It there really a need to adjust “LAYERS”? We keep it to whatever is happens to be and change only the “QUERY_LAYERS” on the client side. Actuallly we capture the last used WMS GetMap and construct a new GetFeatureInfo by using it as a template and adding the constant QUERY_LAYERS and X and Y parameters from the mouse click. That works for us but the WMS server in this case is Mapserver and not Geoserver.
-Jukka Rahkonen-
Andrea Aime wrote:
There is no “configuration” you can do to perform what you’re looking for, but
if you up to programming, you can build a plugin implenetation, called a DispatcherCallback,
in which you replace on the fly the name of the raster layer with the name of the vector layer
in both the layers and query_layers portion of the request.
On Mon, Feb 11, 2013 at 1:38 PM, Rahkonen Jukka <jukka.rahkonen@anonymised.com486…> wrote:
As far as I remember, by specification the server should throw an error if the query_layers layers are not a subset of layers
Ing. Andrea Aime
@geowolf
Technical Lead
Via Poggio alle Viti 1187
mob: +39 339 8844549
