Not there, but you could write a PropertyCollector reading the exif tags and the like, so that they
are added to the index, and then indeed publish the index via WFS.
If it’s a mosaic that’s the way to go, if we are talking single images it seems a bit complicated, but
still, there are no other ways, exposing other types of coverage properties would be possible, but
also quite a bit of work (read them in the reader, store them in the coverage, change featureinfo
to look for these extra attributes)
On Wed, Aug 31, 2016 at 5:54 PM, Paul Wittle <P.Wittle@anonymised.com> wrote:
Thanks Ian,
So nothing in the http://docs.geoserver.org/stable/en/user/tutorials/imagemosaic_timeseries/imagemosaic_time-elevationseries.html tutorial will help me then?
Paul
Sent: 31 August 2016 16:42
To: Paul Wittle
Cc: geoserver-users@anonymised.comsourceforge.net
Subject: Re: [Geoserver-users] GetFeatureInfo on Raster layers
On 31 August 2016 at 16:15, Paul Wittle <P.Wittle@anonymised.com> wrote:
Is it possible to return attribute information on raster layers?
For a raster the attributes tend towards red, green and blue values.
To give examples, I want to know if you can return the source filename for image mosaic layers.
No, I don’t think so. But if you added the index layer as a layer you could do getFeatureInfo requests against that.
I would also be interested in knowing if the GeoServer is able to read Exif tags in photos etc.
I don’t think so
Ian
“This e-mail is intended for the named addressee(s) only and may contain information about individuals or other sensitive information and should be handled accordingly. Unless you are the named addressee (or authorised to receive it for the addressee) you may not copy or use it, or disclose it to anyone else. If you have received this email in error, kindly disregard the content of the message and notify the sender immediately. Please be aware that all email may be subject to recording and/or monitoring in accordance with relevant legislation.”
Geoserver-users mailing list
Geoserver-users@anonymised.com.382…sourceforge.net
Ing. Andrea Aime
@geowolf
Technical Lead
Via di Montramito 3/A
mob: +39 339 8844549
