[Geoserver-users] getFeatureInfo problem when geomcollection?
When my feature is geomcolleciton type consist of line and polygon, the
getFeatureInfo of geoserver remind me the error "Relate Operation called
with a LWGEOMCOLLECTION type. This is unsupported
Could I click a feature consist of both line and polygon? If the click point
intersect my line or within my polygon, I will consider user select the
feature.Could this possible?
View this message in context: http://www.nabble.com/getFeatureInfo-problem-when-geomcollection--tp22595449p22595449.html
As far as I know "heterogeneous" geometry collections is not something we really support. I could be wrong, Andrea?
Are you able to do a wfs "GetFeature" request against the layer?
-Justin
Justin Deoliveira
OpenGeo - http://opengeo.org
Well, for sure it was not really tested out. Anyways, the error
I'm seeing here:
is a PostGIS generated one. It seems postgis itself has troubles dealing
with geometry collections?
Andrea Aime
