On Wed, Nov 18, 2015 at 11:07 AM, Rahkonen Jukka (MML) <
jukka.rahkonen@anonymised.com> wrote:
I would read this
http://docs.geoserver.org/stable/en/user/services/wfs/schemamapping.html
and then try something like
<xsd:element maxOccurs="1" minOccurs="0" name="geometry" nillable="true"
type="gml:MultiLineStringPropertyType"/>
MultiSurface is what GML 3 most often uses and I suggest to file a feature
request for your application about that. However, mismatch between
DescribeFeatureType and GetFeature may be a bug in Geoserver 2.8 but I am
not sure. MultiCurve with just linear members is the same as
MultiLineString but I can’t say if client that is prepared to receive
MultiLineStrings but is getting those enclosed inside MultiCurves has good
enough reason for throwing an error.
MultLineString in WFS 1.1 schemas is deprecated and meant to be replaced
with MultiCurve, but yeah, I've verified that the DescribeFeatureType does
not
match on a 2.8.x I have handy (somewhat surprised the CITE tests we run
nightly are not failing because of it)
Dominik, can you open a report at
https://osgeo-org.atlassian.net/projects/GEOS ?
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
