When wms layer is authenticated, PHP XMLReader is not able to read the GetFetaureInfo output format (GML). (Able to view the info in simple OpenLayers format). But the same XMLReader is working good and throw the result when GeoServer layer is not authenticated…
Kindly suggest on how we can read GetFetaureInfo values from PHP, pls.We are using Windows OS, GeoServer Version from 2.3.5 to 2.4.4.
On Tue, Jan 28, 2014 at 11:04 AM, geo gis <gisgeoserver@anonymised.com> wrote:
result when GeoServer layer is not authenticated..
WatchGuard Dimension instantly turns raw network data into actionable
security intelligence. It gives you real-time visual feedback on key
security issues and trends. Skip the complicated setup - simply import
a virtual appliance and go from zero to informed in seconds. http://pubads.g.doubleclick.net/gampad/clk?id=123612991&iu=/4140/ostg.clktrk
Geoserver-users mailing list
Geoserver-users@lists.sourceforge.net https://lists.sourceforge.net/lists/listinfo/geoserver-users
