On Fri, Jul 22, 2016 at 10:28 AM, Tobias Reinicke <ramotswa@anonymised.com> wrote:
Thanks Andrea,
Yes it was on “leave native”. Changing that to “force declared” (and undoing the tomcat java option) also solves the problem.
Do you happen to know how to specify “force declared” on a shapefile when loading it via curl?
Toby
On 20 July 2016 at 16:23, Andrea Aime <andrea.aime@anonymised.com107…> wrote:
On Wed, Jul 20, 2016 at 4:17 PM, Diego Nieto Cid <dnietoc@anonymised.com> wrote:
The issue is marked as fixed so I’m not sure why it was happening. May it’s something that must be fixed per projection.
Not really. The fix just tries to leverage an eventual EPSG code baked into the projection, but it won’t work for
shapefiles generated by ESRI software, that normally do not contain any EPSG code.
That said, if the projection handling is set to “force declared” then GeoServer should be forcing in a projection
with a proper code, wondering if the shapefile in question is using the “leave native” instead of “force declared”
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
Ing. Andrea Aime
@geowolf
Technical Lead
