.xml.sax.SAXParseException: Content is not allowed in prolog.
</ServiceException>
</ServiceExceptionReport>
If anyone could help me...
Thanks!
Best regards,
* Virginie BERRE / Ingénieur étude et développement *
Générale d'Infographie
ZA Les Erables - bâtiment 4
66 route de Sartrouville - 78232 Le Pecq Cedex
Tél. : (33) (0)1.30.15.40.50 - Fax : (33) (0)1.30.15.40.60
mailto:vberre@anonymised.com
http://www.generale-infographie.fr/&gt;
P / // N'imprimez ce message que si vous en avez l'utilité / ...
!DSPAM:1004,45b0da9c175561702038478!
opinions on IT & business topics through brief surveys - and earn cash
Geoserver-users mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
I'm glad you got it working.
I will update the FAQ with your solution so it might help others in the future.
cheers,
Brent Owens
(The Open Planning Project)
Hi All!
  try {
Best regards,
Virginie
De : Justin Deoliveira [mailto:jdeolive@anonymised.com] Envoyé : vendredi 19 janvier 2007 18:11
À : Virginie BERRE
By default, the body of post requests are considered to be xml. In this case you want the mime-type to be "application/x-www-form-urlencoded". I beleive you can do this with the line:
connection.setRequestProperty("Content-Type", "application/x-www-form-urlencoded");
Hi All !
String service_request_version = URLEncoder.encode("service") + "=" + URLEncoder.encode("WFS") +
                        "&" + URLEncoder.encode("version") + "=" + URLEncoder.encode("1.0.0") +
                        "&" + URLEncoder.encode("request") + "=" + URLEncoder.encode("GetFeature");
                        String typename = URLEncoder.encode("typename") + "=" + URLEncoder.encode("adresses:commune");
                        String maxfeatures = URLEncoder.encode("maxfeatures") + "=" + URLEncoder.encode("100");
                                               "<gml:Box xmlns:gml=\"http://www.opengis.net/gml\\&quot; srsName=\""+srs+"\">" +
                                               "</gml:Box>" +
                        String filterEncoded = "filter="+URLEncoder.encode(filter);
                        String parameters = service_request_version+"&"+typename+"&"+maxfeatures+"&"+filterEncoded;
                        try {
                                   URL url = new URL("http://localhost:8080/AdressesServices-1.0/wfs&quot;\);
                                   HttpURLConnection connection = (HttpURLConnection) url.openConnection();
                                   osw = new OutputStreamWriter(connection.getOutputStream());
                                   osw.flush();
                                   BufferedReader br = new BufferedReader(new InputStreamReader(connection.getInputStream()));
                                   String line;
                                               response += line;
                                   br.close();
                                   osw.close();
The URL is well-formed and when I copy it on my browser, it works fine but the response returned is :
<ServiceExceptionReport version="1.2.0" xsi:schemaLocation="http://www.opengis.net/ogc http://localhost:8080/AdressesServices-1.0/schemas//wfs/1.0.0/OGC-exception.xsd&quot;&gt;
<ServiceException locator="org.vfny.geoserver.util.requests.readers.DispatcherXmlReader">
</ServiceException>
Thanks!
Best regards,
