[Geoserver-users] GetFeatureInfo response in JSON
Hello, all.
I use OpenLayers(in JavaScript) as client for GeoServer. And I need to programmatically get features infos by user clicking on map. I also need to programmatically operate with this answers. JSON is good for this. I found that GeoServer don't represent GetFeatureInfo in JSON text format. Did anybody use this?
I also found that to activate this feature infos I need to add to wms.jar files and recompile this module.
The files I found is:
1. src/main/java/org/vfny/geoserver/wms/responses/featureinfo/JSONFeatureInfoResponse.java
I will place another class file JSONFeatureInfoResponse that extends AbstractFeatureInfoResponse.
2. src/main/java/org/vfny/geoserver/wms/responses/GetFeatureInfoResponse.java
I will append to List supportedMimeTypes my feature info class like this
        producer = new JSONFeatureInfoResponse();
        supportedMimeTypes.addAll(producer.getSupportedFormats());
        delegates.add(producer);
3. Are any other steps I must to do to activate another GetFeatureInfoRequest? Are my steps correct? Did anybody this work(or I'am the first)?
P.S.
I think the simple response in JSON will be(two features from different layers) :
  { // first feature
    fid: "Parcel.123",
    area: 500.50,
    descr: "Text feature description"
  { // second feature
    fid: "Bounds.44",
    place: "afrozodiak"
To use this in JavaScript:
var resultList=eval('('+response.responseText+')');
resultList.length; // count of features in result
resultList[0].fid; // first feature fid
resultList[1].place; // or resultList[1]["place"] - the situation of second feature
Have a good day.
Andrew.
Семененко Андрея ha scritto:
Hello, all.
GetFeatureInfo classes have been negleted for quite some time and
are in some dire need for a restructuring. Anyways, the steps above
do look fine to me, they should work.
Interested in contributing back your JSonFeatureInfoResponse?
Thank you.
But I can't add org.json dependency into pom.xml for maven2. Could you help me? I want to use only org.json.JSONWriter. What the groupId,artifactId,version I need to use in pom.xml?
óÅÍÅÎÅÎËÏ áÎÄÒÅÑ ha scritto:
> Hello, all.
Thank you.
WFS already has GeoJson output so you may just want to
have a look there (also for the coding, that is)...
sorry I haven't told you before, I thought you knew.
Anyways, here is what the wfs pom uses (on trunk)
         <dependency>
           <groupId>net.sf.json-lib</groupId>
           <artifactId>json-lib</artifactId>
           <classifier>jdk13</classifier>
         </dependency>
A simple patch to GeoServer for GetFeatureInfo JSON response in attachment.
> Thank you.
         <dependency>
         </dependency>
json.diff (6.33 KB)
