I’m running geoserver 1.7.4…using OracleNG driver (this one is the best, right? So I’ve heard…)…having issues with getfeatureinfo… At random times (not consistently) if I click on a feature on the map, (using a wms) I’ll get back an error…
Unable to generate information java.lang.RuntimeException: java.io.IOException
no features were found
Interestingly, there is one layer that I can query with getfeatureinfo that returns this error every time. The others return it inconsistently. The log…
2009-05-01 15:25:13,494 WARN [geotools.jdb] - There is code leaving feature readers/iterators open, this is leaking statements and connections!
2009-05-01 15:25:13,494 WARN [geotools.jdbc] - Error occurred closing statement
2009-05-01 15:25:13,494 WARN [geotools.jdbc] - Error occurred closing connection
2009-05-01 15:25:14,103 WARN [geotools.jdb] - There is code leaving feature readers/iterators open, this is leaking statements and connections!
2009-05-01 15:27:41,090 WARN [geotools.jdbc] - Error occurred closing connection
2009-05-01 15:27:41,090 WARN [wms.featureinfo] - Error generating getFeaturInfo, HTML format
at org.geotools.data.store.ContentFeatureCollection.iterator(ContentFeatureCollection.java:275)
at org.geoserver.feature.RetypingFeatureCollection.iterator(RetypingFeatureCollection.java:47)
at org.geoserver.feature.RetypingFeatureCollection.features(RetypingFeatureCollection.java:56)
at org.vfny.geoserver.wms.responses.featureInfo.TextFeatureInfoResponse.writeTo(TextFeatureInfoResponse.java:97)
at org.vfny.geoserver.wms.responses.GetFeatureInfoResponse.writeTo(GetFeatureInfoResponse.java:175)
at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:712)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:216)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:617)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:290)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:235)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.geoserver.filters.LoggingFilter.doFilter(LoggingFilter.java:73)
at org.geoserver.filters.ReverseProxyFilter.doFilter(ReverseProxyFilter.java:163)
at org.geoserver.filters.GZIPFilter.doFilter(GZIPFilter.java:41)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:233)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:191)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:102)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:286)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:845)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:583)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
at java.lang.Thread.run(Unknown Source)
Caused by: java.io.IOException
at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:526)
at org.geotools.data.store.ContentFeatureSource.getReader(ContentFeatureSource.java:508)
at org.geotools.data.store.ContentFeatureCollection.iterator(ContentFeatureCollection.java:272)
… 55 more
Caused by: java.sql.SQLException: Io exception: Socket closed
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:112)
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:146)
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:255)
at oracle.jdbc.driver.T4CPreparedStatement.executeForRows(T4CPreparedStatement.java:977)
at oracle.jdbc.driver.OracleStatement.executeMaybeDescribe(OracleStatement.java:1060)
at oracle.jdbc.driver.T4CPreparedStatement.executeMaybeDescribe(T4CPreparedStatement.java:839)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1132)
at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3316)
at oracle.jdbc.driver.OraclePreparedStatement.executeQuery(OraclePreparedStatement.java:3361)
at org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:93)
at org.geotools.jdbc.JDBCFeatureReader.(JDBCFeatureReader.java:153)
at org.geotools.jdbc.JDBCFeatureSource.getReaderInternal(JDBCFeatureSource.java:514)
… 57 more
Any thoughts?
Important Notice: This Email may contain confidential or proprietary information. If you are not the addressee, San Jose Water Company respectfully requests that you reply to the sender so the sender can correct the addressee. Please destroy the Email after returning it to the sender. Please note that possession of confidential or proprietary information when you are not the intended recipient may have consequences, including civil liability and criminal prosecution. Nothing in this communication is intended to operate as an electronic signature under applicable law.
Aaron Gundel | GIS Programmer | San Jose Water Company | 1265 South Bascom Avenue | San Jose, CA 95110
E: aaron_gundel@anonymised.com (mailto:aaron_gundel@anonymised.com) | P:(408)918-7259 | F:(408)279-7989
